11 Jul 2018, 5:29am
Good to see you back with your ingenious ideas. Keep it coming, I for one am dying to see the finished product which I am sure will be second to none.
Brackets by Sabrebuilder, on Flickr
Exhaust back box by Sabrebuilder, on Flickr
Brake lines by Sabrebuilder, on Flickr
IMG_6818 by Sabrebuilder, on Flickr
Chassis insulation by Sabrebuilder, on Flickr
Summer heat! by Sabrebuilder, on Flickr
More brackets by Sabrebuilder, on Flickr
Exhaust hanger by Sabrebuilder, on Flickr
Offside Engine mount by Sabrebuilder, on Flickr
Clutch by Sabrebuilder, on Flickr
Engine by Sabrebuilder, on Flickr
Pilot bearing removal by Sabrebuilder, on Flickr
Pilot bearing replacement by Sabrebuilder, on Flickr
Gearbox closing plate by Sabrebuilder, on Flickr
Closing plate by Sabrebuilder, on Flickr
Flywheel by Sabrebuilder, on Flickr
Gearbox fitting by Sabrebuilder, on Flickr
Engine fitting by Sabrebuilder, on Flickr
Exhaust manifold by Sabrebuilder, on Flickr
Coming togther
Coming togther
out:
Clutch lever pivot by Sabrebuilder, on Flickr
Gearbox Oil replaced by Sabrebuilder, on Flickr
Another handbrake cable by Sabrebuilder, on Flickr
Heater by Sabrebuilder, on Flickr
Heater Fan by Sabrebuilder, on Flickr
Heater fan by Sabrebuilder, on Flickr
Rear Springs by Sabrebuilder, on Flickr
Rear spring re-fitting by Sabrebuilder, on Flickr
ARB's by Sabrebuilder, on Flickr
ARB Bushes by Sabrebuilder, on Flickr
24mm ARB fitted by Sabrebuilder, on Flickr
Exhaust bracket by Sabrebuilder, on Flickr
Propshaft by Sabrebuilder, on Flickr
Body tub fitted by Sabrebuilder, on Flickr
Bedtime by Sabrebuilder, on Flickr
Engine ancillaries by Sabrebuilder, on Flickr
Misc. Engine parts by Sabrebuilder, on Flickr
BMW engine loom by Sabrebuilder, on Flickr
'A' post crossmember by Sabrebuilder, on Flickr
Pedal box by Sabrebuilder, on Flickr
Clutch Reservoir hose by Sabrebuilder, on Flickr
Brake master cylinder mounting flange by Sabrebuilder, on Flickr
Engine wiring loom by Sabrebuilder, on Flickr
