Scottie's Tribute A352 build
14 Mar 2018, 11:00pm
Overdue update
Ambi-TAS
Barber
and Car Snapper Thanks for the concern and interest!
I really do appreciate it! It was a bit of a surprise to see my thread on
the front page again and even more surprising to see that somehow its
clocked up well over 300, 000 hits!!
I did not realise that the A352 was so popular!
Health-wise I am fine, work-wise ( XK orientated ) I am a total disgrace
to this forum!!! I have done absolutely NOTHING all winter!!
Yesterday a friend of mine said “in two weeks time it will be April” “I
think you should do something on the XK” And of course he was right.
So I ordered a new water pump for the “new” engine, (which at present is
outside wrapped up in blankets and waterproof sheets)
I spent several hours clearing out the shed next to the tent where the XK
lives, with the intention of transferring the engine to the shed so I can
prepare it for installation.
Painting it a nice colour, putting new plugs in it, putting the dizzy on etc,
bolting on the new water pump, (when it arrives) complete with painted
housing. All that sort of stuff.
So that's where I am at present, I am making an effort, but after being in
denial for so long over the XK it's taking a bit of getting used to!
I always seem to have several other projects on the go at the same time,
so its a bit of a juggle to prioritise and fit them all in, but I am going to
have to do the XK.
Watch this space...............
15 Mar 2018, 7:24am
Scottie, great to know that you have a plan about to kick in. Hooray, it will be great to see pics of the car on the road again.
20 Mar 2018, 8:37pm
Good to hear from you. Your build diary has been fascinating, and I'm not surprised you have such interest. You have certainly inspired me, though I'm considering something that, given my much more limited experience, will be something more of a challenge!
22 Mar 2018, 9:55pm
Scottie22 wrote:
Ambi-TAS
Barber
have to do the XK.
A wise man once told me that you should finish one project before starting the next.
What rubbish, having multiple projects is the spice of life!!!
7 Apr 2018, 7:48am
Loved That Video!
Thanks for that, Paul. No hype, just enthusiasm for his fabulous recreation oozing from every pore :).
I was buttonholed by a guy my sort of age (ancient) in Aldi car park on Thursday. After chatting for five minutes he had to go, his comments having included "It sounded great" and "You've made my day".
We're fortunate indeed, being able to indulge our passion!
Regards, Mick
24 Apr 2018, 5:39pm
Thank you for the video Paul!
I have only just seen it. It is indeed a good inspiration!
Like the man says. it may not be "real" or, ( in my case) as fast and powerful,
BUT it looks and sounds the same, and most important of all
IT GIVES YOU THE SAME FEELING!!
Good luck to all you A352 builders!!
Scottie
17 Oct 2018, 2:10pm
Hi Scottie, I've scrolled back through pages to page 100, and the only reference I can find is that it's 'industrial colour' - can you tell me (just out of interest) what brand/type of paint you've used. Like the result BTW
20 Nov 2018, 2:42pm
Hi Scottie,
I have recently found your story,and spent days reading it from start to finish. May I say, you are an inspiration to anyone with an ounce of soul and ambition!
I must tell you about my experience on my 1500 triumph engine following the build of my Frogeye Sprite replica. I had taken the head off to check the condition, having never run the engine before. I had finished the build, and used a MG owners club Gasket set to rebuild the engine. It went onto two cylinders after only 20 miles! I stripped and rebuilt that head three times before I discovered the problem. I had been supplied with gaskets for the flathead 1300 engine, which will not seal the 1500 recessed liner engine. After fitting a genuine Payen gasket, and retorquing when hot, no more problems. This was a very well known problem back when Midgets and Spitfires were everywhere, but I was not aware of it. Like you, I became despondent about the car, but decided to sort it out, and Im so glad I did. Hopefully, you will find time to sort your wonderful creation out, as I would love to see it myself!
Bernard,
Ex RAF, 22yrs
Six kitcars
Three Homebuilt Aircraft
20 Nov 2018, 4:52pm
I must apologise for not being on this thread for weeks and weeks,
so sorry for that!
I still have not put the bloody engine in the XK, that will most likely be in the spring now.
Mitchelkitman : I take it you are wanting the colour and type of paint I used on the XK?
I have the old original tin in front of me now, and it says on the tatty label " BLGN 18 "MAC 5"
It came from a company called "Border Automotive"
I asked for "A really dark British Racing Green" and this is what they gaved me.
I was told it was the modern replacement for celloluse and it
was air dried, I sprayed it outside on my driveway, and got the usual flies, grass and rubbish stuff stuck to it, but it cleaned up pretty well. The tin cost me about £35 which has to be a record for a spray job like I ended up with!
I put two or three coats on so I could mop it back to a good shine which worked well, I mopped through to the primer in a couple
of places but you have to look close and hard to see that!
Chipsairhead: Thank you for your kind words!
I wonder if having rebuilt my 1500 head (when the head gasket went) I wonder if that's why it overheated faily quickly down the road?
Anyhow I now have the trusty and proven 1300 mega-revver
which will eventually find its way into the XK so hopefully should not have any further trouble!!
21 Nov 2018, 1:59pm
Hi Scottie,
When my head was blowing, it blew between the cylinders without breaking the water seal, so I drove home from Stoneleigh on two cylinders!
The next time it blew, five miles after repair, was the other two cylinders, so another slow drive home!
By the way, why have all the photos disappeared from your posts? I have tried every trick I know to get them back, but they seem to have gone. Is there something I should be doing on Photobucket?
Chips
21 Nov 2018, 2:17pm
chipsairhead wrote:
...By the way, why have all the photos disappeared from your posts? I have tried every trick I know to get them back, but they seem to have gone. Is there something I should be doing on Photobucket?
Forum search is your friend here.
21 Nov 2018, 2:34pm
Hi Ian, so does this mean I can no longer view Scotties photos? I had no problem until a couple of days ago.
Chips
22 Nov 2018, 8:20am
chipsairhead wrote:
...so does this mean I can no longer view Scotties photos? ...
It means that Photobucket no longer passes the image to third party sites unless a subscription has been paid.
The enforcement seems random- early pics on my build thread are still visible (for now?) and they are hosted by PB and I declined to pay the sums requested.
I use tinypic now but I understand that their service has been inconsistent lately.
22 Nov 2018, 1:14pm
Thanks Ian, I note that some of Deggsys photos have also vanished. It's a shame, because these threads are a fantastic incentive to prospective A352 builders, like myself.
Thanks for clarifying this for me.
Chips Carpenter.
22 Nov 2018, 8:25pm
The new CEO of Photobucket reversed that decision (after his predecessor was fired) and they should all show now - try refreshing the page if they don’t come up first time (a quick look on page 2 shows them all on my screen)
22 Nov 2018, 9:01pm
scimjim wrote:
The new CEO of Photobucket reversed that decision ...
That's good news- not totally unexpected as the jump from free to $99 per year was obviously not going to fly commercially.
Apologies for diverting the thread Scottie- best rectified by some more pics of your super car- please.
22 Nov 2018, 9:09pm
Hello all,
I also just noticed that my pics have flown, I have asked Paul for help as he seems good at photobucketing around! I am in the process of trying to restore the pics and will try posting some new ones when I get time!!
22 Nov 2018, 9:10pm
$399 pa was the business model that killed Photobucket - latest pricing is $4:03 a month for 2GB $5:83 a month for 20GB and $10:33 for 20TB
22 Nov 2018, 9:13pm
Chips airhead,
when my Triumph head blew it made a one-inch gap in the gasket between 1 and two so I also limped home at 20 mph on 3 and 4.......
with other motorists giving me V signs and moaning 'cos I held them up!
22 Nov 2018, 9:17pm
Chips: forgot to mention that when it overheated again, I thought f**k it and had a 1300 engine rebuilt, so I still dont know what or even care anymore what it was!
And a big thank you to "Oxford" for the the kind donation of that engine for a crate of beer!
