Right, these aren't particularly accurate, as it's a tight squeeze in there now, but the distance from the pivot to the lower hole is about 50mm, and from the pivot to the upper hole is about 70mm
Jason
Thanks for these - mine are 55mm & 80mmso I think Marlin may not be consistent with their dimensions. You can imagine how hard mine was with an 80mm fulcrum!
However, you give me great hope, as I have already modified mine to the 55mm hole and from your account, it suggests it will move in to the acceptable territory.
Now, do I fit that helper spring or not...................................?
Mike
