Navigator Turnkey build 001
30 Jul 2013, 12:40pm
TK1 progressing well. I usually untangle the wiring loom before body fit so I can arrange the rear part of the loom to the frame. Don't you just love it when the washing dries so quickly :biggrin:
The rolling chassis has now been readied for body fit with Radius arms fitted, compensator lever mounted and floors fully bonded on:
Temporarily placed the seats in and marked out the line for the Steering column:
Fuel tank fitted now and all bare spots of the chassis and frame have been painted/treated where necessary:
Prior to fitting the shell, I marked out a possible outline for the luggage compartment which will be bounded by aluminium floor and sides to the rear frame:
As this car will have removable humps, it's quite possible to use all of this area but until we have a pair of newly moulded Left and Right hand humps, I won't be cutting it out.
With the shell in place, we thought it time to try the bonnet for approximate fit:
Which, bearing in mind it currently rides high due to having no engine and that it will ultimately be fitted with 14" wires, it looks pretty good.
As an experiment, we also tried the Pilot bonnet for fit:
I'm now up to my armpits in GRP mat and resin attaching the body so it won't be long before we get the cockpit lined with 9mm ply. More photos when that is done. Now where was I? Oh yes... Kettle's boiled :tea:
3 Aug 2013, 8:42am
Can't wait to get it!!!
A lot of progress, everything is going on quickly!
Pilot bonnet will be fitted finally.
5 Aug 2013, 6:07am
AndyP57 - Looks like lots of good progress going on there. :cool:
I'm looking forward to seeing how the front bulk head develops.
I take it there will be no clearance issues between the pedals and the "flat" front foot wells?
Good luck & keep the photos coming, Paul. :)
11 Aug 2013, 8:09am
A little slower this week caused by my having to be on the road but the cockpit is now lined and the wiring loom is modified (Excess functions taken out and instrument wiring clustered to the centre. I have, however, been shopping whilst away so the box o' bits grows ever more.
We now have a pair of the ubiquitous bucket seats and a full set of rear lights. Headlight buckets have arrived and have a pair of LHD P700 lamps are on order. Pam has specified a particular shape for the front indicators and as we should be at the Donington show, I should pick a pair up there. This week we should see a Canley's Mark 9 Gearbox conversion kit pop through the door so we can work on the power plant. (We're keeping that away from the car at present so it doesn't get enveloped in the usual clouds of dust and GRP).
Plan for this week is to get the steering column mounted (With a bit of design work for the bolt on support structure) and pedals/master cylinders in. We should also get the front wiring loom strapped in place whilst the bonnet is off. Seat mounting holes should be finalised and the dashboard should start to take shape.
More photos soon :biggrin:
30 Aug 2013, 8:30am
It's been a little while since we posted photos but the build has been ongoing. We've initially mounted the pedals (Paul, you will see that there is a good 25mm clearance between the pedals and floor at full travel):
and positioned the steering column with an initial mount being directly to the forward frame. An additional mount will be fabricated nearer the Wheel and is currently being sketched:
The cockpit has been lined in the traditional way:
and Rear light set fitted (Landrover Defender lights):
As seen elsewhere on the forum, the Navigator hump set has now been modelled and will soon be moulded. The reduced length and improved spacing will accommodate the boot:
More soon :biggrin:
30 Aug 2013, 12:34pm
Looks like it is all coming together nicely Andy. :cool:
I think all the improvements will make a better kit & an easier build.
Will be good to see a complete car on the road.
3 Sep 2013, 8:10pm
Good progress on the car Andy!
It's now time to speak a bit more about this project from my side. After a few discussions with Andy we thought it could be a good idea and a really nice wink to give a "modern colour scheme".
I'm working for a French motorsport team and we are running some single seater (GP2 and GP3) and Mc Laren GT3 in different championships. Here is a picture of our workshop :
The Mclaren color scheme would have fit properly to the Navigator so I did a few photoshop to try to it on the car:
I'm still a bit not sure about the final color even if the red looks stunning so I wanted a feedback from other builders (even if you do not like it). :eusa_think:
I hope being able to do some historic regularity rally with the car next year. :eusa_dance:
3 Sep 2013, 8:29pm
I rather like the white with the red graphics but the red looks good too. Either way it's going to look pretty darn good. :)
4 Sep 2013, 7:35am
The white looks stunning :eusa_dance:
Can I steal it for my project???
4 Sep 2013, 7:45pm
Love the single sweater hanging on the wall in the workshop photo
4 Sep 2013, 7:48pm
No Sweaters to be seen. Do you mean the single seater? :biggrin:
4 Sep 2013, 8:36pm
Oops I pod and bloody predictive text
I'll leave it as is to give everyone a chuckle
17 Oct 2013, 3:16pm
As mentioned on another thread, Pam's car is currently in the Spray shop and will be photographed when it returns.
In the mean time, I've been working with the engine which has now had a good flush through and cleaned up externally in prep for fitting. we've also mated it with a Ford Type 9 gearbox so it would seem a good idea to show a few photos of that along with some notes along the way:
Firstly, research showed that there are various 'flavours' of Type 9 gearbox and the one that mates properly with the Triumph 2 Litre engine is the one with the long input shaft as fitted to the 2.8Ltr V6 Fords. These are starting to become rare but luckily I found a good one locally. The first job is (once separated from the Ford Bellhousing if purchased with it fitted) is to remove the input sleeve and gasket which is held by 4 bolts:
the extension is not needed so has to be removed (Angle grinder to the ready :biggrin:
This is then refitted with a new gasket and attention turned to the Canley's conversion plate. When aligned on the Triumph gearbox, you will find that 3 of the holes already line up but the remaining 2 do not. Holes must be marked and drilled for these, though Canley's recommend not drilling the one that potentially clashes with the Clutch Release Lever pivot. That's what I did, blanking the remaining bolt hole with a ground down bolt:
Once all required holes are drilled and cleaned of swarf, the plate is then taken off and bolted to the Ford Gearbox using the original bolts (If you don't have them, this one was fitted with 12mm, 1.5mm thread pitch bolts which may be difficult to find)
Next step is to bolt the bellhousing back on as before and reassemble the clutch in the usual way but using a Ford Driven plate (Supplied by Canleys)
Last step is to replace the existing Spigot Bush fitted into the end of the crankshaft with the one supplied by Canleys and sized to fit the Ford Input Shaft. Bolt the gearbox/Bellhousing combination to the engine and the next step awaits. Fitting it to the car (We'll cover that when we get it back but I have to measure the gearbox top diff gap to make sure I get the right prop shaft from Canleys. Chances are it will be the GT6 one)
As far as the actual conversion goes, it is far simpler than I thought it would be and results in a Five Speed box mated to a nice Triumph Six Pot!
17 Oct 2013, 3:51pm
Ooh, that looks posh. Will the gear lever still line up with the hole in the gearbox cover?
17 Oct 2013, 3:58pm
Apparently not, so I'll be waiting until it is fitted before deciding on the gearbox cover route. Also, as the lever is further back, the Handbrake also needs a bit of thinking.
24 Oct 2013, 11:35am
It's been a little while since we saw the car as it's been away to the spray shop but having received it back, resplendant in RAL3020 Red, here are a couple of shots. Note that the bonnet is still to be final fitted once we know whether it will need any bulges and the RH wheel arch has already been aligned with the body:
This morning we dropped the engine into the car (Dropped! Who am I kidding :icon_confused: with the extra length of the Type 9 gearbox it was wriggled in) so work can now start on gearbox mount and other systems:
Note the gear lever will be 5" rear of the original triumph one but still rests nicely in a good driving position:
Also, in the photo above, please note that we have been very careful to apply the necessary overspray :biggrin:
24 Oct 2013, 2:22pm
Are they the final wheels, as I like the hub cap look. :cool:
I see the bulkhead has a lowered battery tray & "cut out" behind the master cylinders.
Is that part of the new mould, or a build modification?
Good luck finishing it off, Paul. :)
24 Oct 2013, 2:31pm
Hi Paul,
No, the wheels aren't the final ones. It's going to be wearing wires when it's finished but these are just the standard Herald ones, painted red with 'Triumph World' hub caps. They do look rather nice though don't they!
A Story behind the battery tray that I've been thinking about for a while. As you know, we do have a mould for a GRP tray and can turn them out for £15 but, always on the lookout for repurposing stock items, I happened on a non stick meat tray in Asda for a couple of quid that looked about right. Some very minor adjustment and fitted using Sikaflex has the tray you see here. I probably shouldn't mention it as it will affect (Stop) sales but hey! A good idea is a good idea :biggrin:
As you can see this car is a 'Left hooker' and when I mounted the master cylinders I found the ones I had purchased (Not originals) slightly fouled the bulkhead. I could have just ground a little away (it is only a couple of Millimetres) but felt better building a little box behind it and sealing it up. When I get round to it I'll drill a drain hole through the bulkhead so it can't fill up with rain etc.
Glad you'r liking the build. There were a few minor delays here and there but it's full steam ahead now.
25 Oct 2013, 8:00am
The boot looks neat and level!
25 Oct 2013, 11:33am
Thanks Gary, the rear does look neat and we're not fully decided on the retention method for the boot yet. The front, however, is where we're currently working to find space for that whacking great engine under the bonnet :biggrin:
25 Oct 2013, 11:37am
Looking good, almost 32,000 euros worth I would say!
25 Oct 2013, 12:02pm
AndyP57 wrote:
... we're currently working to find space for that whacking great engine under the bonnet :biggrin:
No problem, you just need to cut a tiny vent into the top of the bonnet -
You could fabricate a small scoop to keep the rain out or just run it as it is :)
25 Oct 2013, 12:04pm
Actually, whatever sensible option you come up with for the bonnet, it might be an idea to take a mould from it and offer it as the six cylinder option. Just a thought.
25 Oct 2013, 8:52pm
The master cylinder tower with the reinforced web should be on the brakes and not the clutch.
