Good luck getting your hybrid gearbox back together again. I guess you'll only really know if you've got it right when you put it in first and dump the clutch...
Another suggestion might have been to look at the ford type 9 5 speed gearbox conversion from jigsaw racing..
gearboxes are one of those things that always seem mega-complex, but latying it all out and taking loads of pictures as you go should mean it simplifies the assembly!
So, potentially a lot of progress this weekend but I fear its all going to be 2 steps forward, one step back (as Paula Abdul would say)...
Both gearboxes are now stripped and I think I have the parts I need to rebuild one mega box over the weekend. With a bit of luck i'll have 4 forward gears and one reverse at the end.
Engine stand has been purchased and an adapter plate been made similar to this one so that I can mount onto the side engine mount. I wasn't too keen to hang 200kg+ on a few 5/16 bolts at the back of the engine!
Whipped the head off my engine in excited anticipation of getting to work on it (forgetting that I had a gearbox in pieces to put back together first). Hmmm, milky oil in a couple of the cam followers and water where it shouldn't be. Not a major issue at the moment as I'm planning to strip most of the engine and replace where necessary. I would like to avoid re-machining and so far it looks slightly feasible as the bores are in very good condition. We'll see what the sump pan reveals tomorrow!
Paul - I don't think the 'cut' is that bad or even necessary. Time will tell when the body finally meets the chassis. Much admiration by the way - building a car outdoors is not something I could imagine entertaining!!!
Anyone got any advice on clearing out the water jacket in the head/block. They are jammed full of crud (perhaps the reason for water where it shouldn't be!!!)
Making sh!t and preparing sh!t for our wedding is taking over nearly all of my time but just before it got busy, I managed a day in the garage. Engine on stand, head off, sump off, fluids drained and all seems to look serviceable. Sat looking sorry for itself but it will soon look good after a good scrub and a few new parts. Photos soon.
The gearbox rebuild was a little less straight forward. I replaced a few parts with new, especially the main shaft tip bearing as that was packed with swarf and had started to collapse. Looked like a poor quality replacement. The cranleys replacement that I fitted was much better. Rebuilding was painful and involved a few hours of assembly and dis-assembly. The Haynes manual just isn't right for the gear clusters that are fitted in my gearbox.
Regardless, it went back together in the end and all seems fine! 4 forward, 1 reverse. 4th a bit clunky but I think that's just to do with the synchro hub springs being a bit stiff. Has more of a race feel getting into 4th. All bolted back together ready for some oil and probably a rebuild as soon as it sees and load!
[/URL]
Plenty more photos to follow soon. Hope you are all having fun building or for a lucky few driving in this glorious weather!!!!
So i've not made a huge amount of progress over the summer as I've been busy getting married and honeymooning. Even so, managed to squeeze a few petrol head related things into both - the wedding car, a 1969 Porsche 911 and the honeymoon car, a 4L Mustang...
The past few weekends I've been stripping down the engine and I'm glad that I did in the end as I found some problems that would have bitten me in the @rse after a few hundred miles.
The rear crankshaft thrust washer was installed back to front so was running metal on metal. the result of this is the crank thrust face is damaged. I don't think its beyond repair so I've sent it off to a local machine shop today to be refaced. I might need some custom thrust washer made up but at least I'll know it will be spot on tolerance when its finished!
With everything stripped, I went to work on the block with some gunk and a pressure washer. The water jacket was really clogged up but not anymore. All painted up and ready to rebuild once the machine work is completed.
Before...
And after...
Before...
And after...
And some engine components...
There is one thing that is still confusing me. The main bearings on the crank are 2.3" diameter, not the normal 2". I did some research and though that I could have a TR6 crank in my engine but the stroke is standard for the GT6. I have heard that the bearings were increased in size towards the end of GT6 production (to bring them in-line with the TR6). Any ideas anyone?
Ha, yes Viatron, all the inspiration for the engine colour came after seeing your's! Its looks great and really period too. The plan is to have all the running gear black so its only the engine and gearbox casing in that colour.
Congratulations on your recent wedding Adam.
Engine seems to be coming along ... that's something I will be tackling later this year, but mine's only a 4 pot 1147cc.
Keep up the postings ....
Slarti
In the past few weeks everything has come together for the engine rebuild and although I'll have no idea if I did a good job for a few months yet, so far so good :-)
Cylinder head went away for a refurb which included a skim, unleaded exhaust valve seats and recut and seated valves. The crank was also had the thrust bearing faces cut to remove damage from the incorrectly fitted bearings. They supplied the replacement main, big end and thrust bearings too.
Over the past 2 days I've rebuilt and finished the main painting jobs on the engine. It was actually a lot easier than I'd expected with the main problems being stripped threads in the aluminium sealing block (which I'll repair later) and finding and knowing what bolt goes where.
At the end of today (in order) fit the main and thrust bearings and set the crank (its runs nice a freely). Re-fit the pistons with new big ends and set the caps onto the crank (still running freely). Fit the cam, timing chain, sealing blocks, front and rear engine plates, cam cover and chain tensioner kit. Then the oil pump, the sump, head studs and cam followers. Then the head, the rocker shaft (setting the tappet clearances) and then touched up the remaining unpainted surfaces. phew!
Really happy with the end result. I just hope it runs when all the ancillaries are fitted.
Next job is this beasty! I'll get her blasted before some hopefully minor repairs (the outriggers need replacing) and then I can start the rolling chassis and have somewhere to bolt the engine and gearbox!
