Scottie's Tribute A352 build
1 Feb 2014, 8:54am
Shall I set up the Tribute Automotive Owners Club Military Wing?
1 Feb 2014, 10:11am
There seems to be more than we think out there WCA!
1 Feb 2014, 10:14am
Does anybody dee a kit for a Stolly? Complete with controllable back fire to shit up the box heads and Rolls Royce engine?
2 Feb 2014, 3:51pm
Well, today was bright and sunny, and I had fallen behind with log storage.
Luckily, and friend of mine rang up to tell me a small tree had been blown down in his garden. Just what I wanted to hear!
I took my chainsaw round and had it in logs in no time, it was the best exercise I had since leaving hospital. It was very satisfying, and I feel great.
I did not think to take pictures so you will just have to use your imaginations!!
2 Feb 2014, 6:44pm
Scottie22 wrote:
... I took my chainsaw round...
Did it look something like this?
:icon_wink:
2 Feb 2014, 6:46pm
Bloody hell Paul!!
That gave me a really good laugh! Well done.
I would like to think it looked like that, but reality probably was a bit more mundane as it usually is!
2 Feb 2014, 7:49pm
Logs
3 Feb 2014, 4:23pm
XKSS windscreen
I have re-started to work on the Morris Minor rear window and frame which will be turned into the XKSS windscreen.
I have been both looking forward to, and dreading this bit.
What I am about to attempt (in my view) IS do-able, but only just.
The measurement are very critical, and there is no room for error, hence my apprehension.
I HAVE to get this right first time, and having not done it before does not help much!
The blind leading the blind in the dark! (Least that is what it feels like)
It WILL turn out right, but I have to really get stuck into it.
Here are some new pictures of where I'm at:
3 Feb 2014, 4:36pm
I assume the pink handle is connected to the rake?
3 Feb 2014, 4:54pm
In this particular case, the noun rake, ( not actually an agricultural implement in this example) taken from the adjective "raked" meaning "to incline from the horizontal" or in this case the vertical, as in "raked masts" or if you will, "raked windscreens"
The pink handle you refer to is merely a simple prop in order to set and adjust the rake angle.
I trust this clarifies your wrongful assumption.
3 Feb 2014, 6:22pm
It's going to be epic Scottie. You're a brave soul!
3 Feb 2014, 6:36pm
Ah dee me best Ringo!
3 Feb 2014, 7:35pm
Is it a fixed or variable pitch prop? :whistle:
3 Feb 2014, 8:13pm
Don't you start! :-)
3 Feb 2014, 8:26pm
Is it really possible to have a variable pitch clothes line prop? Geoff.
3 Feb 2014, 9:42pm
You may need to weld that multi adjustable vernier extending mop handle in place to help you get in and out.
3 Feb 2014, 10:33pm
If I don't finish the build soon. I'm gonna need a bloody crane to get in and out I think!
4 Feb 2014, 9:08pm
Have you been living off takeaways like?
4 Feb 2014, 9:58pm
Divent be daft man!
5 Feb 2014, 5:06pm
Screen saga
I spent more time trying to work out how to make the Moggie screen fit my car.
As usual more butchery was involved, and more will be needed I think.
I still have not done any more welding, as I need to know what needs welding to what, and that is proving very complexly difficult.
However, it is only a matter of time and it will come together.
Here are more pictures showing the slow, but definite progress:
6 Feb 2014, 7:17am
I would have moved the screen with its frame further back and would have done the changes in the center of the bonnet i.e. closing the gap between bonnet and windscreen frame ;-)
6 Feb 2014, 7:56am
Now you tell me! :-)
6 Feb 2014, 1:14pm
Scottie - I know this is a key part of the build for you, so I hope you can sort it all out.
Obviously I have absolutely no idea what to suggest. :rolleyes:
So I'll just wish you good luck instead, Paul. :)
6 Feb 2014, 4:34pm
Thanks Paul,
now there's two of us with no idea at all!!
Nah! It'll come right in the end!
