Garyh's Sammio build
20 Nov 2012, 2:18pm
Paul, did you get your mounts made? The fit of the engine looks really good and no cutting of chassis. I'll see if i can get the good lady to give me my allowance.
20 Nov 2012, 5:07pm
Where did your gear lever end up and what's the prop line like?
20 Nov 2012, 9:17pm
Can i use the triumph clocks? Those mounts look simple enough to make. Paul have you used that build to go by?
20 Nov 2012, 9:38pm
You can, it is more difficult, but there are a few that have done it, this blog is one example; http://gt6transformation.blogspot.co.uk/search?updated-max=2010-02-22T19:57:00Z&max-results=7
I have tried to use everything from the Mazda, so have swaped the fuel tank complete wiring loom and dash, seat belts, steering column and brake master cylinder as I want the reliability and driveability of a modern car. Hopefully most of it will be hidden and I'll still have the classic look though!
As you can probably tell by by the different links, I have googled and researched it a bit and there is alot of people doing this type of conversion, did you notice the engine mount one is in New Zealand!!
20 Nov 2012, 10:36pm
I have a slight concern about the DVLA's approach to welding on engine mountings. We know that even when the regs are clear individual centres can take very different positions.
Someone like Speedy cables can make up a hybrid Mazda/Triumph cable and recalibrate the speedo to suit. I don't remember how the Triumph tach is triggered, it may not be directly compatible with the Mazda ignition. There are adapter circuits on the web.
20 Nov 2012, 11:02pm
If the welded mounts are an issue this sort of thing would be a solution.
21 Nov 2012, 9:19am
The Triumph Tacho is mechanical - cable driven off the distributor. There are lots of electric tachometers on ebay though, including seven inch 'monster' tachs starting at about thirty quid. I had planned to use one of those myself, but couldn't find one that didn't have modern graphics on the dial, ususally including the words 'Type R'. It's probably relatively easy to repaint/reprint the graphics, but I ended up fitting a Porsche 550 style three gauge dash in the end so stuck with the Triumph tacho.
Engine mounts look great btw. :biggrin:
21 Nov 2012, 9:24am
Engine mounts, not very elegant... Still don't what to do, trying to keep cost down and wife off my back! Does anyone out there have a MK1 Vitesse cylinder head in good condition that i don't have rebuild...
21 Nov 2012, 9:30am
The Spitfire 1500 tacho is electronic and fairly inexpensive. (Also looks the same as the earlier ones) I got one off eBay for about £20
21 Nov 2012, 9:32am
No to the cylinder head, I'm afraid, but there's a complete 2500 engine going cheap on ebay -
http://www.ebay.co.uk/itm/Triumph-Spitfire-GT6-Vitesse-Herald-2000-PI-2-5-6-Cylinder-Engine-/221155441378?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item337de43ae2
21 Nov 2012, 1:52pm
Remember you can swap the suspension towers to have the mounts at the back where they might line up better and the DVLA shouldn't object to any mods to them because they're a bolt on part (doesn't mean they won't try).
The MX5 engine is quite retro looking for a modern twincam. It doesn't weigh much more than the inline four Triumph either. A set of DCOEs or throttle bodies and a Megasquirt would probably allow it to fit with no bonnet cutting.
21 Nov 2012, 6:08pm
The MX5 engine is quite retro looking for a modern twincam. It doesn't weigh much more than the inline four Triumph either. A set of DCOEs or throttle bodies and a Megasquirt would probably allow it to fit with no bonnet cutting.[/QUOTE]
Or this is another carb solution;
21 Nov 2012, 6:19pm
That is a very neat installation. Is it running a Triumph or Mazda diff?
22 Nov 2012, 9:41pm
It's very interesting, he' been at it for along time...
14 Dec 2012, 5:46pm
got too get one now lol
14 Dec 2012, 7:11pm
A t5 volvo would be interesting lol
14 Dec 2012, 9:08pm
That's just bonkers. I love it. :yo:
24 Dec 2012, 12:01pm
Merry christmas to everyone, hopefully we will all get to work on our cars...
Here's a good short film to watch that I saw on Forgotten Fibreglass website forum that I look at from time to time.
http://vimeo.com/49357431
1 Jan 2013, 7:26pm
I really believed that i would have tons of time to work on car... the couple of nice days we had, i had to do other things. I have sprayed lots of bits and i am now going through all the boxes of parts to start piecing it back together. So i have cleaned clocks and lights, reflectors are actually from the early 60's.
1 Jan 2013, 8:46pm
Thanks for the link to the vid Gary. Not sure if the overtaking at the end was staged or real! Anyway good fun.
Re progressing our cars over Christmas, I have yet to hear anyone say, oooooh, I got so much done. In fact, quite the opposite!
Nice reflectors.....very fine mesh. Are those rear lights going on vertically or horizontally?
N
1 Jan 2013, 8:57pm
Evening Nick, I thought I was going to get 3days on car and go for a walk everyday! First walk today... Nice weather, back to work tomorrow. Lights will be vertical. I will be doing lots of cutting of body work all over. Wish I could make more progress. Blog started 2011.
6 Jan 2013, 7:25pm
Started to put some parts together, need more money to order brackets etc... from Canley, next week painting hallway to raise cash.
I quite like the look of the wheel with everything on, maybe spray trim ring to match rim.
This may look to Hot roddish!
Adjustable tie rods are finished, have ordered some heatshrink to cover joint when set up.
And wishbone/hub carrier made up.
on my rotoflex set up i need to fit shims, does anyone know how to measure the ones required?
