Mister Towed on the road...
12 Jul 2014, 4:32pm
Nice one T, hoping I don't suffer the same issues, hopefully won't as I'm a cylinder down on your!
Mac
13 Jul 2014, 7:40am
Mr T - That is great news, really glad you can enjoy the rest of the Summer. :cool:
If you are ever driving around Wembley, please pop around to say hello...
... and I will wrap your wiring up in black tape for you myself. :icon_twisted:
14 Jul 2014, 6:16am
Hi Towed,
Glad to hear your cooling problem is over.
Looking at you picture, I noticed the way the dynamo is mounted. Did you consider using a smaller fan belt? Maybe this gives a better position to the dynamo for the use of a more simple tensioning bracket?
Michiel
14 Jul 2014, 7:39am
christinedmc wrote:
Hi Towed,
Michiel
Hi Michiel. The dynamo is mounted like that to clear the bonnet as it was just fouling the inside edge of the larger scoop. All I did was rotate it so it sits under the main bracket instead of over it, then made a simple stabiliser bracket to steady the third mounting point. That approach tucks the generator out of the way and uses the standard belt for simplicity and ease of replacement, and it works just fine.
Looks like it's going to be a nice, sunny day in the East today, so a run up to the North Norfolk coast is on the cards. It's going to be nice not having to constantly monitor the temperature gauge for the first time since I finished the car. Aluminium radiators might look cool, but copper cores actually help you keep your cool :rockon:
14 Jul 2014, 6:00pm
Took a trip along the North Norfolk coast today, stopping for lunch (chips) at beautiful Wells Next The Sea -
Weather was perfect and the 'gulls didn't mob us too badly whilst eating the chips -
Stopped off at a farm shop on the way back and couldn't resist parking next to this enormous off-roader -
I reckon that 911S number plate would've cost around ten times what I've spent on my car :lock1:
Also found its little brother parked up in sunny Hunny on the way home -
MassIVVVE!
Car got loads of attention as usual. The bit of Norfolk to the East of Hunstanton is known locally as Chelsea on sea, as it's full of multi-millionaire mansions. There's nothing quite like seeing the look on a £120k Aston driver's face when you blast past in something far, far cooler. :cool:
14 Jul 2014, 8:38pm
Good to see your back on the road again and i will use this for reference when i sort out the rad for my car.
I hope you had plenty of slip slap slop on the old barnet, the weather looked perfect for open top motoring.
14 Jul 2014, 9:00pm
Nice one Mr T.
Silver really suits your car.
I know what you mean about the attention, when I had my little "Seven" I would drive about like one does, and then see people in very expensive soft top cars, coming the other way, and my car would suddenly become completely invisible to them!
They would not even look at it, they felt really super-cool until they spotted what you are driving, then pretend not to notice it at all!
Imagine how they feel, upstaged by a car that cost the same as what their car costs to service!
15 Jul 2014, 5:24am
looking good towed ...looks like car run fine and a nice day out ..great to see you back on road
15 Jul 2014, 12:33pm
Mr T - More great photos. :cool:
I love seeing your car "standing out from the crowd" and it is a great motivator for my own build.
So carry on winding up the owners of expensive cars. :icon_wink:
Take care, Paul. :)
16 Jul 2014, 6:31pm
MOT passed today :)
Can't believe it's been on the road a year now. Mind you, it's taken a full year of fettling to get it running as sweetly as it is now.
The changes I've made from its original spec as far as I recall are as follows:
One more leaf removed from rear spring, lowering blocks all removed to achieve desired ride height/handling/ground clearance;
150lb Spitfire front springs fitted, cut down by 1.5 coils (about 30mm), to replace 220lb springs cut down by 95mm again to achieve desired ride height/handling/ground clearance (might just change to 180lb at some stage in the future);
Heavy duty ARB fitted in place of standard, thin effort to compensate for softer front and rear springs;
Quicker, Spitfire steering rack fitted and clamped down with solid alloy mounts for more positive steering feel;
175/80/14 Uniroyals fitted in place of 175/70/14's once again to achieve desired ride height/handling/ground clearance/and how they just look better;
Alloy Honda Civic racing radiator replaced with larger, copper cored Stock Car radiator to cure overheating issue;
Mk2 Vitesse camshaft and new followers fitted for a bit more power;
Cylinder head decoked, valves lapped in, new timing chain and tensioner fitted whilst changing cam;
MSD multispark ignition unit removed and binned after it failed under full power, stranding me at the roadside in its only breakdown in 2,000 miles :(
Modern stereo removed and binned when it never worked again once I'd dropped it prior to final fitting :(
I think that's about it. If I built another I'd be incorporating all of the above into the initial build, especially the suspension settings which were far too low initially - looked cool but fouled everything.
Things still to do include new wheel bearings all round (advisories on the MOT), fit the 1.75" Strombergs I have sitting in the garage and maybe purchase a Witor flow balanced manifold to go with them.
Oh, and here's some video of the MOT guy bringing it back from its brake test. Afraid it's mobile phone footage and he managed not to rev it at all as he passed by but you get the idea...
Here's to another year on the road and a few more finished cars to join me over the next twelve months. :)
17 Jul 2014, 8:26am
top job towed ......
17 Jul 2014, 8:38am
I'll try and join you for a drive after your next MOT.......
17 Jul 2014, 10:29am
i think i can say from me towed barry wee always up for a run out..
18 Jul 2014, 9:11am
Mister Towed wrote:
... Here's to another year on the road and a few more finished cars to join me over the next twelve months. :) ...
Hmmm ... 12 months from now you say ... hmmm ...
Can I put myself down as a "definite maybe" for this group drive? :rolleyes:
27 Jul 2014, 6:29am
Mister Towed - I know this is your on the road thread, but can I take you back to your building days?
It was just over two years ago (July '12) when you bonded the body shell to the frame. :eek:
Looking at yours photos it appears that there were just four points of contact.
( 3 small blobs across the front of the frame and the huge blob at the rear. )
Were there any other places you used the bonding paste between the frame and the body shell?
I also remember your tip about using Tetroseal on the inside of the shell.
Given all my "cutting & shutting" going on with my body shell, I think this would be a very good idea for me.
However, I will bear in mind your other top tip...
Mister Towed wrote:
... If anyone does go with the Tetroseal coating on the inside of their shell, I'd mark the points where the bonding paste is going to go, rough sand them for adhesion and leave them free of Tetroseal so the body sticks to the frame properly ...
Which leads me to another question about the bonding process...
Was a "rough sand" all you gave the paint on the frame before adding the bonding blobs?
Similarly, when you were fibre glassing your floors to the body shell, was there any problems making the fibreglass stick to the painted floors?
Finally, your big bonding blob was there to support the centre of the rear cockpit.
By the looks of it, your internal cockpit panels support these outside corners of the rear cockpit.
I take it there is no issues with putting any weight on these corners on your car?
I was thinking of building extra supports for these corners on my car, but it seems the internal panels do the same job.
Sorry to bombard you will all these questions, but thinking about this stuff now, will hopefully save me time in the future.
27 Jul 2014, 6:16pm
Hi Paul, never a problem asking questions.
I believe I used six blobs of bonding paste left, right and centre, front and rear. Don't recall even sanding the smoothrite on the frame and it's stuck down just fine.
Likewise the csm and resin stuck rock solid straight to my smoothrited floors when I attached the inside of the shell to them. Just remember that's your opportunity to set the body sides where you want them so make sure everything looks right before applying the old resin.
my interior cockpit panels (6mm marine ply screwed and bonded inside the return under the cockpit edge) gives the shell enough strength to take my weight when climbing in and out - in fact that's what transforms the shell from wobbly blancmange to rigid structure. for the curves that form the inside panel corners on mine I just stapled stainless mesh into the gaps where the side and rear panels didn't meet and 'glassed over the top, effectively bonding the rear corners of the body into the interior panels. Worked for me. :)
27 Jul 2014, 8:32pm
Thanks for the reply Mr T. :cool:
I am not sure when, but one day I will finally get my body shell fixed into position. :pray:
30 Jul 2014, 3:53pm
Off to Southern Italy tonight, shame I can't take the Spyder with me. :(
One day though, one day. :lie::lie::lie:
30 Jul 2014, 8:16pm
Nice & sunny here .... why go all the way to Italy :noidea:
Enjoy your break
Hope to see you at Revival
Slarti
30 Aug 2014, 4:38pm
200 mile round trip to Donington today and the Spyder didn't miss a beat. :)
Cooling is now fully sorted with the copper cored stock car radiator, extended motorway running at, ahem, 70mph(+) followed by stop start town traffic and it never rose above the second dot on the gauge.
One slight issue that's been slowly building up was the horn occasionally sounding itself. Today it decided to sound off on every roundabout - thank Christ I wasn't driving round Milton Keynes - so I had to pull the 'pencil', which was completely worn out, out of the steering wheel boss when I got there.
Good show, loved tribute's 250SWB and will be building one when funds allow...
My baby -
its nephew -
And the twinkle in my eye -
30 Aug 2014, 6:20pm
Nice one Mr T!
Your car makes even a Cobra look fat and over weight!!
I set out for Donington myself today,intent on meeting you, but had to turn back and go home when a "clonking" developed on my car.
Turns out the CV gaiter had split, spilling all the grease out, which dried the joint causing the noise.
Have ordered grease and new gaiters, but not in time for Donington unfortunately.
So you've got away with it this time Mr T!
31 Aug 2014, 6:05pm
Mr T - I know your car is low, but the blue car to the right of the Cobra is seriously slammed (if not squashed). :eek:
I agree that the 250 SWB looks great and that is before the final finishing touches are applied. :cool:
31 Aug 2014, 6:25pm
Lotus XI replica I believe.
Doesn't the Cobra windscreen look like overkill compared to the flyscreens on the cars either side...
1 Sep 2014, 6:42am
I think the fly screens definitely add to the overall race car look. :cool:
10 Sep 2014, 7:05pm
Gave my Spyder a wash, polish and topped up the fluids ready for the trip down to Goodwood tomorrow. Also got my 50's period overalls pressed for the show -
Such a nice day today that I took my better half up to Hunstanton for chips'n'curry sauce in the sunshine -
I had wondered whether it was necessary to fit a heater but today the air was cold despite the sunshine and the heater did a surprisingly good job of keeping the cockpit snug and warm.
Thoroughly looking forward to Goodwood, will post some pics over the weekend.
