As for being part of the driving experience in a Sammio, it sounds like it will be a 4 wheeled motorcycle.
As for the floor, I had already prepared some words covering that in the post below.
But basically the Cordite frame wraps around the chassis in the middle.
This appears to be different to the Spyder frame work & the new Navigator frame.
So the order of parts will be...
Chassis + Frame + Floor + Hand Brake Panel
This is the best photo I have (and it is not great) with the fibre glass floor roughly in place...
Tuesday:
Both my wife & I had tough days at work, so a family trip to the local curry house was in order.
But as the sun was still shining when we go back, I got changed, pulled off the tarpaulin & got out the bitumen paint…
Spitfire Rear Wheel Arch Section:
I just needed to make sure I put a dust sheet underneath, as I've already got black paint on the driveway.
Before:
( Although the Kurust dries black so it is not so easy to see. )
After:
I know it is just the first coat, but it still nice to see something heading in the right direction.
Although it will be dark by the time I get back out to put the tarpaulin back over the top.
Top Tip:
Whilst a good face mask keeps the paint fumes out, it also keeps the curry & beer fumes in.
Rear Internal Framework - Planned Modification:
I have also been looking back at the work I did to make the separate hand brake panel fit over the frame.
The panel needed a lot of cutting before it would slot over the box section forming a cross bracing triangle.
This time around I am going to cut that section of the frame out & weld in a new section at a different angle.
Which means it must be time for another one of my dodgy sketches…
( This represents a section of the frame on the passenger side, looking from the front of the car to the back. )
With this mod, the hand brake panel you see above would sit flush against the frame without any cutting.
So hopefully I should be able to keep this hand brake panel attached to the rear floor / arches section.
However, I still need to work out where exactly I can cut the rear section to keep as much intact as possible.
As this forms part of my "treading through" the frame issue:
- The mounting points at the back of the internal frame will need to sit on top of the rear arches section.
- Whereas the frame work will need to be underneath the hand brake section to sit on the chassis.
Although technically, it will need to sit on top of the lowered floor pans which will be sitting on the frame.
So as I was explaining to Mr T above, I need to co-ordinate the frame, floors & rear arches section.
I'll go though some more thoughts on the floors another day.
