Finally managed to get into the garage to do some work with the heater on.
Started with the boot lid making sure the rubber seal is compressed slightly all the way around, there was a few areas where daylight could be seen so these areas were built up with fiber filler then rough smoothed to check again, once i was happy it was time to cover the whole inside boot lid surface with body filler to hopefully give a smooth surface.
View from inside the boot of the latch and striker plate.
First image shows the rough fiberglass surface and the second is with a coat of body filler, just need to sand it down.
After fitting the lid there are a few areas on the outside that need building up to the level of the body, will use fiber filler then body filler with the lid in position to gauge the correct alignment and height.
After leaving the body filler to go off i moved on to the floors. Cut these from 3mm ally sheet to a rough shape, all of the cut edges will be hidden by the interior trim.
There's a sheet of 2mm steel welded to the bottom of the sub frame i made then sealed around all edges and finished off with etch primer and top coat to match the grey chassis colour.
The ally sheet sits on top the sub frame with box section welded to the 2mm steel plate in the area's where the seat mounting brackets will be, i will then be able to pick up the seat mounts through the ally plate into the box section below for a good sturdy fixing, probably use rivet nuts welded in place for extra security.
7 Dec 2014, 9:18pm
