12th December 2012, 23:04
Hi CarNoob, it looks good.
Hi All, Just a stupid question will I need to install a bulge, as I am going to use a Vitesse MKII engine and chassis on my build.
See http://www.mikessammio.com/photos.html
13th December 2012, 08:47
Hi, My demonstrator Spyder has a MkII Vitesse running gear and engine and needed no bulges. It's close at the carb (Currently no air box but I'm looking at other solutions) but there is sufficient clearance.
13th December 2012, 11:04
I think it depends on the exact way you progress with your build and i don't think that anyone will be able to answer this apart from you when you get to that point.
I know that Andy (as he says above) and Gary before him never needed to mod the bonnet. But lots of us builders have found that we've needed to add bulges, scoops etc. in order to get the bonnet to sit as we've wanted it.
13th December 2012, 11:14
Many thanks, will just wait and see.
I think it depe.....................that we've needed to add bulges, scoops etc. in order to get the bonnet to sit as we've wanted it.
13th December 2012, 12:05
ebay purchase 14inch 4.5 j mgb wire wheels[IMG] [/IMG]
13th December 2012, 12:09
put on a hot wash
13th December 2012, 12:10
and glass bead blast
13th December 2012, 12:11
thats the job
13th December 2012, 12:16
thanks to Pal Steve from Webwww.crowndiffs.co.uk Landrover diferential repair specialist
14th December 2012, 02:00
Hi Andy
Have you recived my private messages?
Regards
14th December 2012, 21:43
The picture you posted is of a big saloon 2ltr six and box standing on wood blocks, similar basic engine but the box is completely different to a Vitesse box.
15th December 2012, 02:25
Thanks Ben
I was wondering about that the overdrive unit is a Laycock J-Type, I bought it unseen, but it was fitted in a Vitesse, I didn't do my home work first, but at that point I was planning to use a Herald and implant the 2.0, but now I have a complete Vitesse instead. I have since been informed, it is possible from a TR6 or GT6, if you have any other info please email me, when I get back to the I will check the serial numbers, then re-sell it, as I may also putting the engine up for sale once I find out what it is originally from.
Regards
15th December 2012, 11:48
the gearbox looks to me to be a tr6/ triumph 2000 as vitesse /gt6 has re/move abell bell housing what is the engine num on the engine and i will tell you
15th December 2012, 12:46
Thanks phil9 when get back to UK I will get the numbers and message you.
17th December 2012, 08:30
Handbrake position[IMG] [/IMG]
17th December 2012, 08:33
needs moving so out with the cutting discs
17th December 2012, 08:35
I wanted it tucked to one side and space for some buttons hiden in the arm rest Bond style
17th December 2012, 08:36
17th December 2012, 08:37
this will be position for new hand brake
17th December 2012, 08:39
make fibre glass boxes to fit in space
