Bit of an update, most of the fuel and oil hoses are finished now although it is a little tight in the engine bay now... solid engine mounts might be needed!
really it's whether they Q or not, I have 90% receipts for new parts and I have a reconditioned certificate for the gearbox but no receipt so it depends on how they see it I guess - plus 100+ build photos
Well, even though I didn't get all major components supplied by SC I still need a certificate of newness :/ plus even though the gearbox recon cert says "fully rebuilt and reconditioned" they won't accept it as it doesn't say "reconditioned to as new"
Hopefully I've spoken to the gearbox place and they are re-doing the recon cert/writing a letter reconfirming it being reconditioned to "as new" and I should be able to get a cert. from SC but it's just annoying and time consuming as I can only get to the DVLA on Wednesdays - but it looks like a new reg. will be going on it
Sounds like a good place to meet. About 2-3 hours away for me. It will have to wait until mine's on the road though. Might not be until late Autumn though. Purley financial. Car is nearly there. Just needs more than anything, exhaust and mapping.$$$$$
It's been a while since I posted an update, still not turned a wheel in anger - but with good reason, I accidently ripped out the old ECU and bought one of these:
Then I found I was up to by eyeballs in this:
Then thought "I should do this properly" so blew the budget on these:
Although still not quite finished, here are a few photos of the wiring loom in progress...
Each wire has been colour coded with heat shrinkable "idents" to allow easy diagnosis of problems and allow tracability throughout the system - it also allows you have 100+ different colour codes so you never have to have the same coloured wire twice
Wires all coded up, crimped and ready to be inserted into the connector
The motorsport connector (20mm diameter!)
Close up of the sensor ends of the loom
The engine loom ready for the sensor connectors
Just need to finish off the sensor connectors then there's 8 other loom sections to build!
Will do I think I'll save the wiring up of the digital dash for later once I've run the engine in as I'll be running it on the laptop during that time doing some road mapping
