Go Back   Madabout Kitcars Forum > Mad Build Area > Italian Replica builds and chat
Italian Replica builds and chat Lamborghini, Ferrari, Lancia, any Italian replica car build and chat
Old 10th November 2010, 17:47
Peggyontherun's Avatar
Peggyontherun Peggyontherun is offline
Peggyontherun is on a distinguished road
Default Lamborghini Murcielago Build
Hi all this is my build i only started it February 2010 so this is how far i am the kit is built on a Toyota MR2 turbo
5 Months into this is how far i got
Ingraved plate
Front view
Replica disks and calipers i made
The custom dash
I sent the dash off to be carbon fiber dipped
This is the top of the dash
The air vents all different carbon fiber
Exhausts fitted bit of a job fitting these
More parts carbon fibered the steering column
The dash
Seat bealt housing fitted
The air vent painted and fitted
The engine cover fitted
Old 11th November 2010, 00:12
JG's Avatar
JG JG is offline
Big Cheese
JG has disabled reputation
Looking very good. Keep us posted on progress.
Old 11th November 2010, 18:38
More pictures from today added
Old 15th November 2010, 18:32
Well have been busy trying to get the front section finished will be a week at it to get it 100% perfect a good bit of sanding left
I had to put in a whole new section as the previous owner decided to cut it all away :angryfire:
The front slam panel i got mad up
The slam panel fiber glassed in place
Old 20th November 2010, 17:31
Put in the front slam panel cut this out to fit then fiberglass it
A layer of filler to get it 100%
The fake calipers re-stickered with Lambo stickers and re-lacquered
The brackets on the rear of the caliper i sprayed them with heat resistant paint
The disk sprayed with heat resistant paint just waiting to finish the middle insert and spray that black
Old 26th November 2010, 17:38
Caliper on the car
The front coming along
The bonnet getting filled and sanded
Old 27th November 2010, 08:54
Chris Cussen's Avatar
Impressive!
Old 27th November 2010, 11:02
GreatOldOne's Avatar
Very nice - But why have you painted the discs? Even if it is heat resistant, The first time you hit the brakes the pad friction will strip the paint of the face of the disc...
Old 6th December 2010, 17:51
There fake caliper and disks they dont work there only there for show
Well have been busy and freezing with the cold
Sheeting into the front of the car to block off the front compartment
Lots od sanding and the gas struts all put back together
Expandable foam all filled the front wings there solid now
The middle section being covered up
Old 19th December 2010, 17:46
Here is some pictures i took yesterday lots of sanding going on as im trying to get
the front section finished.
Old 27th December 2010, 12:47
Here is a video clip of the Lambo running
http://yfrog.com/bhq22z
Old 4th January 2011, 21:57
My new tool box girlfriend baught me for Christmas
Lots of sanding going on
The fuel cap & engine cover cables all run and working perfect just have to mount my new levers
Old 15th January 2011, 19:43
Made the template for the roof lining and it has been sent off to be leathered in black with white diamond stitching the same as the seats are going to be done should look the bomb
Uploaded with ImageShack.us
Old 26th January 2011, 18:24
Got the sheeting cut out for the turbo intercooler housing that will feed air from the side skirt up into the intercooler all metal sealed with under seal
Intercooler at the side of the car
Looking up from the ground into the tunnel
All sealed
Got some mesh for the side skirts
Old 27th January 2011, 18:36
Hi i have been contemplating changing the bulk head as i wasn't happy with the flock so i used filler and im going to smoothen out the back bulk head i think it would look much better
Old 26th November 2012, 19:11
lambogenie lambogenie is offline
Kit Car Dreamer
lambogenie is on a distinguished road
What headlights are you using?
Old 26th November 2012, 19:37
Peggy use Photobucket... It would be nice to see what you are building!
