I would even venture to say it would be impossible. Unless you have a very good engineering qualification and can certify the resulting strength and flexibility of your work to the standards to satisfy the examiner or can find somebody who can, it will never pass an IVA and it shouldn't pass an MOT either unless you completely reconstruct the connection which is almost impossible on a Triumph chassis. We aren't talking about a rust patch repairer here, which may be acceptable for the MOT depending on where it is (some parts of the chassis can't be repaired, I am told).
I have installed the Ford Transit chassis extending kits on their pickups and it's no minor procedure. They are plated with sandwich plates, inside and out and all bolted, 10mm bolts into captive nuts attached to the inner plates, welding is NOT allowed for the reasons Micky has mentioned above.
Modding the body on the other hand would be a doddle and nobody (in authority) will question it.
Good luck with the build!
Your comment has given me reason to give the project more thought.
I have found a matching section of steel, we intend to plate the appropriate joints, and the guys at the garage think its doable? Yes I will be building a special, but are not all these kit cars specials?
Was you experience of structural chassis extension so negative?
As all these cars are specials, and as Kit Cars go, they have always has strange thing done to them in order to achieve the final product. Whether its with the body or the chassis.
With the subframe bolted and welded to the original chassis it will becoming an integral part of the final car structure, I would have thought its would be fine. ( this is my first build from scratch and I really welcome your experienced practical knowledge)
Not true at all. No Sammio/Ribble/Miglia featured on this forum has done anything to the main chassis. And, there is a reason for this............the law is quite clear.
People have offered their advice unanimously (don't cut the chassis). You can heed this (there is a lot of experience on here) or not. If you do not, the chances of you producing a legal and roadworthy car reduce to almost zero.
If this is your first build, do everything you can to keep it simple.
Best of luck.
I will try and find what the Law says. Can you point me in the right direction. I just need to be sure. Thanks.
If I had read and acted upon the info available there, I may have avoided wasting well over £2000 and 1,100 hours building a car which was never going on the road. I have been building cars, specials, diggers and trucks all my life, I'm approaching 70 now and I am still learning something new every day!
The trouble is it isn't 'law', what we have to comply with are regulations, rules and 'directives', which the various government agencies decide are appropriate. There is nothing in law as far as I know regarding the '8 point rule' but if you disregard it you won't get your V5c. They hold the whip hand and we have to comply.
If you dig through all the stuff that ACE have assembled you will find there are a lot of things which some regard as normal mods, like bob-tailing Land Rovers and modifying VW Beetle chassis/floorpans which used to be common modifications, fitting a Webber airbox in a Mini for example, VOSA will revoke the V5c on the spot and the only way of getting the car, which will probably be a pride and joy, back on the road will mean an IVA, which depending on the vehicle and the mod may not be possible.
This can happen at an MOT or a roadside check. VOSA regularly 'sit in' on MOT's and they know what to look for on certain vehicles.
... With the subframe bolted and welded to the original chassis it will becoming an integral part of the final car structure...
The Miglias and Sammios were both designed so that the internal framework is bolted to the chassis.
The fibreglass bodywork is then bonded to the framework to effectively form a new body shell that could be removed if required.
It is the fact that it can be removed that allows these cars to avoid IVA by following the "re-body" rules.
IMHO the argument about whether it is technically possible to cut and extend the chassis is a red herring.
Even if you can technically do it, you are still left with no choice but to declare it and get an IVA test.
( Or your insurance will be invalid as your would not be road legal without the IVA. )
Obviously there are plenty of cars on the roads that are not legal.
But I would hope no one on here would publicly suggest you follow them.
I hope this doesn't come across as trying to lecture you, that is not my intention.
8 Valve Ed,
I have it from a contact in the DVSA as they now are that all the decat, bobtailing and shortening mods are going to be banned, along with rechecking that "historic (tax exempt) Cars" meet the eight point rule. If not, impounded and owner has to reregister,and iva/sva before they can have their car back. Exemption will cease on all modified cars like these. This is why its so crucial to build the Sammios/Ribbles/Miglias as designed. Soon us vehicle inspectors will be liable for confirming "correct build" with the obvious responsibility for turning a blind eye.
The 1958 Rocker
Best I re-register mine this week then - mine easily meets the 8 point rule - it is using the unmodified Spit chassis, engine, gearbox, rear axle, suspension and most other parts (ie seats, electrics, fuel tank, dials, steering). But will be interesting to see how the process pans out.
Hi just reg my miglia got the new v 5 back in 9 days just sent two pic of car one of chassl mlkes recit and a receipt for selling old body plus the form
Rattler, was your car MOTd or still SORNd when you registered your Miglia?
8 Valve Ed,
The 1958 Rocker
There was a thread on "Rod 'n' Sods" about this recently and there seems to be a lot of confusion.
My (very) limited understanding is that the problem area is "Reconstructed Classics" and linked to problems with the Bugatti owners club.
The story goes that some owners of very expensive "original" cars were not happy when cars rebuild around a just a handful of old parts were being accepted by the DVLA as being "reconstructed classics" and getting an age related (and therefore historic) number plates. So if you knew what you were doing you could build several "old" Bugattis from one car and make a lot of money. The problem was that unless they were using an original Bugatti chassis each time, it would not be legal under the 8 point rule and there require IVA & maybe even a Q plate. So I understand that the DVLA were "tipped off" and it has all "kicked off".
So whilst some people have received letters like the one below. The key point is that the problem is not that with the "historic vehicle" part, but rather the "recorded date of manufacture" part, hence the confusion.
So in the case of my Sammio Cordite, whilst I now have "Triumph Swordfish" on the V5C, it is still made in 1980. As far as I can tell, I would only have a problem if I'd managed to convince the DVLA is was made in 1955.
... He is very clued up. ....what he doesn't know isn't worth knowing
+1
Kevin also worked with Gary on the original Sammio Spyder concept so that it became a "bolt on" body shell (internal framework bonded to fibreglass outer shell) to keep within the re-body rules and avoid IVA.
With much regret, I may be looking to sell my Miglia Kit, it is the complete shell with duo humps, bulkhead, floors, doors, bonnet etc.. . It is time for me to face reality and realise I am not going to have time to start it, never mind finish it, with too many other project on the go.
£1,800 ovno, I paid over £2,000 plus extras.
•Kit contents
[INDENT]•One piece Miglia Speedster body
•Bulkhead
•300mm deep dashboard blank moulded into body
•Tear drop vent bonnet
•Double skinned doors
•Perspex windscreen
•Windscreen frame
•Steel subframe [/INDENT]
