Part 3 . . . . .
The back end of the car is certainly quite close to Farina's lines, while not being too complex. The design is clean, but set off by the lights, hinges, bumpers and tailpipes.
The panel was reworked / glassed to have the rear lights pointing almost straight backwards. Note: they must be visible from the side.
The led rear lights [including a reflector] come from Australia, with their colours of wiring. The car was designed by a Japanese man, for a German company, who built the car in the USofA, while we play in the UK.................... in their infinite wisdom bmw seem to have different coloured wires going into and coming out of the same connections in a say, 8 wire plug !
The fog and reversing lights come from a bmw Mini and in due course, they will look better being 2 - 3" further back under the bumper.
The Tribute sign in a modified Ferrari Rosso font, inverted line, was laser cut in Cornwall, via ebay
The boot lid was my attempt to fibre fill, hi build, flat and rattle can spray . . . probably leave it to the professionals in future.
In places we have sprayed a matt cellulose RAL 5000 to cover ugly workings. The gel coat was RAL 5000.
The MGB GT rear glass is a B..... to fit, even by a professional.
Attachment “11 rear tribute lid & window.jpg” from the original forum could not be reliably recovered.
The boot is enlarged with a not very usable space and the lid will need some powerful struts to help it up. Fitting the catch was best done with the shell off, so that I could see inside what was happening . . . The aluminium hinges come from old Minis at Mini spares in Potters Bar. 'Handed' to allow for the boot lid curvature and with the edges smoothed over, they will need lacquering in due course.
The boot lock barrel will benefit from a round stainless surround. 36 - 40mm?
The standard lock mechanism and connectors are set upside down and the other way round, so that the lock is on the boot ledge and the striker in the lid.
The rear end has elongated tailpipes in 54mm OD 2mm wall stainless 15" onto the rear box; the tubes came from Poland via ebay. Fair price, poor communicators. Adaptors quickly and efficiently from UK 'everyexhaustpart' on ebay. A dummy box and pipes will be placed on the R side for balance.
When delivered the rear was bracketed up with some holey galvanised steel and in an effort to provide some weather protection, these were replaced with an aluminium sheet, a stainless section by the box and some plastic sheet to help.
The rear carrier was raised about 9mm but somehow the bumper is not quite level and a spacer will need to be inserted to lower the R side.
