James Hunt's first races were in a Mini. At the first meeting he attended he failed to convince the scruitineers that a modified garden chair was a race seat.
Alfa seats?? Not good - they look great and will handle well but will break down every other weekend...
Tut tut. You really shouldn't go stereotyping on the basis of national characteristics. That's what they do in Russia...
The alfa seats look very nice. The backs might be a bit wide though, I'd check the dimensions. You might get away with using them if you fit a low profile prop tunnel, don't lower the floors so you can fit the seats as far inboard as possible, fit the squabs quite a way forward and fit the backs at a shallow angle. That'll give you the long arms, short legs driving position known as 'The Italian Ape' (which I find quite comfortable) and have you sitting as low down in the car as possible. If you fit them right at the back you'll be sitting bolt upright and your bonce will be sticking so far out of the top it'll create loads of unnecessary drag and you'll end up with a neck like David Coulthard's. Good luck, if you can get them to fit they'll look the business.
Ok, here's hoping someone may have bookmarked the web page I've been searching for after seeing it a while back. Some vendor in UK sells reasonably priced Aluminium 'Bomber' style bucket seats and I'll be darned if i can find them again. Any help would be really appreciated.
Don't recall seeing any reasonably priced new bomber style seats. I think the last ones I saw were about £900 each.
You could always fabricate some yourself, after all, how hard can it be? Remember hacking and bashing at Halton? Chalk on your file and fabricating pointless aluminium panels with 'D' plug holes to one thou tolerance, I knew it would come in handy one day...
I have to agree. Ideally, whatever seats you choose to fit, your shoulder needs to be only slightly above the edge of the cockpit so you're just looking over the top of the flyscreen (as modelled by my better half), otherwise your noggin will spoil the aerodynamics and the wind blast will deafen you.
