Another Sammio - Vitesse 2ltr
15 Jul 2013, 8:42am
Thats a very good suggestion, i will definitely do that as i don't want it too stiff and its considerably lighter than the original car. Thanks for the info :-)
see without my service hatch that would be a right pain :-)
18 Sep 2013, 5:20am
Hello Cabage,
If you went this far with the service hatch (which looks very good), it wouldn't be a great problem to convert it into luggage space I suppose. If you fabricate some sort of basket you can hang in there, you are there. Ultimately it needn/t to be watertight. Just wrap the luggage like on a mototbike. Usage of 4 bonnet pins will do the job to (re)place the hatch.
18 Sep 2013, 7:50am
yes your right there, i will probably lay a floor in the boot so i can place bits in there and some hooks so i can strap stuff down. :-)
21 Oct 2013, 10:50am
A late and rather feeble update, but an update none the less.
There has been a lot more progress than is visible, the cabin is now completely enclosed and im sorting bodywork, designing the dash structure and how i shall line the cabin.
You'll notice i removed the old battery holder, this will be replaced with either a clamp down box with all eletronics inside like an old jag with the Li battery inside, oooor the electronics will be more exposed as original with the Li battery in a bracket on its side, so we shall see.
the whole bulkhead and cabin are silver, rather than cream as the silver is nice and neutral and im no longer sure what colour i shall paint it, so this allows me to progress without having to make that choice for a while.
The exciting stuff now happens as i start putting in the seat rails, seats, harness and various cabin decorations that will make it really look the part :-)
21 Oct 2013, 2:40pm
Love the folded aluminium ... looks great: another idea to steal ....:spy:
When I get to that stage.
Keep up the postings.
Slarti
21 Oct 2013, 3:03pm
Thanks Slarti,
Its good fun to work with and makes the car very rigid at the end of it, just takes a little patience to get used too. :-)
21 Oct 2013, 4:26pm
cabbage - Your bulkhead could pass for factory. :cool:
21 Oct 2013, 6:08pm
Yes, it does look really slick. I cobbled mine together with everything in situ and it ended up as a bit of a patchwork quilt. It's one thing I'd do differently if I built another. Keep up the good work.
21 Oct 2013, 6:27pm
Cabbage.
I just fell in love. With you bulkhead!
What are you? Some kins of sheet metal worker?
Michiel
22 Oct 2013, 7:27am
Thanks guys :-)
And no Michiel, im not a sheet metal worker, it just takes a little experimentation , a good bench and a rubber hammer :-)
22 Oct 2013, 8:25am
Very nice work. I enjoy seeing builds that move away from the normal (if there is such a thing on a sammio/Ribble) and like to see builders use there imagination to get a personalised car just for them.
Good work.
Is that a 944 I see just outside the garage?
22 Oct 2013, 9:07am
Thanks Gaz :-)
and yes, it is a 944, or a 87' 944s to be exact, i have a 83' 944 as well which is my daily driver.
22 Oct 2013, 4:37pm
cabbage wrote:
Thanks Gaz :-)
Very Nice. I have been looking at 944s myself recently and I am giving serious consideration (read trying to get permission) to buying one as a semi-practical weekend toy, or more accurately, a semi-practical whenever Im in the UK toy. This will compliment my own Ribble build which is very non standard but there will be more on that in the near future.
22 Oct 2013, 9:13pm
I can't see either of these getting the green light before you buy the mrs a new house:wink:
On the plus side of buying a house is that you can choose one with a double garage:icon_lol:
23 Oct 2013, 8:15am
Hi Gaz,
Yes 944s make a great weekend fun car and are so easy to maintain and reliable. If you do ever get permission give me a call as i sell / source them so could help you out :-)
29 Oct 2013, 9:01am
A couple more minor updates, drive shaft tunnel fabrication, and yes i will remember to cut a hole for the hand brake. :-)
29 Oct 2013, 9:37am
Wow, that's nice and shiny. Makes my discarded piece of grey guttering look like, well, a discarded piece of grey guttering.
Keep up the good work!
29 Oct 2013, 9:42am
It is rather shiny, its almost a shame to paint it, but i think i will have to in the same silver as the rest of the cabin, it will then be trimmed in quilted leather but i have yet to decide on colour. :-)
3 Dec 2013, 2:39pm
I see, said the blind man... i think we're due an update, so if you could supply some close ups that would be helpful. Once i get to this stage i was going to make round discs on posts that could be welded to the frame with bonding paste on disc stuck to body?
3 Dec 2013, 2:58pm
Sure :-) i'll get on to that tonight as there has been a bit of progress since :-)
The main areas i attached the body were
1) Alu sheeting around the bulkhead, this is composite bonded and riveted to the front of the body all around the front lip.
2) the top of the sides where you get in and out are riveted and bonded to the alu tub sidewalls.
3) the rear of the cabin, tob and frame are sandwiched, bonded and riveted in place.
4) aluminium brackets stretch from the fuel tank supports to the body either side of the access hatch. The load is spread via alu strips which are riveted down each side of the rear.
5) semi-circular alu plates are riveted and composite bonded to the outriggers, these mat up perfectly to the isdie of the rear body, stopping any vibrations, this gives enough support to sit on quite easily.
Tips)
1) I use rubber seals along any sharp edges of aluminium which are not bent over to avoid rubbing and damaging the body.
2) I use composite bond from a mastic gun style tube on all surfaces where the alu, fram and body meet to absorbe and vibration and avoid fatigue from the rivets, its very very strong stuff.
3 Dec 2013, 5:09pm
Can you let me know what the mastic is called. Ta.
