Got the head back from the machine shop on Friday (the place in Southampton were very good and friendly (if a little bit odd), unlike the first place!), they took 4 thou off to remove the warp:
Starting a bit of valve lapping
2 down only 10 to go!
All the valves boxed up and ordered
Throttle body attaches here, its been ground a bit larger - more pictres to follow on that at some point
Valve springs - the larger one has shrunk 2mm over the inside ones and new springs.
All valve lapped in - a simple short sentance that will take you hours and hours, especially if you have pits on the valves like we did!
A nice mat grey colour is what your after!
The valves all have a nice mat dull finish on them as well.
Valve stem oil seals going on - a size 11 socket bit proves to be exactly the right size to push these in place.
One at a time the new schik valve springs go in, putting the colletes back on proved to be a very fiddly proceedure!
All springs now in place!
All cleaned up - the head needed a 4 thou skim to take the warp out of it.
