Ericholm 250 SWB Build thread
30 Oct 2016, 3:55pm
I was not happy with being able to see through the wheel arches and out through the front grill and air intake. Also at the rear of the front wheel it sort of looked un-finished.
I had previously 'chopped' the Z3 inner arch parts to shape, however due to the extra width of the from section of the body it left a huge gap. So I ordered some 1.5mm sheet of black plastic ABS and made an inner wheel arch liner.
I'm pretty happy with the result and will now need to do the other side, it took about 2 hours of adjusting, fine tuning, trimming so that the bonnet can open without it scraping touching. But now one side is done I just need to mirror it on the other so should take less time. On the rear there are also some gaps but nowhere near the size of the front so should be much smaller job.
Here are some pictures of todays work........
BEFORE
DSCN9339 by eric holm, on Flickr
DSCN9338 by eric holm, on Flickr
DURING
DSCN9321 by eric holm, on Flickr
DSCN9328 by eric holm, on Flickr
DSCN9329 by eric holm, on Flickr
DSCN9331 by eric holm, on Flickr
AFTER
DSCN9337 by eric holm, on Flickr
DSCN9334 by eric holm, on Flickr
30 Oct 2016, 4:20pm
Cars looking great Andy. I think I'll steal your front arch idea as I 'm not keen on the look at the front either.
Where did you get the material from?
30 Oct 2016, 4:24pm
That looks neat
30 Oct 2016, 5:43pm
Hey Bob! Long time no hear/see.
1.5mm thick and I think the sheet was 2.4m x 1.2m ABS Black non-dimpled (Smooth)
from
http://www.eagleplastics.co.uk/
around £49 delivered
I'm off to NEC to classic car show probably on 12th Nov, are you going? wont be taking my SWB though as sorn'd at end of Oct.
Cheers.
30 Oct 2016, 5:44pm
Roadster wrote:
That looks neat
Thanks Roadster, for me its all about the little details :-)
30 Oct 2016, 6:30pm
Looks so much better. Every little change you make amounts to a big difference.
Must be following the 100 times 1% difference = 100% better
30 Oct 2016, 7:32pm
Looks like a finished car now . Details like the under arch trim make all the difference . The MX5 250 kits look odd when can see right through from the wheel arch to the nose and you look at a void of empty space. A simple but effective fix.
19 Nov 2016, 2:43pm
Some recent additions
Thanks to Lucky@LeMans (Paul) for building the bracket and screen for my bonnet screen. Heres some pictures:
[SIZE="5"]The original[/SIZE]
P1010985 by eric holm, on Flickr
[SIZE="5"]Placement of my screen[/SIZE]
Dscn9397_ by eric holm, on Flickr
[SIZE="5"]Perspective view[/SIZE]
DSCN9389 by eric holm, on Flickr
There is some adjustment needed to get the right angle, gap, fixing size, etc. but this needs some time and thought, but generally it fits and is a great addition to the car.
You will see that my pictures look dark (time of year I guess), and in reality it doesn't look so noticeable and sort of blends in with the car. Also its shiny metal and in the picture it looks black. I'll take some more and share another day!
Also I have gone with a smaller profile in terms of height and a slightly thicker screen (5mm) so the thing doesn't 'flap' around at speed.
Thanks once again to Paul getting the profile from my rough cardboard template! :eusa_clap:
19 Nov 2016, 4:01pm
Looks good !
Maybe a strip of soft rubber or foam under the screen will hide any slight gap. If you tilt the screen back slightly it will lift the front lower edge a little so the addition of a rubber strip will close the gap.
23 Dec 2016, 10:06pm
Hi All,
Iv'e been messing around with a build video on Youtube using the pictures taken during the build
https://youtu.be/v2hZuMKccMY
Had to do 3 parts as software only limited me to 5 mins per video :hurt:
Hope every one has a festive time, look forward to dry weather next year!
:plane:
23 Dec 2016, 10:52pm
Great work on the videos. Thanks for taking the trouble.
Have a wicked xmas
28 Jan 2017, 2:41pm
That really is a superb looking example and the wheels look just right too. I wouldn't be waiting for warmer weather if it was mine...
28 Jan 2017, 2:50pm
Looks great, it's amazing what you can find amonst the junk in a garage.
Bob.
28 Jan 2017, 6:03pm
That does look excellent. The 250swb tributes are some of my fave cars out there.
Those wheels do look good. Are they Calibres ?
28 Jan 2017, 6:55pm
Thanks, but fair weather only for this one, ironically though I am sure the heavens will open on the first day of use this year, most likley at the further point away form home! :icon_redface:
Cheers.
28 Jan 2017, 6:57pm
Thanks Dave, Yep well spotted they are calibres with a modified center with a 3 star spinner attached, All cost less than the 17" BMW wheels that were on the Z3 that I sold on ebay!
29 Jan 2017, 7:32am
Your car does look absolutely stunning. :cool:
ericholm wrote:
... I am sure the heavens will open on the first day of use this year, most likely at the further point away from home! ...
Look on the bright side, at least if this happens your car actually has a roof! :icon_wink:
29 Jan 2017, 4:47pm
No bug screen on the front then ! Did you manage to find something that would seal the gap under it ?
The car looks stunning all the same.
29 Jan 2017, 6:02pm
Thanks, Bug screen will definately go on, I need to adjust the mounting to get angle correct due to angle of bonnet, probably will go with smaller mountings but will use all fixing positions instead of 3. Will need to get some fabricated, I have some prototypes and as will be seen they need to be a good finish, not my hacksawed/dremmelled version!
Watch this space.....
14 Mar 2017, 10:22pm
Front wheel arch liners
I finally got around to taking some pictures of the inner wheel arch liners I put in to
1. Stop the water being splashed straight on to the front light fitments and electrics &
2. get rid of that horrible see through the wheel arch and out of the front grill scenario.
It took some time to fine tune, mount, shape and fix in place, without it fouling on the hood section when lifting it up and down.
Overall I am pleased with the look.
aDSCN9670 by eric holm, on Flickr
aDSCN9669 by eric holm, on Flickr
I also refurbished the soft top hood, and it had come back really well.
Ive still got to get the small front deflector windscreen fitted with new mounts (local metal work chap on the case with that one).
Here are some more photos as getting car ready for 1st April to be back on the road.
Also booked up the Laon Historique trip for start of June :yo:
So full systems checks are underway, oil, water, tyres, electrics, brakes, etc.
aDSCN9747 by eric holm, on Flickr
aDSCN9730 by eric holm, on Flickr
aDSCN9849 by eric holm, on Flickr
aDSCN9889 by eric holm, on Flickr
aDSCN9653 by eric holm, on Flickr
aDSCN9677 by eric holm, on Flickr
aDSCN9707 by eric holm, on Flickr
aDSCN9697 by eric holm, on Flickr
aDSCN9681 by eric holm, on Flickr
15 Mar 2017, 12:43am
I've read this thread back to front and front to back again.
I have to say, I just love your car!
15 Mar 2017, 8:08am
Ditto, great looking car in a great colour with superb detailing. Nice.
15 Mar 2017, 8:35am
Hi Munky and Mr T,
Still trying to get it finished, small steps now, bit by bit getting there. trying also to show all stages for others too, if it helps anyone then great! :yo:
15 Mar 2017, 6:40pm
Looking sweeeeeeeet. Like the little tweaks you are doing.
