Mystery misfire
4 May 2015, 7:32pm
Ps. While changing the coil I slso pulled all the plugs. They were all text book perfect..
13 May 2015, 7:32am
An update!
Following a suggestion from Brian Moooore of E30Zone fame I checked the connector, in the engine loom, for the injectors. Apparently, due to the location, these tend to suffer from corrosion due to electrolytic action. This is inconviniently sited under the inlet manifold. A real pig to get to on an E30 I would imagine but on the Sportster it just meant removing the bonnet side and the AFM. Of course it was 100% perfect....
But - I did find evidence of a water leak from the pipes that heat the manifold that could well have been dripping on it. I sorted this out and went for a 40 mile run. It was perfect for the first 35 miles and then the problem re-occoured albeit not so bad as it has been before.
So - I now suspect the problem may be an accumulation of several small issues. Next job is to move the coil which is currently sited just behind the rad and gets cooked both by the air through the rad and the close proximity to the exhaust manifold. But where to put it? Can any other of the Sportster builders remember where they put theirs? I had thought of moving it right back to the top of the bulkhead but this would mean a new, longer, HT lead.
Cheers, Robin
PS. Does anywhere know where I can get a new, orginal spec, coil at a reasonable price? Bosch or Beru both seem to be an arm and a leg...
13 May 2015, 9:13am
I put my coil on the bulkhead for that reason, it was either next to the dizzy, right next to the rad, or the bulkhead with a longer HT lead, given the HT lead I had was ample long enough and had been shortened by tying knots in it (by the PO I hasten to add)...
To try the solution would be very cheap, a long HT lead, perhaps a couple of quid, and some tie wraps to hold things in place to test it? It it works fine, easy to try. May not NEED a new coil in the short term. The coil I'm using must be best part of 40 years old, it runs the V8 faultlessly.
13 May 2015, 7:00pm
This is where my coil is:
The injector loom plug we ended up completely changing as the connectors were a bit rotten.
14 May 2015, 7:18am
Thanks guys.
8 Valve Ed - good advice!
Patrick. Intersting that your connector was rotten. That's exactly the problem described by Brian Moore. Good location for the coil. Unfortunately my air filter is there! I think it's going to end up on the bulkhead.
Cheers, Robin
14 May 2015, 8:29am
Keep us posted, will be good to hear when it's sorted and what actually fixed it.
17 May 2015, 9:39am
Just a thought but have you checked the "tea bag" pick up filter in the tank.
If this is blocked you will get the same sort of fault. It will tick over all day but once the pump gets overheated through the extra effort it will stop, wait 10 minutes and off you go again. This was gained through experience.
My apologies for the interjection.
17 May 2015, 5:55pm
Thanks for the input Phil. There is no filter in the tank - its external :-). But there is always fuel in the system so I dont think its a filter problem.
This weekend I moved the coil to a cooler location but too soon yet to see if this has made any imrprovement. To be honest I dont think this is the problem but it's another thing eliminated from the equation.
Cheers, Robin
17 May 2015, 6:21pm
I'm surprised that there is no filter on the pick up pipe in the tank, is the external filter before the pump?
The only other thing I can think of is the fuel regulator or the fuel return line being blocked or faulty, but it's an outside chance.
Phil
18 May 2015, 7:30am
The Marlin fuel tank is pretty crude. It doesn't even have any baffles. But there is a filter before the low pressure pump and another (actual BMW) one before the high pressure pump so the fuel is well filtered.
I wondered about the fuel pressure regulator but its a simple device and I would imagine it fits into the catagory of either its working or its not. I can't see how you could get an intermittant fault. Fuel return line is a straight run back to the tank and is made from (new) 8mm cunifer so unlikely that it is blocked.
Nevertheless all ideas welcome! I just need to wait for some warmer and dryer weather again now to see if my previous changes have made any difference.
Cheers, Robin
18 May 2015, 9:48am
How about the fuel pump relay opening and closing when it gets warm, or the possibility that the spade connectors have pushed out the bottom of the relay socket. Do you have anyway of checking fuel pressure when it immediately conks out? Have you blown any fuses on the fuel side of things lately.
How about resetting the throttle position sensor, because the TPS values are programmed in the ECU sometimes after a lot of use the TPS goes off a bit due to wear. If you turn the ignition on (do not start engine) and press the throttle pedal fully up and down about 10 times, then turn the ignition off, finish drinking your tea and after a couple of minutes start the engine. All this does is give the ECU a re-valuation of the TPS.
I'll keep thinking!
Phil
7 Jun 2015, 3:55pm
Did a round trip of 70 miles today. Ok for the first 30 and then a breif reocurence of the problem and then it went away. However on the way home it came back big time and at one point I didnt think we would make it....
I have fitted a fuel pressure gauge and that told me the fuel was fine. However I now have another clue. This time I watched the rev counter. Each time the misfire appeared the rev counter started moving erratically. (Over reading....) The rev counter is driven dire tly from the ECU as I recall. So next thing to do is change the cpu i think. I have a spare somewher purchased just in case.
The saga countinues.....
Cheers, Robin
7 Jun 2015, 4:31pm
I'm sure you must be aware that electronic ignition coils and points type coils are different. It was earlier in you posts that you mentioned your V8 ran well on the coil that you are now using on the troublesome engine. An ordinary coil will run an electronic ignition set up but very poorly. The electronic coil stays "charged" all the time, where as an ordinary type builds up to the charge and releases when points open. You can get a Lucas electronic coil for about £20 I've got one on my EFi, but if you do a lot of google searches about coils you will get to know what I'm going on about.
Phil.
7 Jun 2015, 5:34pm
Well the spare ecu I have is a wrong un. I'll have to look again. In case anyone has one lying about the part number I need is 0261 200 173.
I did have one other thought. I would be intersted to know what the forum thinks.... These problems all started after I replaced the alternator (over 12 months ago now). I wonder if there is any chance of a dodgy alternator interfering with the ecu. Certainly must be a theoretical possibility....
Cheers, Robin
Ps. I am using acoil designed for electronic ignition!
7 Jun 2015, 5:54pm
I suppose if the alternator isn't working at its best and failing to charge the battery properly, the engine will be running the battery down slowly perhaps to the point where there's not enough energy for a good spark. If you don't have a voltage gauge on your dash I guess you could run the car with some fly leads to a multimeter in the cockpit and see what's happening over the period up to when the problem occurs.
It may be worth sticking your head lamps on as well when the problem happens to see if the extra drain makes it worse.
7 Jun 2015, 8:27pm
I don't know if this helps but, on my EFi the wiring loom from the injectors has a diode in the wire from the injectors to the ECU, this is to stop any spikes in power from upsetting the ECU and the wires from the Hall effect dizzy are all screened, and I have wrapped them in foil tape. My diode started to break up causing it to misfire, a trip to Maplins for a 20k diode (60p) and some ally sticky tape and bingo job done.
The ECU is susceptible to interference so a check on your alternator may be in order. I know of one example of a very expensive hand built British car that would conk out every time the guys mobile phone rang when he was driving in France (he lived there) when the car was returned to England no problems could be found, and as soon as It went back, problem every time the phone rang, this was 15 years ago but it shows there can be a hidden problem.
This is one reason why most engines have an anti knock sensor in the block as it picks up bad ignition (pinking etc.) which can be picked up by wires and ECUs.
Phil.
8 Jun 2015, 7:38am
MMM.
ECU s generally have over voltage regulators, and it will throw a code.
Depending on the age as to the sophistication of the fault software,it maybe to old for missfire history.
disconnect a plug lead and see if it throws a code in.
Hint If it has no code you look for something that does not log.
EG rotor button
fuel pump
plug leads
What it will log is things like AFM, TPS, crank cam sensors bla bla bla.
It wont log if its not in the soft ware, so induce a fault by pulling a lead and that will tell you if it should or should not log a code on a secondary ign missfire.
If it where me, I would go for a drive and take an inductive timing light with you.
When it starts to miss put the pickup onto one lead at a time and look at the flashing light.,
If one is not firing it is related to that cylinder, then go on from there.
If it is all then move it to the coil lead, if this is ok then it is the rotor button.
To test a rotor, pull the cap off, pull the coil lead out of the cap and hold it about an inch or so above the rotor button, get some one to crank, if the spark is bright and jumps onto the button and goes to ground through the shaft it needs replacing.
One other thing if it has an ignition module put the timing light on the coil lead and then load it or put it into D, if the timing light goes out and the car stalls it will most likely be the ign module.
I am a mechanic, if it is running as poor as you say then you need to gather evidence see if it is all or one.
Jim
8 Jun 2015, 8:32pm
Cheers, Robin
Hi Robin,
sorry to hear you still having issues.
I think the Rev counter erratic behaviour is just a symptom of the misfire. Mine was very sensitive to noise and I suspect it's just picking up a lot of erratic pulses from the mis-fire. Sorry, I don't have any spare ECU's as I've now sold most of my e30 spares.
Whilst it could be a high temperature failure inside the ECU (dry joint or cracked PCB track) I still think it will be an input from a sensor that is driving the ECU crazy.
I guess the good news is that you have eliminated the fuel supply so can focus on the electricals.
I'd start with the cheapest things first and work your way through some simple things. You've changed the crank sensor, fuel pump and coil so those can now be assumed to be OK. I doubt it's the alternator as I think if that was faulty your red charging light would be coming on and I think you would have noticed that.
We are also looking for something that fails when it's hot and then 'cures' itself when it cools down? hhmmm.....:ranger:
I think you said your plugs looked OK, but no harm in changing them all, just in case and to eliminate them.
Are your plug leads the original set from the donor car or did you replace them during the Sportster build. If they are the originals, I would invest in a new set but if they were new then leave those for now.
As Jim suggested, I think the rotor arm is worth replacing but try to get a good quality one. Personally, I wouldn't bother testing it as Jim suggested, I would just swap out the old one.
Water temperature sensors are notoriously unreliable. Usually they causing hunting or over fuelling but again worth a try as an intermittent failure might just be confusing the DME.
Throttle Position Sensor? - another fairly simple inexpensive sensors to change. Again, intermittent failure may be confusing the ECU/DME.
Finally, (for now) as your last failure was almost fatal, it may be worth another go with the code reader to see if anything has ben stored but I think the last time you tried it didn't have any codes. (Note to Jim, these early e30 BMW's had very limited code storage capability as it was pre-OBD I )
Good luck,
cheers, Peter
9 Jun 2015, 7:45am
Peter - thanks for your thoughts. All input is useful.
The plug leads are like new. I don't remember if I replaced them or not but they are certainly not 30 years old! I changed the main lead to the coil when I moved it (it needed to be longer). The rotor arm is also new as I recall - but you are right - this is a cheap and simple thing to replace - so it will be next on my list.
I checked the temperature sensor some time back - it was fine. Even if it had an itermittant fault I cant imagine it would produce the extreme symptoms I am getting. Worth changing the AFM though. I have a spare somewhere I think...
The missfire itself is odd. It starts off as a small reduction in power - I guess it is just missing on one. This comes and goes for a few miles getting progrssively worse. I guess missing on more and more cylinders - its difficult to tell from behind th wheel. Evantually it gets so bad that there is not enough energy to move the car! And it sounds like a tractor. Strangely though there is never any backfire.
The reason I am suspicious of the alternator is that I changed it just before the problem started. Of course it may just be a coincidence. I was wondering whether it could be generating some spikes that are interfering with the ECU.
I have sourced an ECU - it should be arriving in the next few days. But before I swap it you are right - it would be useful to try reading the diagnostic codes again.
Cheers, Robin
Edit. I hadn't thoght about changing the throttle postion sensor. Is it just a switch or is it a pot - does anyone know?
9 Jun 2015, 8:37am
You are right in thinking it is a potentiometer. You can reset them very simply, because the values of tickover and flatout are already programmed in the ECU you can re-learn the ECU to read the TPS by ,
1. Turn on ignition.
2. Press throttle pedal fully down and up quite quickly about 10 times should do it.
3. Turn ignition off and wait a few minutes, or finish your tea!
4. Start engine.
The number of times you press the pedal varies with different cars, some more some less, but I find 10 is about enough. At resting position with the ign on the TPS should read 0.4-0.5 volts or thereabouts, if it reads 0 volts it is dead.
Phil
9 Jun 2015, 9:57am
You are not thinking it through.
You scanned and none of the sensors came up as an issue, you have to trust that and move on.
An ECU will throw an internal error code or a bunch of codes that make it a liar.
If you think its an alternator then when it starts to missfire remove the fan belt if its causing any RF then that will prove a point, if it aint turning it should not be an issue.
I assume the alt is charging and battery is full.
I would be very surprised if its an ECU.
Only time I have seen BMW ECU fail is water.
Is this engine fitted with an ignition module.?????
It sounds like an ignition module because that will cause the rev counter to flick,the counter circuit is linked to the ign coil primary circuit, and so is the module and the primary side of the ign coil.
And also will stall when put under load because the circuit is failing.
Ign modules are matched to the coil, I gather you put a different coil on it (from the auto store) non BMW this can cause the module and or coil to fail if there is a miss match.
Before you do anything you should change the coil and module.
You said the coil is new but if not suited to that module they only last a week or two.
Why did you change the coil originally ??????? was there a problem.
jim
9 Jun 2015, 10:27am
jim
Thanks Jim.
Removing the fan belt can't easily be done as it also drives the water pump. However I had thought about putting an isolator switch in the alternator output so I could easily disconnect it as a test.
There isn't an ignition module! Motronic 1.3 drives the single coil directly - sparks are then routed with a conventional distributor. I changed the coil as it was a simple thing to do and it's orginal location meant it was getting cooked by the exhaust manifold. The replacement coil is for electronic ignition so it should be fine (and now on the bulkhead so cool as well...). But of course it hasn't made the slightest difference.
The "funny" thing is I used to be an electronics engineer fault finding on control systems far more complex than this. I was good! Which only makes my lack of success with this even more frustrating!
Cheers, Robin
9 Jun 2015, 11:51am
The other thing I have struck with these is the cam sensor cable was falling apart and shorting.
Whe I said disconnect the belt its only to see if the miss goes away, not till it cooks.
The problem I can see is lack of equipment to confirm, ign scope ect.
Jim
11 Jun 2015, 9:20pm
Robin, having made my first journey with the Berli, and suffered with a heat related refusal to start, I thought of your issue.
Might it be related to ethanol? I am guessing your engine isn't the latest, perhaps an early fuel injection unit, I don't 'know' the BMW engine types so please excuse my ignorance but I wonder if your problem might be related to vapour locking? On the face of it that seems to match the symptoms you describe, it won't lave a fault code and self corrects once the engine has cooled.
At least worth a thought?
19 Jun 2015, 8:12pm
I had thought about a vapour lock. But I recently put a pressure gauge in the hp fuel line which indicates all is well on that side.
Last weekend I replaced the ECU. Interesting result. The missfire is worse! All I can think off is that the missfire is being caused by interference and the new ECU is more suseptable. Hmm....
I have reinstated the BMW check engine light. It's flashing madly indicating a problem. You are supposed to be able to read the fault codes using it and something called the stomp test - but I havent been able to make thst work.
I am going to try running without the alternator tomorrow. It seems I just need to remove the charging indicator lamp which provides the excitation current and the alternator ceases to err alternate....
