Dino V6 conversion
2 Feb 2016, 9:59am
Drsquashdavid wrote:
I did buy seperate engine and luggage covers with the intent of using them, but amongst the reasons I didn't was the problem of overcoming the engine position , height and canopy clearance.
BW
Hi Dave
I am looking for separate engine and luggage covers for my Dino.
Do you still have the ones you mentioned?
If so are they specifically for the Mirabeau or did they originate from one of the other Dino replicas (De Havilland, Classic replicas, Classic and Sports Cars unlimited (Cascu), Deon Scoperto) ?
Neil
3 Feb 2016, 11:44am
rossnzwpi wrote:
I made this quick picture. I think it would be really helpful if people could take some photos and measurements. (I know its hard to take photos if your project is not mobile though). That will help people plan their engine swaps. We can compare the real Dino to JH Classics/Deon, Scoperto, Classic Replicas, Dehavilland, Cascu's.
Ross
Hi Ross
I've managed to get some measurements from my part completed Classic Replicas 206GT. The engine is the Alfa V6 (Busso) 12v 2959cc. As it doesn't have an engine cover yet I can't detail some of the measurements but here are the ones I have
1) Ground up to centre of wheels :- 300mm
2) Wheel centre to wheel centre (wheelbase) :- 2230mm (which surprisingly is a bit short of the original 206GT's 2280mm)
3a) From ground to sump :- 140mm (a sumpguard might be a good idea!)
3b) From ground to top of engine :- 820mm
4) From ground to engine cover Not Available.
As it's still a project the only side view I have of it is this one from when I collected it on a trailer. As you can see it currently has 15" Alfa wheels which I will be replacing with a set of 15" cromodora replicas.
3 Feb 2016, 5:19pm
engine cover
Hi
For what it's worth I would say looking at your car it is a jhclassic's/deon body you have.Or I should say a mold from a shell from their mold. Classic replica's took a mold from a deon (formaly jhclassic') customer's car in return for completing his car. Not sure if they did ever complete the car though!!
As dehavilland took possession of jhclaasic's mold's when John Hurst went in to MR2 body swaps I'd say they are your best bet to get a engine cover and a boot lid that should fit.
Ian
4 Feb 2016, 10:40am
thecarbuilder246 wrote:
Hi
Ian
Hi Ian
Thanks for the info, that confirms what I thought.
The date the kit was originally purchased and the fact that it was designed for a single rear engine/boot lid led me to believe it was one of, if not the first, bodies that Classic Replicas produced and that it was basically the Deon body.
It was later on that they changed the kit to feature the separate engine and boot lids.
I hope De Havilland will be at Stoneleigh this year so I can have a talk with them about engine/boot covers, glass package, seats, instruments, brightwork....!
Neil
4 Feb 2016, 6:04pm
hello neil, went and measured my car when I saw your figures to compare, my centre of wheel to centre of wheel is 2270, ground to centre of wheel 30, ground to sump 120, ground to top of engine 825, been over speed bumps no problems, mine is a 94 build number 73 of 200 I believe made, my plate in engine bay dgt 073 and year made 94, I considered a 2 piece lid but am staying with the one piece, the prototype 206,s according to my book where one piece, regards dave
5 Feb 2016, 10:24am
Hi Dave
It's interesting to compare the figures, particularly the wheelbase difference. It looks like Classic Replicas have modified the chassis, I have a receipt indicating that the kit was originally purchased in 2002 and it details a chassis number of CR000100G/A.
massa wrote:
I considered a 2 piece lid but am staying with the one piece, the prototype 206,s according to my book where one piece.
That's something else I've learned, I think I need to read up on the history of the Dino!
Neil
6 Feb 2016, 4:24am
Hi Neil, it looks like your engine sticks out an inch or maybe two at most. So maybe the easiest and most aesthetically pleasing would be to raise the whole engine cover and boot lid by extending the lip around the edge with a curved triangular fillet. Suitably radiused it might be the least obtrusive. If it is about an inch or two high at the rear windscreen edge it could reduce to zero on the boot edge.
The huge bulge that Deon had to accommodate Ford V6s doesn't look like it belongs on a Dino to my eyes.
Ross
6 Feb 2016, 9:51am
boot lid
Hi all
Further to my other reply I have a deon gt with the ford cosworth V6 engine fitted and I have the proper engine cover and boot lid with no bulge. It is a tight fit but I can tell you it can be done.
I lowered the engine by machining the engine mounts by 20mm as in my opinion deon had placed the ford engine a little to high.This resulted in the drive shafts being at a angle when the car sat on it's wheels.
By lowering the engine and box 20mm it still no lower than the lowest part of the chassis and meant the proper engine cover and boot lid could fit. The drive shafts now are at a better angle albeit still slightly angled down towards the wheels.
ian
6 Feb 2016, 2:37pm
Hi Ross
I was thinking along the same lines, maybe in combination with filling or lifting the base of the rear window and the base of the buttress around the engine cover to lessen the height difference.
Neil
6 Feb 2016, 5:22pm
NeilF355 wrote:
Hi Ross
Neil
If it were me I'd look at other options. Once you start lifting panels and reshaping buttresses /filling and shaping etc the pure dino shape has gone then it will start to looked bodged!
Get an engine cover on and see what is required-you may be able to just reduce you inlet trumpets in height.
Ian
7 Feb 2016, 6:01am
engine lowering
Hi Ian, I agree with your idea of keeping to the original look of a Dino as much as possible. An Alfa V6 "should" fit based on the measurements I've heard. But if it needs as little as 20mm clearance then lowering the engine would probably be a good option. Just make sure the various angles created in drive shafts and cv joints are well within engineering tolerances. I wonder what those tolerances are? The real Dino 246 didn't have level driveshafts by the way, but the angle was fairly small.
Ross
7 Feb 2016, 12:44pm
Hi again
another couple of rear shots of my dino to show proper dino split engine cover and boot lid.when I received my deon body I had no bonnet/ boot or engine cover but was lucky to come across a guy with all these panels and I was able to borrow them and take molds from and produce my own. Alas before any one gets in touch I no longer have the molds. A small out fit called Low Rider Cars had them based (can you guess?) on the same business park as deon and later classic replicas in somerset!!
ian
9 Feb 2016, 6:40am
Hi Neil
I do still have the engine and luggage canopies. They were copies taken from a CR/Deon.
As said I ended up using the Mirabeau canopy but even then have had to modify to get the " hump" higher -- as per previous photo.
These did fit into my Deon Mirabeau lid cover ares fairly well.
Regards
9 Feb 2016, 6:48am
Hi Neil
After splitting I put a fibreglass panel across to act to divert water, carry the engine latches , and also the luggage hinges.
On the engine side it also has the cabling which is threaded through brake pipe fibreglassed to it
9 Feb 2016, 6:52am
Hi Neil
Another more recent view
9 Feb 2016, 9:54am
Hi Neil
Hi Dave
I am very interested in buying those from you.
I've PM'd you
Car seems to be coming along nicely
Best regards
Neil
15 Feb 2016, 11:33pm
What interesting differences in wheel base! Perhaps a small difference could be attributable to inaccuracies while measuring, such as not having the steering wheel dead ahead. But these are big differences! The original moulds from which nearly all (except maybe CASCU's) derive were taken off the 206GT and then David had the wheel arches moved back a bit to match the Lotus Europa Chassis he was bonding the body to. That gives 3 different possibilities: Europa/206GT/246GT. The Europa at 7'7" (2311.4mm); the 206GT's 2280mm (89.76" - 7' 5 3/4") or the 246GT's 2340mm (92.12" - 7'8.12").
Ross
16 Feb 2016, 10:11pm
wheel base
hi all
I thought the 206gt was only 40mm shorter than 246gt not 60mm
ian
21 Feb 2016, 10:09am
wheelbase
Hi
Sorry but I got confused! My deon 246 has a wheelbase 40mm shorter than a real dino 246!! my mistake.
ian
1 May 2016, 9:52am
Hi Dai, is that your car for sale on EBay? If so, good luck with the auction - it looks in great condition
cheers
Ross
1 May 2016, 12:03pm
Hi Ross, Yes it's mine, unfortunately I'm moving house and I need a much larger deposit than I expected.... So the toys are having to go 😢
1 May 2016, 4:44pm
HI
Very nice indeed. could I ask what kit you started out with?
ian
