Latest progress on the Gooster
17 Dec 2009, 8:43am
Fuel gauge light looks OK to me.
I think if C4 is32uF, R8 is 500M and RV3 is 500M then you would have a delay variable of between 20sec and 40 sec.
Using two comparitors like that will be a much better solution than the single comparitor solutions you had earlier.
To drive the fuel gauge in a similar manner will require an analog circuit, but could be feasible.......
18 Jan 2010, 6:52pm
First real work of the new year - I fitted the front bumpers tonight. Considerably easier than the front ones, even if it dod mean taking the driving lights off and unhooking the top wishbone!
I think I may try some carpeting tomorrow, now that the temps are coming back up and the glue might have a chance of going off. :)
18 Jan 2010, 10:37pm
It's good to see someone has made it into the garage! (but we need pictures as updates on this forum are becoming rare)
Get your IVA booked, as we want to see you in the Gooster at Stoneliegh this year. :smile:
19 Jan 2010, 12:58am
updates
Happy New Year to all....want to put some pics on forum..how do I do it directly without links to remote gallery?jeremy
19 Jan 2010, 8:14am
Jeremy - as long as they're not too big, you can attach them. Click on the 'manage attachments' button under the thread reply box and you'll be able to specify the files / images you want to post.
You could always get a flicker account as well, and then use the standard
[img][/img] tags with the url to your image within them.
Peter - I'll try and take some pics tonight after work. ;)
19 Jan 2010, 6:55pm
Here we go:
They've been mounted so that the lobes on the back of the bumpers are 25mm away from the fiberglass of the nose cone.
Each side has been shimmed with ali, and an M8 stainless cap head holds it in. The other fixings are for the driving light brackets, which have been removed and are in the process of being painted.
When I rubbed down my filler patches on the tub, I managed to find some more voids that needed filling! There's a fair bit of the fiberglass based filler and some P38 around the reversing light recess now. Just hope it paints up OK...
19 Jan 2010, 9:12pm
Those bumpers look nice, I think Mark has done a good design job on them, meeting the new IVA spec without looking out of place.
You seem to be unlucky with your GRP tub, as I haven't seen that problem on mine. But maybe that's because I haven't rubbed any of it down?
I'm sure a good body shop will fill it and flatten it so it won't show when painted.
Got that IVA form filled in yet :wink:
19 Jan 2010, 10:00pm
I haven't even got the form yet! :) I guess I need to get one sent to me from the local DVLA office. That's where you get them from, right?
19 Jan 2010, 10:54pm
I got all my (SVA) forms from Swansea. They sent me a whole pack with instructions and all the forms you need. If you can get through to the right place there is a small department that deals with kit cars but I don't remember it being too difficult to get all the forms first.
20 Jan 2010, 8:32am
Yeah, you can get the forms OK from Swansea. Only problem I had was some jobsworth wasn't convinced I had built the car myself and more or accused me of having it built for me.
I had sent copies of the donor V5, invoices for the kit and a few build photos with the first application.
In the end I sent another pack in with EVERY photo I'd taken, and a letter from my wife saying I had spent 7 years in the garage and she would be really pleased to see me again.
20 Jan 2010, 9:39am
I've just downloaded the Amateur Build Declaration and IVA Application (M1) forms, along with the guidance notes.
Just glancing through them here at work, I've noticed there's no where to declare what bits came from where. Is this on another form I need, or is it just when it comes to registering the car later on?
20 Jan 2010, 11:21am
Other questions:
I was going on other figures posted here, and decided on axle 1 = 500Kg, axle 2 = 570Kg, total of 1070Kg. Seem reasonable? I know Peter put 600 down for the rear axle.
Top speed - I reckon she'll make .5 past lightspeed and do the Kessel Run in less than 12 parsecs. But what's the consenus on Sublight velocity? :)
Max Power @ RPM - I'm sure there's some figures in the Bently manual, but I also recall some debate on here about it. I just can't find the thread it was in! Can anyone remember so I can go and refresh my memory?
20 Jan 2010, 12:31pm
DVLA are the ones that require the list of components, not VOSA, except to prove the age of the engine for the emissions test.
DLVA require the list so they can allocate an age related/ Q/new registration. Provided they know their own rules, as they didn't in my case and I had to argue for an are related plate.
If you don't know max power IVA will test your noise level at (if I remember correct) 2/3 of your max RPM.
Make sure your tyres are capable of doing your declared Max Speed. They don't test you max for the IVA (you would need a race track!). I stuck an arbitary 112 mph down as it was the max of the donor car.
Whats the sidewall letters for 0.5 lightspeed?
20 Jan 2010, 1:05pm
Jason
You should be OK with your car as it is a single source donor, so you will be able to prove the main components all came from the same source, (with the donor V5) and will be able to get an age related plate. Proving the age of your engine will be important with regard to not requiring a CAT.
Mike
20 Jan 2010, 6:31pm
GreatOldOne wrote:
Other questions:
It's a parsec a measure of distance rather speed... I digress :madgrin: what ever you put down as max speed make sure it's lower than your tyre speed rating. I think I put down 120 Tyres were rate 130 :)
Weight wise it's worth putting more at the back to be sure as I failed on hat first time :)
20 Jan 2010, 9:36pm
Awesome episode of Family Guy. Not seen the Empire Strikes Back one yet. Stewie as Darth Vader is just (to coin internet speak) "so full of win". :lol:
20 Jan 2010, 9:53pm
GreatOldOne wrote:
Other questions:
I used the following:
Design Weights:
Front Axle 550Kg
Rear Axle 700Kg
I came to those figures following a small survey of cars that had passed and failed. Mine passed wih no questions or head scratching on this point.
Top Speed must be less than your Speedo and tyres. Just put something sensible as they won't test it.
I think Max Power for the BMW engines is at 5800 RPM. It's in the BMW user manual I got with my donor car. Don't put this figure too high as it defines the RPM they use to test the noise.
..hope that helps...
...peter
22 Jan 2010, 11:16am
I spent last night fashoning my rear wing extensions.
I thought I had some ali sheet left, but it turns out it's stainless. It's a fudging pig to cut. I lost count of the number of jigsaw blades I burnt out (literally in one case - it was glowing, even with liberal doses of cutting fluid! :dizzy: )
They're not quite there yet, but it's going to work. I just need to bend the sides up to make the portion that gets clamped to the underside of the wing a bit more ridged, and I think it'll be OK. As it is now, it goes below the 150mm reference plane. It's just a a bit floppy and skew-wiff.
I'll post pics at the weekend once they're finished.
22 Jan 2010, 5:37pm
Ok, here they are:
Not the prettiest of things, but they should tick all the boxes regarding the shortcomings of the sportster rear wings and IVA
They're held on by the light pod and the bracket that clamps it to the wing, so they're bound to fall off at some point in the future. ;)
24 Jan 2010, 6:50pm
They look very good, well done!
Mounting the reflectors on them make them look permanent.
(Don't forget to buy some new reflectors if the extensions fall off :wink:)
...peter
25 Jan 2010, 7:27pm
nice, I do like the reflector mounting :D
