Z300swb?
9 May 2015, 9:35am
WorldClassAccident wrote:
... If I had described the Z300S before it was built you would have said it would never work.
Having said that, I do occasionally get it wrong. The anchovies and Stilton sandwich I had last night after nine Duvals was not improved by adding caper berries.
Yes, I am grateful to you for getting the idea off the drawing board, seeing was believing and Chris's pricing the icing on the cake.
Good luck with the conversion- I have to admit I have often thought about chopping a Ford Escort Mk1 and an HB Vauxhall Viva in half and conjoining the opposite halves...
Experimental recipes as well now...
9 May 2015, 4:23pm
Car lowering has commenced!
Well first I raised the front and stuck some concrete blocks under it so I could pop the wheels off to get to the struts.
Amazingly the first came off really easily. 3 bolts at the bottom, three at the top a slight tap with the persuading hammer and the rust welding broke free to release the strut. Clearly the new ones are shorter and smaller
Second side had bolts held in place by Gods own hand and even when I had all six bolts out it wouldn't come free. There is a little 'dimple' that helps locate the strut that seems to attract rust weld. Multiple hammers and a long persuading stick were employed.
Eventually the git was freed
Now I cannot get the sodding top off the old shock to transfer to the new shocks. they are staying like this tonight
And the car looks like this
9 May 2015, 7:31pm
You need to increase the rideheight from the lowest it is in now....
Probably about 2cm.....
10 May 2015, 7:27am
The shocks are as they came with no compression in the spring. I will adjust once fitted.
I will start with 2cm as you suggest and see how it looks.
Just realised that as well as not having the right spanner for the top of the old shock, I don't have a hook spanner to adjust the new ones. Oh well, more tools to buy
10 May 2015, 10:26am
I've never before seen a scythe used to work on a motor car. Further posts eagerly awaited!
10 May 2015, 10:54am
Multifunctional tool. One day you are part of an angry mob the next you are levering the shock off.
Standard equipment in BMW technicians toolbox I believe
10 May 2015, 10:59am
Haha, very good
10 May 2015, 11:12am
I suspect that what you see is WCA's complete toolkit: hammer, three sockets, jack, screwdriver and scythe!
It does explain why some of the carpentery work we have seen was lacking in finesse, but a testament to ingenuity to be able to build a whole kit car without spending half the build cost on tools.
10 May 2015, 5:19pm
That tool kit help me fashion the wooden axle stands you can see holding the car up!
Anyway. All nicely lowered and definitely lower than before
Okay, there was some slight wheel rub issues but I liked the stance
now how to keep the ride height the same but stop the wheel arches rubbing? Easy with an angle grinder, just remove the wheel arches
Problem solved!
Looks ike my trolley jack will be getting less use from now on
10 May 2015, 5:38pm
Good job. I should imagine a little more trimming of the splash guard will be needed to allow suspension travel. Talking of which, what's the ride quality like now?
10 May 2015, 5:51pm
Looks good! I have TaTechnix coilovers on my mx5 and they're really quite comfortable compared to the Eibachs I had on my Rx8!
10 May 2015, 5:54pm
The quick blast I went for first showed they rubbed but a rerun after the angle grinder showed a reasonable ride and no rubbing. I will stick it on the ramps in a few days and check everything is still tight and then have a proper play
10 May 2015, 6:23pm
it's a bill hook...
10 May 2015, 6:29pm
I wasn't going to correct him but you are right. Bill hooks are an underrated tool and should be in every motor mechanics tool kit
11 May 2015, 11:51am
garyh wrote:
it's a bill hook...
Thanks, I stand corrected.
I've seen neither a scythe nor a bill hook used to work on a car.
11 May 2015, 11:53am
Have a look at WCA's inner wheel arches...
13 May 2015, 10:13am
Hmmm, nearly got stuck straddled across the speed bump on the entrance to a clients car park this morning. Perhaps I will raise the front another cm.
13 May 2015, 12:03pm
Maybe a pick and shovel should be included in the tool kit!
14 May 2015, 3:54pm
Hey dsg. Have a look at a Maserati a6g53.
14 May 2015, 4:33pm
Same as AndySharrock - I building up the parts ready for the build. Not as exciting as his
Some bonnet pins
and i am guessing this contains bonnet hinges
Beaulieu autojumble this weekend so need to think what else I will need.
Head lights
Indicators
Side repeaters
Grille - probably get one from Tribute if possible
Driving lights for in the grille
That's about it I think!
Do need to design a spare bonnet holder for the garage and some way to easily fit and remove the bonnets when swapping them over
16 May 2015, 7:00am
Head lights
Indicators
Side repeaters
+ Chrome headlight rims
+ Bonnet pins
+ Wiring for the new bonnet
+ Connectors to allow all bonnet wiring to be disconnected easily
