Old 1st February 2016, 21:35
Dpaz Dpaz is offline
Default Old engines and IVA
I have just been told by a bloke in the pub (unimpeachable source, maybe) that old Xflow ,pinto, A&B ser etc can no longer be used in a new build requiring IVA . Because of emissions. Is this so?
Old 2nd February 2016, 09:33
AcC8braman's Avatar
Deffo not.
As long as you can prove the age of the engine, it will be tested on the higher settings - ie will not need CATS
My car has a Chevy V8 dated 1990 and just gave in a copy of the V5 from the donor
Old 2nd February 2016, 10:59
peterux's Avatar
peterux peterux is offline
ACC8BRAMAN is correct, you can fit any engine and the exhaust emissions test is described in section 02B of the IVA manual.
However, you must be able to prove the age of the engine and VOSA will be looking for some documentation from the engine manufacturer. This may be difficult for older engines from Ford as I'm not sure they will help.
BMW customer service (and maybe others) will provide you with a letter for their engines but I don't know if Ford do the same.
Old 2nd February 2016, 11:18
Cheers chaps ,sorted. Though I won't convince my man.
DP
Old 7th February 2016, 15:21
deggsy deggsy is offline
For fords you can use the burton sales mag as they are all listed in there.
It was accepted for the SVA on my seven. I don't think it has changed for the IVA
