Running reports
2 Oct 2008, 9:26pm
Mike wrote:
If you go back to page 3 of the Sportster/Cabrio there is a thread called "Unhappy owner". He has bought an M3 engine to go in his kit, but was looking to sell it. I know he was offered £3k for the engine gearbox wiring etc. Dont know if this is in the dream budget, but what a car it be..............:biggrin1:
Thanks, Mike, but even in my dreams that would be too much!
peter
2 Oct 2008, 10:13pm
There's a chap on E30 Zone selling an M52B28 crank and 130mm con rod. That plus a M20B25 and you'll have a nice 2.8ltr :D
Build it take the current engine out and your sorted for a winter project ;)
A quick call to Ant @ A-Tech and the ECU can be easily sorted for the higher capacity with a new chip.
Not sure on the power but should end up around or above 200bhp with a wedge more torque as well.
3 Oct 2008, 7:25am
Also seems to be someone selling a complete 2.7 engine - just rebuilt. Hmm
No - mustn't be tempted - must finish the car first.....
3 Oct 2008, 7:52pm
noooice engine :D The updated ones put out some where in the region of 340bhp :madgrin: Won lots of awards as well.
M54/S54 bring their own difficulties such as electronic throttle that you need to deal with. It's also a bit of an a issue with VANOS engines as I don't think megasquirt is up to dealing with variable valve timing yet which means stock ECU and EWS (but as I understand it its possible to turn that off).
There's a number of TVR V8's on ebay right now, they would awesome.
3 Oct 2008, 8:26pm
I seem to have really started something here....
Like Robin said, I really need to finish the car first and spend my money on getting it painted!
I was down at the Marlin factory (barn) today to collect my windscreen, hood frame, hood and to get some vents cut in my top bonnets.
So I now have lots to do!
Mark told me he is considering offering the Audi 2ltre turbo engine as an option on the Sportster which he reckons is good for 220bhp
3 Oct 2008, 8:49pm
:lol: your not the only one that needs to spend money on paint first tee hee. But it's fun to dream / waste hours on end looking at engines :madgrin:
I only did the engine rebuild at the beginning of the year due to the crash and waiting forever on new parts. Glad I did it as it was an interesting project never having taken and engine to bits. I'll be sticking with the M20 for a while to come yet realistically!
24 Nov 2008, 11:13pm
Mike wrote:
I did a lot of research into the engine options for my Cabrio, before deciding to go for the M50 2.5.
My decision was based on:
As relatively new design as possible
As efficient as possible
Electrically simple
Patrick is right about the M52. When BMW replaced the M50 with the M52they had to meet tougher emission/insurance regulations. They then had to increase the cc upto 2.8 to achieve the same power output as the M50 2.5
By simply changing the inlet manifold from the M50 2.5 on to the M52 2.8 will take the BHP up to 220BHP. These are advertised on ebay and I have seen them make £100 each. I have one which I may well sell in the future when I am sure my modification to my manifold has proven successful - we have to chop 75mm out of the manifold to fit it in the Cabrio - not sure if you'll have to do the same in a Sportster - I guess you may have to as ???? has a purple Sportster fitted with the M50 and he has fitted a special home made glass fibre elbow, but I think this is believed to restrict the air flow at the top end.
Have a look at my site on flickr to see the drastic action necesary to make it fit a Cabrio.
I chose not to go down the M52 route as the engine electronics are tied in to the cars central locking system and even the electronic key- so if you do go down this route be prepared to either adopt the entire M52 wiring loom, or make sure you know a good BMW electrician who can reprogram the chip to blank off the ingition switch, door lock sensors and all the others before the engine will work.
If you are prepared to take on the electronics of the M52 it should be a lovely engine with twin Vanos (variable valve timing on both inlet and outlet valves) the M50 has only single Vanos on the inlet.
Let us know what you finally decide to do, as this is really interesting.
Regards
Mike
Does anyone here know if the e46/M52 uses the same engine mounts as the e36/M50?
Also, any details of the mods required to the ecu or e46 wiring diagrams on the web?
thanks
25 Nov 2008, 12:04am
I'll see what I have on my CDs re: E46 wiring :)
25 Nov 2008, 11:06pm
thanks
29 Nov 2008, 8:49am
I found a wiring diagram cd that covers the E46, just sorting something out, will email you later :)
29 Nov 2008, 12:45pm
Hi Patrick,
thanks for looking but I bought a DVD off fleabay the other night,
29 Nov 2008, 9:10pm
New Engine!!!!!!!!!!!
Ok, so I've gone and done it. :madgrin: :madgrin: :madgrin:
I blame the weather as it's been too cold to finish fitting my windscreen and hood.
I'd been watching on eBay an M52 2.8 litre engine out of an 1998 e46 complete with all ancillaries and exhaust system.
It turned out the guy selling it was only 20 mins drive away, so when he listed it again for the third time and no buyers, I called him and went to see it. After about 10 mins I was stuffing crisp £20 notes into his hand and the deal was done.
My son and I went down to pick it up today and here is a picture just after we got it back in the garage.
there are some more pictures on my Flickr site here..........
http://www.flickr.com/photos/peters-bmwmarlin/
........just got to figure out the wiring now........:noidea:
29 Nov 2008, 9:20pm
very, very nice :D
30 Nov 2008, 3:37pm
Hi Peter
So - will that bolt straight onto the M20 gearbox?
30 Nov 2008, 3:58pm
It will bolt on to an M20 gear box will be at a different angle, should be possible to raise the mount on one side to compensate :)
30 Nov 2008, 7:58pm
One on Ebay at the moment
140284684840
1 Dec 2008, 10:33pm
Patrick wrote:
Bit more on that here: http://328compact.co.uk/index.php?section=25
With a remap it will be closer to 240bhp :)
Useful info, thanks.
Not sure about the gearbox yet. My e30 box was a very low milage 'box from crashed e30.
If I can pick up a 328i gearbox and I could sell the M20 box?
Lots of other things to ponder....
Do I need the cats and lamda sensors? If not, will it pass an MOT?
Do I need a new radiator?
Will my electric fan still fit?
Will I need an expansion tank?
Purge control valve??
Will I need to move/different alternator?
Will I need to put concrete blocks in the back to stop the wheels spinning! :madgrin:
And probably a whole bunch of other things that I haven't thought of yet....:wink:
2 Dec 2008, 7:51pm
As you have already registered your car, I would guess you do not have to fit the Cats: would this only be necessary if you declare the revised age of the engine? - however, the lambda(spelling?) sensor is linked in to the ECU, so could cause problems if you don't
Your electric fan will still fit - you have much more room in the Sportster than the Cabrio and mine is mounted in a similar way to yours
What radiator/expansion tank do you have now?
The alternator has to be moved to the opposite side in the Cabrio - Marlin make a bracket, but don't buty it !- you learn by experience - It does not work with the original BMW alternator, and is designed for a smaller Lucas item. I have altered my bracket to allow the original to locate on the oposite side - Despite what Marlin tell you there is plenty of room
You may have to either cut the manifold and shorten it, or make a new intake elbow. Marlin recommend cutting the inlet manifold - drastic stuff - as in their Demo car, and Chris Cunliffe has done this too. Andrew Curtis preferred to make a new inlet elbow for his Sportster - I have photos - I can post it on my Flickr site if you are interested?
I think you'll need alot more than the odd concrete block to stop the wheels spinning!! - What a hairy motor you are going to have!!
Do keep us informed on progress
Regards
Mike
2 Dec 2008, 10:34pm
Mike wrote:
Regards
Mike
Thanks for the tips, Mike. I've got pictures of the Lucas alternator mounted on the other side but like you would like to re-use the BMW one if I can. I don't fancy cutting the manifold. I think i'll get the engine in and then figure out what to do. Any more pictures would be useful, thanks.
I'm also going to try to re-use the cats if they will fit under the car as i'm not sure it'll pass MOT tests without.
I think I also have something called a Secondary Air Injection but I think that is just to reduce emmisons after start up.
Did Marlin suppy your engine mounts or make your own? I wouldn't mind a picture of each mount next time your in your garage with your camera. :wink:
cheers
2 Dec 2008, 10:52pm
As I understand MOT rules if you take a new car and put an old engine inside it has to pass old MOT standards - but you need to prove engine age.
You take an old car and put a new engine in and it has to pass the MOT standards for the original chassis.
Now here's the the one I'm not sure on, the Sportsters first registration date in my case is 2007. So is the chassis classed as old or new? It has an age related plate which would lead me to assume that the engine passed F plate regs, but then the date of first registration is only a year ago.
Meh I hate "grey" area's when it comes to this stuff.
2 Dec 2008, 11:16pm
Yeah and I bet you get three different answers from the DVLA/MOT station!!:noidea:
3 Dec 2008, 10:35pm
cheers
I have posted pics of Andrew Curtis's M50 Inlet mods in his Sportster on my flickr site. Although Andrew is happy with it, the racing fraternity believe the elbow restricts breathing at the top end - which defeats the object of using a bigger engine if you cant extract the full power from it?
Looking at richard & Patrick's Compact M52 conversion, I do not think shortening its Inlet manifold is an option as it changes shape along its inlet tubes length. Shortening the M50 manifold is much easier, and will give you the additional benefit of an extra 20BHP! - see my Flickr pics.
I will take some engine mount and alternator pics over the weekend for my M50, which I guess is very similar to the M52? - Perhaps Patrick knows better, but I have the impression the M52 is mechanically similar (bottom end & block) to the M50, except it has a twin Vanos head? - but could be wrong.
Marlin supplied my engine mounts - but like most things they make they could be improved - to use the original BMW rubber mounts - not the cheap Landrover units they supply. The BM ones are offset top and bottom, so you can rotate them to move the positioning of the engine in the bay-- very useful in a Cabrio as the engine bay space is much more limited than your Sportster.
regards
Mike
