Fatbloke builds a Spyder
5 Jun 2016, 4:12pm
Thanks Paul. I agree, as long as it is finally all one colour I don't really care and after I sanded back the bonnet quite dramatically the orange peel disappeared.
Mazdarazmataz, I gave it about 24 hours between coats but only gave the surface a very light sand with 400 grit between coats to give it a key. For the deep sand and polish, I left the bonnet for a week to harden.
BTW, just had a look at the website where I bought the paint and I bought the wrong thinners - oops. Here's a link to their site with all the tech info:
https://www.promain.co.uk/combicolor-7300-smooth-gloss.html
5 Jun 2016, 4:24pm
Thanks for info, always been curious about coach painting techniques.
Shows how ignorant I am, I thought thinners were thinners! Didn't realise there were different types..
5 Jun 2016, 5:58pm
I do like that colour, it's going to look stunning once it's all painted. Is it Fiat Broom Yellow?
5 Jun 2016, 6:02pm
Thanks Mr T. It was the brightest yellow on the Rustoleum colour pallet so isn't car specific.
5 Jun 2016, 6:09pm
Here's another question, what quantity of paint do you guesstimate you will use?
5 Jun 2016, 6:15pm
I've bought 5 litres of primer and colour. I'm hoping that will give me 2 coats of base and 3 of top coat.
5 Jun 2016, 6:18pm
Hmm so roughly the same quantity as if you were spraying celly or 2k
Your colours better than the JCB yellow we use at work ;)
5 Jun 2016, 6:21pm
Five litres of paint mixed 50/50 with high-gloss thinners did me about six coats (I lost count). That was sprayed on though, you might get through more paint using a roller. Or less :noidea:
5 Jun 2016, 6:23pm
I would say less because no overspray? But hey this is pioneering territory!
12 Jun 2016, 6:37pm
First coat of rollered primer applied.
12 Jun 2016, 6:41pm
YES! Woohoo. Wish I was at your stage!
12 Jun 2016, 6:49pm
Taken me over 3 years to get to this point mazdarazmataz so don't beat yourself up on how slow it fast the build progresses.
12 Jun 2016, 7:30pm
Some of my favourite Ferrari's are yellow ....interested to see it done ...
14 Jun 2016, 3:37pm
Well, I said it would be yellow... ...and it is!
The orange (lemon?) peel is quite bad but as I discovered on the bonnet of you get enough paint on you can cut this back. One other note of caution, if you are painting a really bright colour with the garage door open the flies love it. These can be removed when the paint is dry with a little bit of wet and dry :icon_lol:
14 Jun 2016, 3:43pm
Good job!
Can't wait to see pics of final assembly
14 Jun 2016, 3:53pm
Looking good! I bet you're chuffed getting it to this stage - It will look good all trimmed up.
14 Jun 2016, 4:26pm
Thanks guys. The photographs hide a whole host of horrors but I think most of these can be sorted once the paint has properly hardened and i can cut it back. Only two more coats to go.
14 Jun 2016, 4:31pm
The narrow boat chappie did light brush strokes after the roller application. Are you doing that or just depending on volume to cut back?
14 Jun 2016, 4:40pm
Lovely colour, it's going to look fabulous on the road.
14 Jun 2016, 4:45pm
Just looking to get a good, thick layer with the roller to allow me to cut the surface back off. It worked quite well on the bonnet, although the edges are, inevitably, thin.
14 Jun 2016, 5:15pm
What sort of roller did you use ? Was it one of those more solid foam types ?
Did you flat down the primer or not before the top coat ?
Looking good though, wait a few weeks before wet n drying.
14 Jun 2016, 5:30pm
High density foam rollers. I removed the lumpy bits from the primer but didn't flat it as I knew the gloss would be just as orange peeley (is that a word?). I'm going to give at least a month to harden before going near it with and wet and dry after the final coat.
14 Jun 2016, 6:09pm
It would make the process long and more laborious but I would let it harden between coats and flatten back. I believe from my limited experience of painting (please note only spraying not rollering) is that if you paint over the peaks and troughs of the orange peel will just be accentuate the peaks. This means when you come to do final flattening back you would be more susceptible to going through to primer if attemptingto get a true flat surface for depth of shine.
This is just an uniformed guesstimate so feel free to ignore.
14 Jun 2016, 6:25pm
Cheers, all advice welcomed.
14 Jun 2016, 6:58pm
Oh, please.
Light coats, let dry and flatten.
Another light coat, etc.
Saves labor in the end.
