Scottie - Whilst I still like the original "holey" grille that I was planning to fit…
The mesh grille does look a lot better (& more period), even if the photos struggle to show it properly.
Mick - That is a brilliantly simple idea, so thanks a lot for posting it.
You will see below that I have put the electrics into the "come back later" pile, but it will be fixed at some point.
There is quite a bit to cover today, so here goes…
A Plan Insurance:
Mister Towed recommended this firm years ago and, as of today, I am finally insured with them.
The comprehensive policy they found covers me for both the final "under construction" period and then "on the road" too.
Which means my insurance is now in place for the day I finally drive the car to the MOT station (whenever that may be).
Now there are lots of reasons
not to build a kit car on your driveway, the weather being the most obvious one.
However, the real risk is that no insurance company will cover, what they call, an "under tarpaulin" build.
The fact the car was just sitting outside uninsured was becoming more of a worry the further the build went on.
Even when I got the V5C back from the DVLA, they still were not able to find anyone to cover it.
But, thankfully, my recent short
YouTube clips and photos highlight how close the car now is to being finished.
So that is a huge weight off my shoulders and you will now see my number plate appearing in the photos.
( I didn't have the technical skills to blur the plate in the last video clip.
Friday- Part 1:
Spent some time working out the best place for my "stick on" front number plate.
The tape near the nose of the bonnet represents where a 2 inch deep yellow band around the nose would reach.
This allowed me to mark up where the corners should be.
Before I finally stuck it on, although I've left the protective cover in place for now.
This is a temporary arrangement for two reasons:
- It will be removed when the time comes to finally paint the car.
- This is my original donor car registration and it will soon be replaced with a "C" reg. number plate instead.
( However, I need an MOT before the DVLA will let me change my V5C. )
Covered up the scuttle to protect all the shiny bits fitted.
I tested my largest drill bit on a spare bit of metal.
To see if this was the right size for the rubber grommets I had.
Before drilling a "drain hole" in each of the lowered floor pans & giving the fresh edge a lick of Kurust.
The grommet will be fitted upside down, as the seat will make it harder to reach this point from above.
( Note: I still need to tidy up the area around the hole. )
So the grommet is effectively reached from underneath the floor instead.
End of Part 1…
