I'll come back to the petrol tank issue above in a minute.
In the mean time here is how my day went...
Saturday:
I'd ordered some Eye Bolts for the 3 point racing harness I am going to fit...
I knew they were the right size for the backing plates that I'd bought.
But when they arrived it dawned on me I wasn't sure if they would fit the existing Spitfire "holes".
So first job of the day was to test they were a matching thread & they were...
The second job of the day was trying to find the missing seat belt plate.
So half of the contents of the Summerhouse ended up in the garden...
But the good news was I found the plate and could move on to my next "search".
I knew I had a set of three funnels put to one side as they would come in handy.
Despite going through all the remaining boxes in the Summerhouse I could not find them.
I then tried the utility room & the storage area in the loft where other bits live, but nothing.
Then I got the sinking feeling that there were in the shed.
Sure enough, after pulling yet more stuff out I found them & could now empty the petrol tank.
I used an old tight as a filter (with my wife's blessing as they had a ladder in them)...
This was then shoved in one of the new jerry cans that I'd bought recently.
( I'll use the 2nd one to get fresh petrol when I try to re-start the engine. )
The big funnel didn't work very well, so I switched to a medium one.
But the tights were doing their job & I needed to move them around often...
I've already posted the photos of me trying to fit the tank with the seat belt brackets in place.
It has now occurred to me that having metal in front of the tank isn't really an issue.
The traditional Sammio / Ribble "getting started" guide expected the rear cockpit to be sealed.
So even if you hadn't got any metal in the way, the petrol tank is effectively boxed in anyway.
Therefore I feel happier that my approach will work for this build.
I am also planning to have some access to the fuel lines from the "boot".
I will also have an access panel to get at the fuel gauge sensor if required too.
More on the petrol tank later, as it was time to work out where the "side" seat belt plates would go.
There was a lot of beard scratching going on to come up with something that I could make work.
In the end I've opted for another of my over engineered solutions that will look like this...
I have to take a notch out of the box section where it meets another frame rail at an angle...
The brackets will go in behind the door cut out section of the frame...
I will add one last piece of box section to join the bracket to the frame in another stop too.
But for now, I have cleaned up both the box section, plate, & frame work ready for welding.
Here are the brackets for both the driver and passenger side...
Note two things:
- I've recycled the box section I cut off the frame last week
- The brackets are different sizes as the door cut outs are not in the same place.
As part of my test fitting, I tried the 3 point harness for size.
I clamped up the rear bracket as best I could until I cut the ends to match the frame...
This allowed the shoulder straps to sit nicely over the seat...
I then climbed on board to see if I could "buckle up"...
Even though the adjuster brackets are at my shoulder they actually seem fine.
I guess the restrictions of a racing harness is going to take some getting use to anyway.
The final job of the day was to prepare the petrol tank for painting.
I've left if out in the sun all day to get rid of any remaining petrol vapours.
This was before...
This was during the sanding down stage...
And then it was time to apply a coat of Kurust...
Then it was time to tidy up and put everything away for the night.
I have done all the grinding I need to do on the side belt brackets.
So hopefully I can get welding first thing in the morning as it isn't to noisy.
Until then, take care, Paul.
