Old 30th October 2005, 15:35
BIG_Fella's Avatar
Default Brake Pipe's
On all the pics i have seen the front brake pipe to caliper there is a banjo fitting.
The pipe's that i have got there is a straight fitting.
What have you other builder's got.
Cheers BIG_fella
Old 31st October 2005, 20:04
BIG_Fella's Avatar
Anyone ??
Old 31st October 2005, 21:06
Dan's Avatar
Dan Dan is offline
Dan is on a distinguished road
My caliper pipes have the round banjo connectors, bolts are in the pack as well
Old 31st October 2005, 22:00
BIG_Fella's Avatar
We have wrong front pipes then...
Old 1st November 2005, 07:25
Patrick's Avatar
Patrick Patrick is offline
Most of the pipes were wrong on my Sportster kit too. I got my local garage to re-do the ends with the right fittings.
I had ordered that pipe flaring tool from frost.co.uk but found the results to be pretty rubbish.
Old 1st November 2005, 08:46
Ex-Biker Ex-Biker is offline
It should be a straight fitting for the 'T' piece and banjo for the calliper.
There should be 6 pieces. Master cylinder to 'T' piece x2 (straight fittings) then front & rear brake callipers to 'T' piece x4 (straight & banjo).
One problem some people have is the master cylinder connection, as Rover use a couple of different sized fittings, depending on the year & model of donor car.
I have overcome this by adding a couple of short pipe lengths - male for master cylinder - female to connect to supplied pipe.
Old 1st November 2005, 09:47
limpabit's Avatar
limpabit limpabit is offline
The way I got round it was to get another master cylinder from the scrappies.
