Although I did get the chance to do one small job, that was thankfully indoors in the warmth...
Cordite Specific Wiring Diagram:
I cross checked my lighting circuit wiring diagram and thankfully it seems OK, apart from one thing I'd missed.
I had forgotten that the headlight switch is also linked to the lights illuminating dashboard dials & gauges!
So I have modified my diagram accordingly & will re-print it here when I know wire colours for side repeaters.
I've now started on the wiring diagram for running the engine (something I've already done in practise).
Welding Update:
I had an Amazon gift voucher which I have now used towards a basic auto-darkening welding helmet.
This will hopefully allow me to see what I am doing before I start welding, which can only help.
There will also be the added bonus of freeing up my left hand from holding the mask in place too.
I'll keep an eye on Ebay for a decent second hand ARC welder for a few weeks, before buying new if I have to.
Depending on what the weather is doing, I will try to get some more practise in some time over the weekend.
Cordite Frame Work Modifications:
And I certainly need the practise as here is my current list of welding jobs:
- Add a "box" to a vertical bulk head frame rail to allow the steering column to pass through.
- Cut and reposition the three frame rails that meet at a point behind the top/front of dash board body work.
- Fix seat belt mounting plates into position, adding additional bracing to frame work where required.
- Extend framework under the dash to provide mounting points to attach the steering column to.
- Match passenger foot well rails so floor pan will sit flush (currently one frame rail is lower than the other).
- Rearrange driver's side footwell rails to allow the pedals to clear the floor pan when depressed fully.
- Reposition front bulk head frame mounting plates to give better alignment with chassis mounting points.
- Add brackets to frame to provide additional support for the battery box when fitted.
- Raise the driver's side lower outside corner bulk head mounting point so that it sits inside the bulk head. *
( * Unless other frame modifications lower body shell sufficiently for this current problem to go away. )
But it is not all welding work, as I have a few simple drilling & cutting modification jobs to do too:
- Drill 2 holes in frame to match original seat belt mounting points in Spitfire hand brake panel.
- Drill 4 holes in Cordite's frame "spine" to allow additional bolting down through main Spitfire chassis rails.
- Remove all traces of the original seat belt mounting plates.
- Remove the body shell fixing bracket on the side of the pedal mounting plate.
That just leaves a few other odd jobs I need to make a final decision on:
- Add a vertical mounting plate to attach the accelerator pedal (might just re-inforce the fibre glass).
- Add mounting plate below dash for choke lever (& maybe hazard light switch & milometer trip reset).
Note:
As always, this is a legacy of the Cordite frame design, which has been re-designed in the Ribble Navigator.
Other Welding Work Required:
- Weld bonnet hinge mounting brackets to front of chassis rails (after re-body inspection).
- Weld the bracket used to pivot the handbrake mechanism back to the panel it broke off from.
DonnySoutherner - Cheers Simon, but I think it will be a while yet before I start over taking you.
