Front Struts and Rear Hubs
31 Mar 2006, 12:07pm
Yay!
Just grabbed myself two brand new e30 rear bearings with replacement circlips for £20 of eBay.
Yeah, I know I said I'd give it up, but you know... I have eBayitus.... ;)
5 Apr 2006, 12:20pm
Hmmph. Well, they're going straight back on eBay. :roll:
So much for the distilled wisdom of the e30zone forums. "There's no difference between the bearings for an ABS car and a Non ABS car" they said. Oh yes there is. They're too fudgin' small! The hub won't fit in the center race, and the outer race would just fall into the carrier on the arm!
Ah well, ce la vie.
BTW - I'm about to start work on cleaning up the front struts. How much does Marlin cut off the top? I know that the modification is a bit more involved than that, but they obviously get shortened. What I want to know is whether I can cut the top couple of inches off (essentially the bit with the spring seat on it) so It doesn't have to be / get in the way when I'm cleaning the strut.
Ta,
Jason
5 Apr 2006, 12:57pm
Rear wheel bearings
I think someone might have sold you a pup there. According to ETK the trailing arms seem to be exactly the same no matter which version you have.
I chopped the top of my struts (can't remember why) before sending them to Marlin. Once Marlin modify them they are only about 6 to 8" long.
5 Apr 2006, 1:18pm
I did a very rough clean up of the front struts and then finished the job properly after Marlin made the modification. I couldn't get the dampers out of mine!
6 Apr 2006, 11:42am
Well - that's sorted. Apparently non ABS cars do have smaller bearings. I talked to the chap who sold them to me - initially to confirm that the correct ones had been sent - and he's agreed to take them back (less his ebay relist fee). So that's saved me having to resell them. :D
Now all I have to do is source some correctly sized ones! GSF prices look reasonable...
