Old 10th October 2017, 09:57
Mistrale Mistrale is offline
Mistrale is on a distinguished road
Oh god here we go again
Oh do indulge me, please? I realise the issue of IVA and the Sammie has been covered, but the question I was asking relates to the peculiarities of chassis on the Scimitar.
If you re-body a Z3, IVA not required.
If you re-body a Z3, but remove the windscreen surround - IVA is required as it is deemed part of the structure.
If you re-body a Spitfire, Herald etc. , the screen comes off with the body so it is not part of the chassis - IVA not required.
On the SS1 however, the screen IS attached to the chassis..... and therein lies my question! Not trying to declare that a car is illegal, just interested in the interpretation in this circumstance.
Old 10th October 2017, 10:53
Jaguartvr's Avatar
The SS1 has a chassis so the screen can be removed .
Old 10th October 2017, 13:45
Old 10th October 2017, 13:52
Originally Posted by Mistrale View Post
Did you have to IVA this? The windscreen frame is part of the chassis on the SS1 (and has some roll reinforcement as I recall...) so cutting it off might offend the authorities.....
Scroll through this and you will see that the windscreen surround is part of the fibreglass structure......and you will see how much roll reinforcement it provides.....
http://www.scimitarweb.co.uk/sgwrs/viewtopic.php?t=1510
Old 10th October 2017, 16:51
micky1mo's Avatar
micky1mo micky1mo is offline
Only if you strip a Scimitar SS1 will you know how its constructed!!
The windscreen is part of the body tub which is a one piece construction made-up of the windscreen/bulkhead/floor pan.
This whole assembly can be unbolted from the chassis.
If you take the time and trouble to look at the link below (thanks Oxford 13/60) this whole assembly can clearly be seen, windscreen in place, being lifted over the chassis and the chassis can also be clearly seen with-out the body tub assembly fitted.
In this construction I chose to use the body tub with-out the windscreen surround because it makes the build quicker, easier and stronger. Even the original floor carpet can be re-used
So IMHO, no IVA required
Old 10th October 2017, 17:03
Cool - thanks for the info!
False confidence in the strength of the windscreen surround when I had my 2 then!!!
Could be very tempted by this....
Old 10th October 2017, 17:34
micky1mo's Avatar
The build should be "on the road" in a few weeks.
When it is your more than welcome to call-in and have a test drive.
Old 10th October 2017, 21:13
redratbike's Avatar
Apologies ...if you saw some of the recent posts you would understand
Old 12th October 2017, 08:47
scimjim's Avatar
scimjim scimjim is offline
So much love for my little SS1 :-)
As you can see from the pictures, with a standard factory roll hoop behind and the windscreen surround (which has a couple of steel tubes inside, running to the chassis) in front - it held up remarkably well and allowed my son to walk away unharmed.
Personally, I will always insist on a roll hoop in SS1s (and in fact we amended our competition championship regulations to include this requirement for roadgoing class) but it would ruin the lines of an open car. Perhaps a couple of hoops behind the seats would be better than nothing?
Old 17th March 2022, 15:40
micky1mo's Avatar
This is the original build blog for the car recently sold at auction .
I think I still have a few photos of the car when first finished/sold.
It's nice to see how the car has changed.
http://www.madabout-kitcars.com/foru...ead.php?t=7483
https://www.historics.co.uk/buying/a...24-replica-dl/
It,s a pity photo-bucket removed all the photos.
Old 18th March 2022, 12:02
HouseMartin's Avatar
Default Sold
Not quite a 20K car
https://www.historics.co.uk/buying/a...3-12/cars/?p=6
Old 18th March 2022, 12:31
micky1mo's Avatar
This is the car when first on-the-road.
The two LED's under the filler cap are extra brake lights.
Not much changed only removable hump and the decals.
