Stewarts build
27 Oct 2015, 10:10am
It was 24 hrs drive but made it with load intact, car attracted a lot of attention at services along the road, a small crowd and photoshoot near Le Mans, a bit embarrassing considering the state of it, now to start some progress again....
27 Oct 2015, 10:23am
Something that's always bothered me since I bonded the body has been the wheel alignment, too far back and too low on the near side,
So drastic action taken taken, recut and reposition the wheel arches,
Cardboard former! Wait and see how it's taken ... Been so long since I've worked " the Sammio way" it's good to be back
27 Oct 2015, 11:20am
The standard wheels look quite streamlined, nice to see you back.
27 Oct 2015, 6:09pm
Great to see your build back in action. :cool:
27 Oct 2015, 8:24pm
Where are you in France may be we could meet up.I still got the miglia rattler
27 Oct 2015, 9:41pm
Hi Rattler I'm in Marmande 47200, is your Miglia still uk registered? What with the nightmare of registering anything unusual here in France.
28 Oct 2015, 10:52am
This guy might be able to help with French registration. His name is Jean-Paul [email]jp.francois37@orange.fr[/email]
28 Oct 2015, 5:12pm
Thank you
Appreciate the link, ( pm sent to you)
Cheers Pops
1 Nov 2015, 6:25pm
Hi pops yes UK reg giving up trying for French reg French not and isurance i am in 79320
30 Mar 2016, 5:28pm
Wow time passes so quick since I posted any updates, still plugging away. Finally gave up on the slammed look when I altered the exhausts, have managed to cut the final one into two prong back by 10 cm and pull the tail pipes in the same making them a lot more acceptable protruding at the back, however when I pulled out of the garage I caught the rear apron on the floor ripping it up the rear seams, this was the final straw so lowering block out, with the swing Spring fitted it's still relatively low but not impracticable as before, repairs are complete, now just sanding and sanding. Got a scare reading the dangers of two pack so may take the outdoor spray route and sacrifice a little on the finish, better to be alive and see it....
30 Mar 2016, 5:48pm
In keeping with the Sammio ethos I've managed to up cycle the herald inner glass lenses into indicators for the spyder,
1 Apr 2016, 5:19am
Pops - By all accounts you should be very careful indeed if using 2 pack paint in a domestic setting. :eek:
Sorry to hear your "slammed" set up caused you a few problems, but nice work on the front indicators. :cool:
I'd like to see how far your tail pipes stick out now, as this is my set up.
1 Apr 2016, 7:08am
Paul
This was before, will have an after shot this evening....pretty sure yours are already shorter than mine began, must be another difference between Herald and Spitfire
1 Apr 2016, 5:38pm
Paul, this is how the exhaust ended up, much happier with this length tail pipe, be aware if you shorten the y piece and pull in the box to reduce length the up turn of the tail pipe increases, this ended up in me rearranging the cut outs in the apron and remodelling the previous work I had done..
1 Apr 2016, 5:42pm
Continued rubbing down today removing brush marks from the gel coat, dissapointingly found stress cracks in the front quarter panel, believe this is where the body wraps tight around the framework, gauged out and filled, unexpected but better to find and fix now than after painting
2 Apr 2016, 7:25am
Pops - Thanks for the photos, looks like we've ended up with a similar length.
In terms of Spitfire vs. Herald, my exhaust is the standard set up, but there is no room to move the silencer boxes back any further.
( As they would foul the chassis. )
Good luck with the rest of the body work preparation, Paul. :)
13 Apr 2016, 5:17pm
Now the nice weather is here and the nights drawing out
Thought I'd take a brake from sanding and filling and spend some time on the cockpit, instruments wired up only to find Tacho was broken so time to fit substitute, problem the new one was smaller diameter then original cut out so some new ideas needed, managed to fit the new Bezzle into the old so although doubled up its functional and fills the hole, starter button fitted and working main beam and indicator light on dash,
Sourcing parts over here is a nightmare car carpet ordered from eBay but shipping same cost as purchase☹️
Hope to have etch and primer on soon so I can see where I am with rubbing down, will be a great boost to have the car all one colour even if t is just primer....
14 Apr 2016, 3:01pm
Pops - Getting the whole car in primer will make a big difference and is a great boost to morale. :cool:
16 Apr 2016, 1:34pm
Glad to see you're back on track. Also been suffering from 'lifegettingintheway-itis' so quite inspiring to see there's a way forward! Will be down your way this Summer - PM me if I can help with any parts transport.
Richard
16 Apr 2016, 6:56pm
Richard, very good of you to offer thank you, there are a couple of bits I need but will have to wait to see how funds are nearer the time��
28 Apr 2016, 8:08pm
At last something to update, was not happy with my rear end something was not right so after a long time planning decided to take the plunge and shape the rear apron cutting it back by about 30mm, recut the exhaust again and made up a shield to go around the pipes. Finally decided to move the number plate light previously stuck directly to the body I thought I would try forming a shroud and mount it on this, this altered the angle thinking I will try and find a red lense to fit and make a third brake light in the centre, overall quite happy with the results and feel it's a bit more pleasing to the eye..
From this
To this..
Pops
28 Apr 2016, 11:03pm
I like that Stewart
But I am biased and it reminds me of my old roadster
29 Apr 2016, 7:08am
Pops - I really like your tail pipe shield. :cool:
And it is good to see your build making regular progress again.
Which reminds me I never replied to your post on the sticky thread. :rolleyes:
Oxford is the one person who I know is still building, but not posting.
Although I'd love to know how other builders are getting on.
29 Apr 2016, 5:46pm
Roadster, Paul thanks for the positive comments I'm keen to keep to keep the rear simple much like the roadster
Rubbing down all day today paying the price for being over enthusiastic with the orbital sander as the swirl marks are quite deep and a nightmare to remove. Not sure how deep a mark the high build primer will cover but at the moment 600 wet and dry seems to be the answer but weeks of sanding ahead......��
Pops
30 Apr 2016, 9:38am
I love the tunnelled tail lights Pops , thats a nice touch . Centred exhaust looks cool too ...some nice little features that make all the difference ...
Bodywork is a ball ache ...I hate it ...but it is always very rewarding at the end ...dont bust yourself up about getting it too perfect ...If you look at the genuine cars of the period , not the over restored investments that turn up at Auction , but a day at Goodwood types ...they are not finished to a high standard ...and , in my opinion , look better for it ...
