Following on from a subject touched upon on my other thread on here regarding the Sammio Spyders - I have decided to start a new thread covering our new project , The working title is SAMMIO G46 - That might change !
The new body is being developed to fit the Scimitar SE5 chassis and running gear...The SE5 is 99'' wheelbase as opposed to its SE6 sibling that is 103.5'' ...The later version has been adopted by the Hot Rodders as its pretty much Ford Model A or Willys Coupe dimensions , as well as being only 2.5'' shorter than the Ford Model B chassis...we are using the shorter chassis as it is dimensionally more appropriate for our needs being slightly shorter and a few inches narrower as well...This is still a big car though at approx 14' long !
The project is concentrating on body production at present ...it is being built in the same way as the Spyder , a replacement body for a stock Chassis ( no mods at all - many people using these chassis remove outriggers and the fuel tank - not us !! ) The body will rely on the Scimitar bulkhead in the same unique way the Spyder does and the example we are building currently uses the entire Scimitar floor as well - its there , we may as well use it !......The cars will undergo a re-name only , no IVA , still retaining original registration , tax exempt where applicable etc. etc....This body will feature , seperate double skinned doors a bonnet and maybe a bootlid as well !
My colleague and myself have started shaping the body up ...we are using lots of foam strips to get the voluptuous curves of a mid 50's car that I am looking for and work is moving on steady inbetween 'proper' work...
Heres some taster pics , you need to use a bit of imagination at the moment , but I'm really pleased with the way its shaping up so far....
I'm not sure how far these will be developed as a 'kit' yet ....initially bodies and sundries only and we will build some turnkeys as well ....prices are to be confirmed but initial calculations suggest that a full bodyshell with accompanying panels etc in an extra thick layup should be around the £1500-1600 mark
Paul ....Having Mike on board has helped ease the workload - still doing 55 hr weeks though most weeks.
The Scimitar based kit won't be as popular as the Herald one - price and build level are different....There are surprisingly quite a few SE5's around ...since we started I have bought 3 ...a nice one for £700 , not so nice £200 and horrid £50 ! I have been offered about 5 others as well ....they are out there.
Both Herald and Scimitar share a similar chassis in design and make it ideal for avoiding SVA/IVA etc....they also both fit into the category of costing more to restore than they are worth restored - keeping prices reasonable for now....
Its looking great,
How long do you expect before its completed?
I have already spoken to you about the rear section to fit to my mx5 based special - my jag front end is well under way and now I have seen the progress on the rear of your car its a definite.
So I want to put my name down for the second rear out of the mould.
No deposit reqd. thanks , just let you know when we are ready to go....
The tank causes a few issues with the boot area , but there is a massive loadspace doing nothing under there ( rear seats originally )..so we may try and fit a boot incorporated into the headfairing , perhaps or just to one side - not sure yet....will probably be a lift out panel rather than hinged at this stage...
A lift out panel would be very useful but i wont ask you to make it specially as I will be ready for the back end as soon as its made,
Is blanking out the fairing going to be a problem as i need to cut this area away for the hood?
Blanking out the fairing will be pretty styraight forward ...we have done it a few times with the Spyder - you get some scarring , but not too bad ...a bit of a tickle with some filler and alls good.....
I am leaning towards creating a bootlid that will be part of the headrest , so your body section would need to be moulded slightly differently but , you could create a bootlid fairly easily - difficult to explain without standing next to the car , but we would create the apperture for you as well....
no problem as soon as you let me know i will come down and finalise the changes.
Im sure when all prepped and painted , everyone will think it was designed bespoke.
Is it still looking to be complete in 6 weeks? or have i slightly longer to wait?
We are forging on - no pun intended ...actually not relevant as we aren't copying anything ( stop rambling Gary !! ) .......
I have taken the reins of general kit production and customers projects for the last two weeks to enable Mike to carry on with the G-46....He is doing a fantastic job...it is very rewarding to see your ideas coming to life in front of you and I am very lucky to have someone on board who , not only has an equal interest in the car and 'gets' the design , but can shape up a body exactly how I can picture it and often without needing much prompting from me ....Mike totally knows how this car should look and can make it happen...His input has been invaluable...
We still have a couple of design elements to play with - we think the car needs side vents on the front wings , its a big car with large areas and a bit of wing detail will help break it up a bit , plus the V6 will need to get rid of hot air as well...The vents drawn are our initial idea ...I like the 'porthole' idea - mid 50's Buick style , not sure the car needs a big vent like some , just a suggestion of breathing holes really ....trying to avoid 'gills' as the car looks enough like a Blue Whale or Great White as it is !!
Here's some pics ...
The way the wing flows into the grille mouth is an area I am really pleased with ..the smallish opening has great lines ....And look at the way the wing climbs from the door and flows back down again ....the 'coke bottle' effect combined with its silhouette make this car just so beautiful ...Im my opinion , of course , and I am a bit biased !!
The exhaust's exiting through the rear valance is a little detail that I really like and they are the stock Scimitar exhausts....the body has been totally formed to fit a stock chassis , outriggers , fuel tank , exhaust etc - all as they were .....
Apologies for gushing - I am so passionate about this project , it is hard to not to .....
Should start moulding the body in the next two weeks - hopefully..
I was planning on using austin 1300 units on there side but i think the rear wing doesn't finish as flush with the rear like the spyder so i might have to re think or get the resin out
wow she looks stunning gary, half of me wish i waited and built that scimitar,HEY ANY IDEA`S ON THE SEAT`S,
Build the Sammio , run it for a year or so ....sell it ( we just received a deposit on the red one at a sale price of £6750 and thats not as nice underneath as yours is going to be....well £7600 delivered to Stuttgart , actually ) and then build a G-46 .....More than happy to sell you another project , Gary !!!
Garry can we have more pics please especially of the rear ok im biased because its the part im waiting for - but i need to keep the creative juices flowing as i pick the resin and glass from my hands.
I love the idea of a 'supersized' Spyder with the G46 project. It looks a little 'D-type ish' and the size of the beast means it will have road 'presence'. There must be very viable market for this type of vehicle. The idea of using a Scimitar as a base vehicle is inspired - it's all there, just waiting for a change of clothes.
Thanks for your kind comment. Will give you a call once I have obtained a suitable donor (probably September).
I'm looking forward to seeing photos of the finished prototype and wonder if you plan to create a 'walk through' of how to put one together; similar to your picture spread on the Spyder build (when time permits!)
I saw the updated photos on the web site and it's all looking very nice!
I must make sure that i have a good nosey when i'm down next Wed, although i think i'll leave my wallet in the van as i've promised the wife that once the Spyder is on the road in a few week i'll do a few more family things before i even start considering another project
Whilst reading back through this thread , I realised that I hadn't put a picture of the stripped out donor car on...
Its different to the original Sammio - this time we use bulkhead , floor and inner arches , inner cills etc...the new body bonding to the original with a smaller steel hoop frame...
