I am trying to turn a Sherpa into a lose copy of this:-
this is the plan ?
I did build a 1/6 scale model [ Action man sized ! ]
with an idea of the internals ?
mocking it up :-
You can see how high I will be ? looks like any higher and I will take my head off on the garage door !
Also you cannot see the front wheel I have moved engine/gearbox back about 30" !
I did not chose this forum , although I am a frequent visitor as:-
a) I am not building a kit car.
b) I felt I was going to have all sorts of grief in the build, like my steering column is now about 40" from the steering box so I choose a hot rod forum as
it is more their field of expertise , your car's look marvellous , however you tend to favour a single donor and rebody.
c) some of the hot rod,s have used Sherpas in the past
all the best Paul
ps will answer PM when I am on my desk PC and can assess the situation regards the volume of the stuff
Since bleeding the brakes I've had zero enthusiasm for things mechanical as the A352 has been playing silly buggers yet again.
Yesterday I had a slight feebleness bypass and decided to address a couple of Weber related problems. The first was the attachment points for the air cleaner. There are four M5 tappings in the carb. body, two if which were completely stripped, and the other two almost. Looking at the meagre amount of cast ally around these, I'd previously fought shy of tapping them out to M6, as disaster seemed to be beckoning. Sod it, I thought, it's got to be done. I gaffer taped over the choke holes etc., carefully cleaned my M6 tap and set to with extreme caution, backing off every couple of turns and popping a drop of oil in to pick up the swarf. A nervous 40 minutes or so later the job was done.
Next question: screws or studs? I decided on the latter, cut four to length, thoroughly cleaned both them and the carb. tappings with acetone, and screwed them in with Loctite. Another job done. The second problem will have to wait.
I quit while I was ahead.
I'd been to Sainsbury's in the Lotus earlier and thought I'd go for a spin as the forecast for the rest of the week wasn't too clever. Despite the brilliant sunshine and the Lotus being bright red, I wasn't able to.
I generally think of Gloucester as fuckwit central, but this took the biscuit, the surprise being that it was 'only' a BMW rather than a Chelsea Tractor. I couldn't be fagged to go knocking on the doors of my legion of numpty neighbours so, despite the miniature Satan on my shoulder urging me to key it or douse it in brake fluid, wrote a polite (yes, really!) note in huge black felt tip and trapped it under a wiper. I heard it leave as dusk fell.
I know you shouldn't have to but anotice saying 'Entrance in constant use Please do not obstruct' might work. BMW owners are often a bit thick but will respond to a warning. If you knew where it was rig the Police and tell them about the party he is attending. Get the council to put a white line by your drive. I love the S4 Lotus, not widely appreciated but nice.
Still worth asking, or paint one youself! You can get Rollls of white line, lay it ad melt it with a blowtorch. Then deny all knowledge,' Doh I thought you did
Still worth asking, or paint one yourself! You can get Rollls of white line, lay it ad melt it with a blowtorch. Then deny all knowledge,' Doh I thought you did
I did one myself outside my gate using aerosol line marking paint so I could get my motorbike in and out. Did it make a blind (yep) bit of difference? Nope. Gloucester is technically a city but the mentality is that of an isolated medieval village...
Thanks for kind words regarding the S4. It garners nearly as much interest as the A352 . I'm displaying it at the Castle Combe Historic meeting this weekend, I'd better get the bucket and sponge out!
Yesterday I wandered down to the sunlit cave and re-bled both the clutch and brakes, this time successfully. Riding that wave, and with a freshly charged battery and a squirt of ether, I fired her up. Lumpy and reluctant to idle, but running . The next two days are forecast fine here in Gloucester, so I can have a good game under the metaphorical bonnet.
It seems that, at long last, I have a genuine purchaser for the A352. Its insurance runs out on 2 December so perhaps everything will fall nicely into place?
Thanks for supportive comments everyone , I'm not getting excited over closing a deal on the A352. Given all the past disappointments I'll believe it when it's trailered away and I have a wad of 50s in my pocket.
Anyway, back to the Monaco. In yesterday's clement weather I enthusiastically marched down to the cave hopeful of making meaningful progress. I decided to go back to basics on the engine. I cleaned and reset the points, set the static ignition at 6° advanced and adjusted the throttle stop and idle mixture jet screws on the DCD to their basic settings. Using full choke she started instantly and after immediately moving the choke to the intermediate warm up setting she ran very sweetly - result. Unfortunately the brand new starter solenoid decided to ignore its 12v signal from the ignition switch so I had to use the button. I started her again but this time the solenoid stuck on. Damn! I took it off, removed the rubber cover and liberally applied WD40 around the button whilst working it. I also gave it a couple of stiffish belts with a hammer. Replacement revealed an operative button but still no response to the ignition switch. I double checked both its earth and trigger voltage but no change . Hoping the WD40 might work its magic overnight I called it a day.
Claims :- Race car maybe unique and complete with its original engine running 001300km in correct condition I do not do not know its history not a similar one in France nor to the strange c is a friend who inherited these relatives and sold it to me I sell it with regret. the rental lease of my non-renewable local sarrette I sell € 25,000 or exchange for vintage car for collector or youngtimers
To me, it looks bigger than a Monaco, or are the people small? I remember in the mists of time a magazine article where the creator of the Monaco said that he had based it on '50s specials. Maybe this one? I love it, 3 stud wheels, Citroen front wheel drive? Paul N more pics and info please!
By the way what is the body behind it?
It's undoubtedly a Monaco, and it's one I hadn't seen before. Thanks for posting. Looking at the supplementary grilles and giveaway wheels I agree with Dpaz that it's 2CV or Dyane based. The body behind it looks to be a Lomax 223/4.
The three in the link are also Monacos, I like the one on wires, well disguised but clearly Spitfire/Herald/Vitesse/GT6 underpinnings.
I'll post a picture and the link on the Moss Owners FB page and await developments.
I assume you have seen this? Some interesting ideas?
Paul
Hi Paul
Apologies for delay in replying. That's a new one on me, thanks for posting.
Nice dash, apart from the flip up starter, too plasticky for my taste. Carpets, in a Monaco? Knuckle protection required with that gear stick position! At least it's X-Flow powered, rather than P*nto (swear word in my book). Shame there's not a rear view, are they mirrors on the back mudguards ?
I went with a friend and looked at a Ford (Fix Or Repair Daily) based one in Bristol about ten years ago. We dragged it out of the lock up on its flat tyres to find it was thick with rust, scary wiring, no engine or gear box, and a very tatty interior. Only the body was really worth saving. He wanted £450 so I took a pass on it.
