Paul D wrote:
I must admit I am having doubts about the measurements since it comes out on the on-line calculator as 60.3 cm total , but I can only make it about 58.5 cm in the flesh as it were. Paul.
I'd also wondered about the accuracy of the tyre size calculator as I found it difficult to physically measure the height of the wheels without access to a jumbo vernier caliper.
As luck would have it, before I found
http://www.kouki.co.uk/utilities/visual-tyre-size-calculator I used to work out the tyre size the old fashioned way, so for your 185/65/15 the calculation would be as follows:
A/ Convert wheel size to mm -
15x25.4 = 381
B/ Multiply tyre width by aspect ratio then multiply by two (for top and bottom sidewalls -
(185x0.6)x2 = 222
Add A and B together -
381+222 = 603mm or 60.3cm, which is what the calculator says.
Both methods assume that the tyre is
exactly 185mm wide and that the sidewall height is
exactly 60% of the width. There is a danger, however, that those dimensions are nominal and substantial variations due to manufacturing tolerances is the norm.
One thing we haven't considered yet is the effect the
width has on clearance. The original setup used 155mm wide tyres and we're all increasing this by between 10mm and 30mm.
You wouldn't expect this alone to make much difference but most of us are also increasing the track width by adding splined adaptors. This has the same effect on the front suspension geometry as fitting something like a 7" to 8" wide wheel, meaning the outside edge of the wheel scribes a much larger arc as the steering is turned. Sadly, the wider the arc the more likely the tyre is to foul on the chassis and/or bulkhead.
If you take a look at this picture of my MGB wires fitted to my chassis you'll see that the discs have ended up completely inboard of the wheels. With the Vitesse wheels fitted the discs are fully enclosed inside the wheels, so, although the tyres on the wires (poetry!) are only 10mm wider than standard, they scribe a considerably wider arc.
I hope all that makes sense and good luck finding a tyre size that works for you.
Oh, and I really like what you've done with the flexible conduit zip-tied to your frame to protect the loom. I'll be pinching that idea, thank you...
