MX250 Build
18 Apr 2016, 6:50pm
No updates yet as I have been on holiday for past week, hoping to get on it at the week end as wheel spacers have arrived and will be putting them on.
18 Apr 2016, 7:23pm
Cool, thanks Nick.
18 May 2016, 8:31pm
Hello Everybody
Here is an update of the MX250 build, have finally got the boot lid to fit and work properly have used some stainless hinges buried into the body then reinforced with a bit of fibreglass. Will end up with a slight hump but hopefully will smooth that out and loose a lot of it to maintain the flush look that the build is developing into.
Have also managed to get the original locking mechanism working and can open the boot with either the cable pull from inside the car and the key from outside the car.
I am now moving onto the boot to hopefully do the same there photo's attached.
24 May 2016, 6:55pm
Here's another update from the weekends push on the build, have now got the front hinges fixed and bonded in, and the bonnet in correct position so that the gaps are as close as they can be and the bonnet opens and closes.
I am now working on the bonnet catch that I have got a bolt assembly that works on the original cable pull, just figuring out now what the hoop on the bonnet will end up being for the best result for the bolt to slide into to.
Have also had to changed the drivers door after starting the car in reverse gear and jamming the door between the wall and car which then crushed the door, at least now I don't have to cut out that corrosion at the bottom of the door, but ended up with a MK2.5 door where mine is MK2 so had to change the wiring loom as the door sockets where different.
Getting close now to getting the rear end bonded on, and on with all that filling and sanding and choosing the final colour which I think has been through the full colour spectrum.
24 May 2016, 7:37pm
Looking good Nick. I do like your bonnet release. I have been thinking of something similar for mine as I am going for front mounted hinges too. Have you thought about getting another boot loop from a breakers?
Cheers for your tips on my front end. :nod::smile:
24 May 2016, 7:44pm
Thinking it will have to have a taper of some sort on the catch so that as you close the bonnet the bolt slides up the taper then into a hole and locks.
24 May 2016, 7:47pm
Could you not grind a shamfer onto the bolt? Have the end of the bolt butting up against the loop, and then a bit of downward pressure against a bump stop or seal and the bolt snaps in?
24 May 2016, 7:54pm
That is a possible option but not sure though if the bolt would go in far enough to be confident that it will lock properly. Probably a bit of experimenting to be done.
24 May 2016, 8:07pm
Good luck mate.
28 May 2016, 6:45pm
Another good few days with good progress on the car, have got the side indicators and vents on side of wing cut out and the indicator just positioned in.
Have also got all the flanges in for mounting the mesh in, and the spacer rings on the head lights so that you can put on and take off the chrome outer rings for the headlights.
Photos attached of the progress.
29 May 2016, 6:12am
Nick - Looks like your build is progressing nicely. :cool:
29 May 2016, 8:19am
I like the side indicators. They off a Cooper S mini ?
29 May 2016, 8:51am
Thanks for the comments, the indicators are off a mini cooper S was thinking of using the fog lights as well as one of the build threads mentions using them but are a bit expensive looking around for another alternative at the moment that could work.
29 May 2016, 8:44pm
Looking good Nick. Keep up the progress.
1 Jun 2016, 5:11pm
Hi Nick. Interested in how thick your spacers are for the headlights? I can't get my chrome rings on either! Cheers.
5 Jun 2016, 4:12pm
High Craig
Don't know if this is too late but have been on holiday for the past week.
The spacers are 12mm thick and I have used pvc plastic for the rings, this bring it just enough to give you the space to get the rings on.
I also had to drill a hole in the bottom of the light bucket on the car to be able to put screw in, as the lights that I have got have got the diamond shape and a P700 badge in them so screw is on bottom of lights as you put them together.
Nick
5 Jun 2016, 4:47pm
Hope you had a good holoday Nick. 12mm? That seems a lot. I had thought about having to drill a hole to get the screw in to hold the chrome rings on. Now I know someone else has done I will be doing the same. Cheers for the tips.
10 Jun 2016, 9:24pm
Getting ready for the back end to be bonded on over the weekend hopefully. Carpet bonded to parcel-shelf and soundproofing and head liner all bonded in.
11 Jun 2016, 6:44pm
Doing the head lining before bonding is such a good move its a pain once the body is on !!!!
11 Jun 2016, 9:02pm
Well that was a productive day finally the back end is bonded on with all the head lining in place and just a bit of trimming to finish off. I am glad that I put the head lining in first, can quite imagine it being a nightmare putting it in after you have bonded on.
Also got round to moving the wing mirrors forward which I think look better in that position.
Feel as though I'm getting somewhere now that the car is one piece, and getting to point where it just needs body work doing, now that all the fabrication and problem solving of getting things to work is done.
[img]http://www.madabout-kitcars.com/forum/attachment.php?attachmentid=3669&d=1465678067[i/mg]
12 Jun 2016, 10:16am
Looking really good , did you make your mind up regards the colour ?
12 Jun 2016, 12:14pm
Have got my mate trying to convince me to do gulf racing colours or burnt orange. But I can't make y mind up.
19 Jun 2016, 7:10pm
Well first day of many of noting but, arm ache, dust,and more dust.
19 Jun 2016, 7:18pm
What rear lights are you using?
