22 Oct 2021, 6:33pm
There, that's much better -
The image possibly still makes it look a bit wonky, which it isn't, and I'm confident it will look right once it's cut to size and properly lined up with the structure of the door.
I've made a mirror image of the inner panel for the other side which will be ready to have its opening cut out tomorrow.
While that was curing I made a start on the next step, which is to create something to make the doors weatherproof. That might seem a bit unnecessary on a completely open car, but it's mainly to stop it filling up with water if it's parked up in the rain with its tonneau cover fitted.
550 Spyder replicas often have a flange that overlaps the door on its inside to take a D section rubber seal -
So, my plan is to recreate that lip around the inside of the door aperture at the front and bottom of the opening. The inside back edges of my doors have the facility to take a seal already, albeit a self-adhesive one rather than one that clips over the lip, so I won't need to continue the lip up the back edges. A picture of what I'm doing might well explain that better.
A big chunk of alloy sheet cut to match the opening -
Then my now 'old faithful' former for the door sills was reused again to overlap the edge -
Tomorrow I'll fibreglass about a 4" band around the join between the flat panel and sticky out panel, which, once cured, will be moved 10mm back and up and 'glassed in place to form a lip the right size to take a slim D section seal.
Hopefully I should have that done tomorrow :)
23 Oct 2021, 9:30am
Mister Towed wrote:
... sticky out panel ...
I love it went you talk technical. :icon_twisted:
Jokes aside, your fabricating skills are letting you build your car the way you want it. :cool:
26 Oct 2021, 11:44am
What I really like Mr.T is that you always have a plan B. I'm sure the doors will look great when they are finished.
27 Oct 2021, 5:54am
Thanks for the supportive words guys, they're much appreciated :)
Not much progress this week, I'm afraid, due to family commitments.
I did manage to make the seal 'lip' for each door, though. They just need a bit of sanding and trimming to make them an even thickness and height above the door opening all the way round, then they'll be bonded in place, and they'll need to stand off from the opening about 5mm to allow space for the seal to contact the surface of the door under pressure but without completely crushing it. That will negate the need to have a recess around the doors to take the seal -
To keep it looking neat and 'factory' finished, I'm thinking that I need to find a way of using a seal that clips over the lip rather than a self-adhesive version. As there's quite a wide and deep gap between the back of the doors and the body I think I can make that work...
Hopefully I should have a better update later this week :)
5 Nov 2021, 4:58pm
Having spent a week doing other things, I have picked up the baton and restarted work on my Speedster doors.
I just had a couple of hours spare today, so decided to trim the oval hole in the passenger door inner surface panel, cut it to size - just at the top for the moment - fit it along its top edge and work out where the door handle needs to be.
to help me fix the panel in place I recently bought this rather Gucci M4 Rivnut tool -
As you can see, it's rather different to the usual 'pliers' type which require a lot of brute force to operate. This one uses two 13mm open ended spanners to draw the Rivnut up and compress it into place, which gives you a lot of control over exactly how tight it clamps into its hole.
It's the first time I've tried it and I do like it, you just have to be careful to stop when you feel the resistance to turning the nut increase or you'll strip the thread out of the Rivnut and have to drill it out and replace it (don't ask me how I know this...)
Anyway, that allowed me to fix the panel in place along its top edge with M4 countersunk allen bolts, and then find a suitable place for the handle -
I'm pleased with the results so far, I think it's all coming together the way I envisaged it :)
5 Nov 2021, 5:55pm
Those Riv Nut tools do come in handy. Good job!
6 Nov 2021, 8:27am
Showing my age...
Whilst idly surfing through chrome fuel filler caps on ebay, I came across this image, and I saw something completely different to my son (20) and my wife (a fair bit younger than me) -
So, what did you see?
I saw a freaky image of someone in a hoody wearing an Edvard Munch 'Scream' mask reflected in the chrome, while my far more tech. savvy son and wife both just saw the latest mobile phone being used as a camera.
I do now feel rather old this morning :(
6 Nov 2021, 12:54pm
That's funny! I saw exactly what you had seen.
17 Dec 2021, 8:09am
Progress has been a little slow lately due to family commitments and the like. I have been able to get on with the driver's side door seal 'lip' over the last week or so, though.
I've now set the correct gap for the seal and bonded/glassed the lip in place at the front and along the bottom, and I've temporarily screwed in a strip at the rear of the door aperture, which I'll bond into place in a day or so -
The seal fits snugly against the inner face of the door all round without leaving any gaps for water ingress or making the door too tight to close easily.
The seal looks a little uneven and there appears to be a squared section in the curve that joins the door upright to the lower edge in the photo taken from inside the cabin, but I just hadn't seated it properly all the way around so it does fit better than it looks.
Anyway, Christmas is only a week away so there won't be any more progress today as I have some shopping to do...
17 Dec 2021, 7:36pm
Mr T - how weird is this, was just wondering how you were getting on just today!
Great to see you are still ‘plugging’ away.
Looking forward to seeing more progress in 2022!
19 Dec 2021, 8:55am
Looking good so far MrT. Keep up the good work and progress thread.
It’s a bit quiet on here lately and your content worth coming back for.
19 Dec 2021, 8:44pm
Thanks for your positive comments, guys, it's nice to know you're interested in what I'm doing :)
It's all coming together slowly but surely, and I should have another update shortly after Christmas.
6 Feb 2022, 4:24pm
Mr T - A very belated 'Nice job on the doors'. :cool:
Any more progress to report?
6 Feb 2022, 8:27pm
Hi Paul, no more progress to report just yet as I've been busy with other things recently.
Will be getting on with it soon, though...
27 Jun 2022, 1:52pm
Hi Mr T.
Would you be kind to give more info on your spring choice for the Speedster please?
I have read that you have used 170lb springs (did you buy them at Rimmers? - I could only find higher rate springs on their website)?
I was researching a bit more about springs, and I think that I have read somewhere that you were intending to use 150lb springs for this build. Is that correct? If yes, what made you change your mind?
Also, did you have to cut down the springs you installed on the speedster, and if yes for how much please? The stance of the speedster looks great - I am curious what is the fitted length of the spring you ended up with?
I hope the build is going well, and that you also manage to find the time to go out and look for treasures with your metal detector.
Cheers, Deni.
30 Jun 2022, 5:12pm
Hi Deni, thanks for the positive comments they're always appreciated.
I've now sourced a pair of 150lb front springs from Moss Europe. I've gone with the softer rate as my car isn't going to be very heavy - the 180lb springs were perfect on my Spyder, which ran a straight 6, but the Speedster's only got a four pot - and a car with overly firm suspension is dangerous on the roads where I live.
The fen roads round here are very undulating as the ground they're built on is about as solid as blancmange, so stiff suspension on a car can make it impossible to drive safely at anything over 50mph. As an example, I attended a single vehicle RTC near Wisbech where a garage delivery driver had been driving a customer car, a Porsche Cayenne SUV on 20" alloys and 'uprated' suspension on a fen road. There was a particular straight where the road dips and rises twice in quick succession, and the Porsche was launched into space as it failed to damp the second rise after hitting the first dip way too hard - there were witness marks where the car had bottomed out. It struck a telegraph pole just under three metres above ground level almost twenty metres from where it took off, and ended up in the roadside ditch. The driver was fine, a bit shaken and probably in need of a new job, but the car was written off.
Anyway, back to the springs. Here's a list of what Triumph fitted and when:
http://auskellian.com/paul/links_files/springs.htm
And here's where you can buy the 150lb springs from:
https://www.jamespaddock.co.uk/front-spring-mk1-111-spitfire-2
I also use Gaz ride & height adjustable shocks on their softest setting and almost fully extended to get the stance just right.
https://rimmerbros.com/Item--i-GSA366GAZAS
Not cheap but excellent quality and infinitely preferable to cutting the springs down.
Anyway, got to go as I'm on holiday and wifey wants me to get ready for dinner :)
1 Jul 2022, 2:58pm
Hi Mr.T,
Oh dear, It's amazing how far and high this guy was "catapulted" in the air :surprised::shocked:. Poor guy, but I admit I had to laugh as well...I loooove your stories Mr.T, so thanks for sharing.
Thank you so much, your advice is so helpful, as always.
I have GAZ adjustable shocks. I have decided to part-exchange my spring seats for springs with 2,75" ID, and replace them with the ones for the springs with 2,5" ID. I need to lower my car significantly, so I reckon I need shorter springs, and there is so much choice if are buying 2,5" ID springs.
Your speedster looks great, and it will probably be a bit lighter than my car, as I have added some weight to the subframe modifying it to make it a bit more sturdier and safer, as it was quite basic.
So, I have now ordered 9" long, 170lb springs, and we shall see how they work. I know this is trial and error process, but at least I have a starting point. I tried to come close to factory Spitfire 1500 spec as a reference.
I'm only worried a bit about the top seats. Not sure they will be ok now, as the springs OD might be a bit smaller too.
Looking forward to see your next update on the speedster build.
Have nice holidays and thanks again, your help is much appreciated.
Cheers, D.
5 Sep 2022, 4:17pm
At last I've found some time to get on with my Speedster. Part of the reason for the delay was that I've just been so busy doing other things since I retired, like holidays abroad, visiting English Heritage and National Trust historic buildings and digging up the past in the fields near my home.
The other reason for the delayed progress is that I wasn't happy with the way my subframe and floorpan efforts were coming together. It looked fine, but I had niggling doubts that it was starting to get cumbersome, overcomplicated and might just not be up to the important job of locating the rear suspension.
As I've been following progress on the Old No.7 A6 GCS Coupe with interest, I had a bit of a lightbulb moment the other day as the answer has been sitting on my driveway under a tarpaulin for about the last four years.
I have an early Triumph Spitfire body that I had intended to turn into a GT-Sixfire by putting it onto a GT-6 chassis that I just happen to have in my shed, but tbh I'd rather build another special once I've finished my Speedster (probably an A6 GCS...) so I decided to sell both the GT-6 chassis and the Spitfire body.
Someone bought the body and then bottled it the night before they were due to collect it, but that's when the penny dropped and I realised that I should really use the Spitfire body as a subframe in the way that Dan at Tribute/Old No.7 do with their Triumph based cars.
I don't know why it took me so long to think of it, but I have now so I have gone at it today to see whether it will work with my 356 body.
First job was to remove the (fibreglass) rear wings -
This revealed a bit of a hidden horror in that a previous owner, after welding in new floors and sills, filled the sills with builders' expanding foam, which blocked the drainage holes and trapped water against the new metal :(
Thankfully, the sills survived the experience and the only rusted part is the non-structural bottom edge of the wheel arch liner, which I'm going to cut out anyway.
First trial of the body looked promising. This isn't a great picture, I'm afraid, but the back end grounded out about four inches too high as the Spitfire's inner rear wings were fouling the body while the Spit's rear valance made it difficult to lift the body on and off.
So, out with the angle grinder and chop, chop chop...
I eventually had to cut away the inner rear wings completely and part of the rear deck, while I also cut away the 'rear seat' area on the Speedster body so I could see what was going on inside. I'll reinstate that once it's all fitting together.
So, at close of play today, the body sits on top of the Spitfire frame perfectly, and the door apertures match exactly, which is more by luck than judgement!
Before packing up for the day I trial fitted the dash, and all that needs is for a bit of the Spitfire's dash panel to be cut back and that will fit perfectly too! I suppose the fact that there's only 8mm difference in the wheelbase between the Spitfire and the Porsche 356 helps :)
5 Sep 2022, 4:24pm
that is a positive step forward , i’d be feeling pleased with myself which i’m sure you are.
sounds like retirement is agreeing with you too
10 Sep 2022, 12:06pm
[QUOTE=redratbike;107987]that is a positive step forward , i
10 Sep 2022, 12:07pm
10 Sep 2022, 12:09pm
Forum's playing up again, my last post completely failed to appear :(
I did keep a draft, though:
That's a big YES on both counts:
I'm pleased that I've seen the light and realised that I should use the donor Spitfire's body as a subframe as it resolves a lot of design headaches that I'd unnecessarily set myself.
Retirement is also agreeing with me this time round (I unretired five years ago).
After 43 years keeping my nose pressed firmly against assorted grindstones, I've now finally accepted that work sucks and that I've had enough of it.
As it happens, doing your own thing all day every day turns out to be a much better work/life balance than putting work first and life second and I can thoroughly recommend it.
Now, back to my Speedster. I'll be mostly working on the Spitfire 'subframe' over the coming weeks to address the holes in the floor and to strengthen the sills to take the weight of the Speedster body, once I get back from Goodwood, anyway.
I need to get a move on, really, as I want this car on the road for Goodwood next year (that's always my target completion date), and a quick check on Google threw up the fact that prices of the real thing haven risen so much, almost a million pounds for a RHD Carrera Speedster recently, that a decent replica can now command the kind of price you'd have paid for a pristine early Porsche 911 around ten years ago - https://www.ebay.co.uk/itm/134200976503?hash=item1f3f006477:g:fb4AAOSwkMhifNPW&amdata=enc%3AAQAHAAAAoC%2BYFWufH%2BhHT579nEq0FynYLmHnfz9u1S9giXcDungLOKCuQjcaHf9srb96aR9qOKq1wWjZUpFik4kir%2FkTM%2FpnxY7L0YcSE0QaN3sQe1jzdfWl90qVmVK1x4YEKfnGMXPPi%2Bpz0jiuHpKN5Q5xkz3KaQuqxV%2F8zPuDK1vvnyG0evXqyScegNNkiAJ6XJSyLmEFPx4DGwqBeAn%2FwcnF0iw%3D%7Ctkp%3ABk9SR_rGqe7kYA
Well, seventy grand is at least what they're asking...
10 Sep 2022, 4:03pm
Now I know that the Speedster body will fit on the Spitfire tub with a bit of jiggery pokery, my main job for today was to separate them and move the Speedster body outside so I can work on further trimming down and repairing the Spitfire tub before reuniting it with the chassis and getting it to the Moon Rover stage.
Hmm, looking at that I can't help thinking of James Dean's 550 Spyder...
12 Sep 2022, 9:35pm
Wow Mr.T, that is very exciting development (and such a great idea in my opinion)! I'm looking forward to see how you are going to do this.
