Tribute MX250 My Build
6 Oct 2017, 6:00pm
Holes pre cut ?
Blimey, never in my day :)
6 Oct 2017, 8:16pm
Yep requested when ordered, wasn't confident in getting good cuts so opted for pre cut, makes things a little easier :)
8 Oct 2017, 9:48am
Be sure to take plenty of pics and post them as you put it all together. Good luck.
12 Oct 2017, 8:59pm
Thinking about the rear lights and I'm wanting something like the attached picture. Anybody know where I can get the round lights with chrome surround and the small oblong fog and reverse lights ?
12 Oct 2017, 10:02pm
Europa spares , car builders , kit car solutions
13 Oct 2017, 2:53am
You can find them in plastic or glass also.
13 Oct 2017, 7:02am
Perfect Thankyou, looks to a few other bits I'll need too.
13 Oct 2017, 7:06am
So yesterday I managed to get a few hours in. I temporarily fitted the rear boot extension and extended parcel shelf with a few screws and re fit the rear shell to make sure all looks ok. Also gave me an opportunity to mark where the paint will need removing from the rear panels.
13 Oct 2017, 5:52pm
Hi if you intend to put in a headlining then best fit it while you can turn the rear section over as its a pig to do after you have bonded it all on , looking forward to your build Ned
13 Oct 2017, 7:58pm
Hi Ned. Yep that's my plan going to get all the fixings for the rear panel and temp install once all is good I'll remove the panel, put in the headlining and then start the process of bonding everything into place. I'm just so restricted for room so think it's going to be a case of installing the headlining on the panel in my conservatory lol.
13 Oct 2017, 7:59pm
Noticed on most of the builds none of the cars have a rear reflector is this not required for the MOT ?
13 Oct 2017, 10:30pm
i thought they are needed just can't see them in most of the other builds. Will have to think where to put them to make everything symmetrical
17 Oct 2017, 5:16am
3148markc wrote:
…As I don't have much room…
You weren’t kidding, that does look like a very tight squeeze. :eek:
17 Oct 2017, 7:02pm
Yeah it's a squeeze but I knew it would be. Hopefully it'll showcase that you don't need a huge garage for such a project, but then again it would be heaven :icon_lol:
17 Oct 2017, 7:06pm
Got some goodies in the post from Europa today. Just waiting for some hole cutting tools and work can start on the rear. Getting the roll cage powder coated tomorrow as it needs doing which was a little disappointing it wasn't already but heyho.
21 Oct 2017, 4:08pm
Rollcage back from being powder coated, much better nice and clean.
21 Oct 2017, 4:09pm
Thinking about the connection to the new petrol filling cap has anybody got any links or tips on what to use to extend the fuel filler hose. Do I just get rid of the old one and get a complete new pipe ?
6 Nov 2017, 9:33pm
So managed to do a few more jobs, first off the lights have been drilled, just need fitting in when the cars all painted. Fuel filler cap and filler hose done and headlining installed, all ready now just to start bonding the rear on.
6 Nov 2017, 10:21pm
Curious as to what you are using for headliner material...
29 Nov 2017, 6:49pm
Roof on and sides bonded and riveted. Also got some longer rivets and did the roof, can only help and you don't see them from the inside once the plastic panel is back on. Now to get filling....
10 Dec 2017, 3:01pm
Thought I would skip the filling for now so started fitting the front end which doesn't seem too bad and the kit seemed to go on ok. The gaps between the door and the front seem a little questionable so will need re shaping so it's nice and close but also not catching on the door. Ordered bonnet hinges and front pins and will probably need lots of work to get the bonnet to sit neatly and smoothly on all edges and corners. Going to use the original wiper points so the left top will need cutting out slightly so the wiper arm doesn't catch on the body kit.
Hopefully will be able to get time to pull the car out and take some side pictures this week once the snow stops !
Been watching a ton of uTube clips around filling so hopefully it'll go ok..fingers crossed
7 Feb 2018, 10:13pm
You can extend the spindles through the kit too, which can make for a cleaner finish.
