Jones - Thanks, I can't quite believe how fast the driver's side is coming together.
Unfortunately, we were poor, so no fancy Meccano sets, or things like Scalectric for me to play with as a boy.
Still, at least I've got a very big toy car to play with now.
Tuesday Morning - Part 1:
It was been a very busy day, balancing my car and domestic chores.
Started by removing the "Meccano" from the body shell side extension.
Which gave me my first view of the open wound.
Note: I have only one small section of the original arch left to play with.
Made a cardboard template to fill in the gap in the bonnet, that would "wrap around" that small arch piece
Cut the panel out of what remains of one of my fibreglass floor pans.
Unfortunately, due to the angles involved, if the bottom edge lines up, the top edge doesn't.
Thankfully the experience I gained on the passenger side taught me two key things:
- Any high spots can be ground down.
- Any low spots can be built up.
So I just cut the panel in half.
Came across one small technical hitch when I tried to fit a screw near here…
As if I tightened the screw fully in, it would join the bonnet to the body shell!
So when I fixed all these brackets in place, there was "a screw loose".
I can't sing the praises of this stuff enough, it really does make this work much easier.
( Although it does take me a while to work out the best way of connecting everything.
Then I could open the bonnet, tighten the last screw and then cut the bottom of the screw off.
Which allowed me to lower the bonnet back down without anything fouling the body shell.
Note:
The bottom corner of the bonnet is deliberately 'oversize' so that I can trim it back to shape and add the curve later on.
Thankfully, the inside of the bonnet looks much better than the outside.
End of Part 1…
