This is a lot larger and cheaper than anything else I could find, it also looks perfect.f1 by jaguartvr, on Flickr
To fit it I cut the mounting panel in half to enlarge it and then in half again.cap2 by jaguartvr, on Flickr
Here is a picture of it mounted with the rear clam off.fuel7 by jaguartvr, on Flickr
I did find that using the concertina effect fuel filler pipe from CBS restricted the fule flow so I bought 500mm of straight pipe designed for a boat. Fits perfectly and the fuel flow is much better, you still have to fill up with the trigger pulled half way but if you look at the picture on Smash's thread youl will see it is much better.
I used rivnuts to provide tapped holes to mount the flange as getting nuts on the mounting screws was just about impossible. Don't forget to provide a drainage hole otherwise it will fill up with water. cap4 by jaguartvr, on Flickr
I don't really want anyone fitting the 4-5/8ths filler cap, at the moment I can comfortably say I have the biggest on the forum and would like to keep it that way!
Travelling down Egham Hill on the A30 this morning and whats coming up the hill but a Cherry Red DNA 2Fifty, very nice it was, almost as nice as the 250swb!
Small world.
Took it in for its first MOT since the conversion, all passed but it was pointed out that if fitting a single rear fog light it has to be fitted on the drivers side.....Doh!
So now I have to reposition it which involves cutting the body work which I wanted to avoid.
Is it me or have Z3 2.8's suddenly gone up in value?
Seem to be going for silly money.
Was bidding on a 97 2.8 on Copart today, front end, cat c value was only put at £1400. One front wheel turned out and pushed back. Bit of a risk could be a wishbone or a bent chassis leg. It did have a very nice red leather interior and a good looking roof, thought it was worth a punt a £500>£600.
Went for £1250 + buyers premium
My latest cock up is the front indicators. Being rather clever I fitted a set of chrome Harley indicator bulbs. That means that the yellow of the indicator bulb doesn't show through and give you the fried egg look.
Unfortunately, the chrome bulbs are a tiny bit bigger and when the MOT tester left the hazards on during the test, the lenses started melting!
I've ordered a pair of glass lenses, whats the betting they don't fit the plastic light version?
I've painted normal clear glass bulbs when I couldn't find amber/ yellow ones in the size I wanted. That seemed to work ok. In hind sight it did have the fried egg look , but I didn't even think that at the time !
Hi when I took my kit for its first mot I tried winging it without side repeaters had to take it home and fit some chrome jag ones sourced from a scrap yard, car has been off the road for a while repeaters not working as bulbs rusted into holders drilled them out and got 2 white £4.99 led dash lights from Halfords soldered them onto wires re fitted lenses, job done. originally had led number plate lights but found them too white and modern.
On my Cafe racer motorcycles, I run a mix of LED's and bulbs for the indicators along with a special flasher unit that automatically corrects the flash rate.
The Z3 doesn't have a flasher unit but a double realy, very complicated and not worth the trouble, stick with bulbs!
