Am i mad to even be thinking about this
26 Aug 2014, 9:48pm
Well, we sorted the handbrake - needed shortening, so used the old "silver solder a nut onto the wire for a nipple" routine - works well now. helped him fix some minor niggles (indicator had wrong bulb, rear number plate light etc) - waiting for MOT now.
27 Aug 2014, 9:48am
good luck with the MOT fingers crossed :)
27 Aug 2014, 11:00am
Will announce results here :-)
27 Sep 2014, 5:47pm
Ok, so, now has an MOT. needed a new steering rack (turns out it is mk2, not mk 1 - very different threads on track rod ends, and tapers are very different - as we found when BiL took to the test - steering effectively just wobbled around on its own! But all done now. Fitted a new washer bottle - it had teh pipe work but no bottle. Got rid of massive air horns and he is to sort out column horn push. Back end is sitting off - drivers side is higher - so maybe a duff passenger side spring. Then next BIG issue os the overheating - clearly has serious issues. Need to get timing right, then carbs and then work through the heating system to get it right. Joys of kit cars.
But for me, my car should be with me next week subject to trailer hire etc, so it will be less Dutton for me, and more Miglia as I build my own car - wish me luck :-)
27 Sep 2014, 7:23pm
Duttons are well known for overheating, but its an easy fix, fit an electric fan, ,i used the thermostat housing from a fiesta as it contains a fan switch , and duct the area around the radiator, to ensure air goes through the rad, not round it simple sheet metal work on mine the rad is shroulded , and the air flow has to go through the rad, its the only way , it used to get very hot before, but now even in hot weather it will not boil the fan cuts in at 86 degrees
7 Oct 2014, 3:19pm
Still no response from the DoC though - BiL is a bit miffed that he paid his money two months ago and not heard from them since. Shame.
But my Miglia has arrived so probably won't update on the BiL's Dutton anymore - I have mentioned this website but he is not too computer focussed, so may not be much in the way of updates.
Hopefully though we will make a show or two in the Melos when the sun shines - see you fellow owners there :-)
7 Oct 2014, 3:40pm
Get him to contact Ade Southgate ,he's the membership sec, things are not very good with in the DOC at the moment , but Ades one of the best committee members
15 Oct 2014, 10:11pm
for anyone remotely interested in kit cars, ones making its way into soap land, a light blue Melos on corrie to be exact , it was filmed this week
