3rd October 2015, 16:22
Another Sportster's (finally) on the road!
The Sportster has her plates so I took her out for the first drive this afternoon.
I only went a few miles for the first trip just to get a feel for it. It seems to be pulling well but I need to sort a few problems out, the main one being a significant vibration at 50+. I had the front wheels balanced this morning ahead of the drive as I'd knocked all the weights off when I had my steering rack issues. The vibration is coming through the body rather than just the steering so next stop is the rears. I know that there's a very minor buckle in one of the rear wheels but shouldn't be enough to create so much vibration but it will be my first port of call. I'm just hoping it's not an issue with either the prop-shaft balance or angle between the gear box and diff.
I still have the suspension set up for the IVA test so I've got quite a bit of toe out plus the tyres are pumped right up and the suspension is all on the softest settings so addressing these things may help a bit. I've also got the new 40mm spacers on the rear so I'll see if I can run it without just to eliminate them from the equation.
My front cycle wings still bounce around quite a bit even with the extra reinforcement I fitted but I can see a fix for that already. Generally the car seems very squeaky/rattly but as I've never owned a car like this, it may just be noises I never normally hear cocooned in the cabin (I get obsessed with finding even the tiniest squeak in my cars).
I think the length of the nose is going to take some getting used to too. I was a bit paranoid about clipping the curb as you have to lean your head around to see where the wheel is. That will become second nature after a short time though.
If anyone's got some good advice on suspension settings for the road, I'd be interested. I'm going to change to a spot of toe in on the front and generally lift the ride height all round to make it a bit more speed bump friendly. It's the amount of damping front and rear I'm not too sure on from the point of view of the bias.
3rd October 2015, 19:21
Dear Ian,
firstly, a big congratulations on finishing your car and getting it registered! I bet your first drive was exciting and that view down the bonnet is something to savour!!
I think you'll get used to the front mudguards bouncing around which, so long as they don't fall off, is quite normal and nothing to worry about.
From memory I used to run with tyre pressures around 18-20 psi and only a couple of clicks from full softness on the front shocks.
I'm not sure about the vibration but perhaps you've flat spotted your tyres on your first lap (...well that's what they always say on F1 TV )
At least we finally know that gearbox works okay
Happy motoring.............peter.
3rd October 2015, 20:04
hey that's a thought, maybe it's the gearbox causing the vibration
No, it works fine and changes are nice and smooth, well, provided I press the clutch down properly. It takes a strong left leg with the current setting.
I've basically worked out where the mid point of rebound setting is on both front and rear dampers and set to that now. I'm going to get a full day of testing in tomorrow so should be able to play around with things a bit.
One thing I did notice when I had the car jacked up is the front NS wheel has a slight buckle. I thought I'd put the dodgy one at the back deliberately as you'll notice it less there but now I'm wondering. Hopefully that's all it is and I've found the problem rather than I now have 2 buckled wheels
The other things I noticed on my test drive were that the oil temp never got really warm on the whole 6 mile round trip, maybe 50 degs. This may be because there's so much air flow round the sump or that 6 miles just isn't long enough.
I've also noticed that oil pressure isn't really getting very high on my gauge and the light blinks now and again. The oil level is good but I did add some of that tappet loosening stuff (can't remember the name) a year back when I had the VANOS rattle issues. The oil seems more like the consistency of veg oil than engine oil so I wonder if it's a bit thin. A change wouldn't hurt I think.
4th October 2015, 09:36
Well done
Can you try the wheels from your daily driver on there see if tht cuts out the vibration? That is if the tyres on the rear ones will fit in the arches as the MV type 1's are staggered!
4th October 2015, 10:48
If sorting the buckled wheels doesn't cure the problem I would suspect the prop shaft! Has it been apart or new parts been fitted? I once replaced just the front yoke on a Mk2 Cortina (splines semed a bit worn) but didn't have it re-balanced. At 50 mph the vibrtion was horrendous! Ended up refitting the old yoke which luckily I had identified and all was well again.
Also do a quick check that there aren't any dribbles of paint or underseal on the propshaft as that will be enough to throw it out of balance (as does repainting it!). Peter.
4th October 2015, 12:34
The prop was a new custom made unit and had been balanced (had a little plate welded on). That doesn't mean it was correctly balanced mind you. I'm going to rule out all the more common causes first as that will be a pain to get looked at. I refurbished the drive shafts too so it's entirely possible they're out of balance though being so thin I would have thought it unlikely to cause a problem at road speeds.
I reset the toe in on the front this morning then gave my wheels an inspection for buckles. The one I knew about was on the back after all so that has to be addressed anyway. what I thought was a buckle on the front I now think is just a bit of corrosion damage on the bead which after they we're refurb'd shows as a minor inward dip as you spin the wheel. It isn't actually out of round.
I popped down kwikfit with my good spare wheel/worn tyre and my buckled wheel/good tyre to get them swapped over and they refused to do it. Said it's against company policy as they can't guarantee the work unless the tyre is brand new. Sounds to me more like they're only interested in helping if there's a tyre sale in it for them. Nowhere else is open today so I'll go to a local garage tomorrow and get them to do it. I can't just get a new tyre put on the good wheel as you can no longer buy the one I need to match the other side of the axle. It's pretty frustrating as it writes off an entire day of good weather and testing. I could probably fit my MV-1 front 225 wheels on the back of the Marlin but Patrick is right, they are a staggered set up with 255s on the back. A bit wide for the Marlin.
I've fixed up the front wings a bit too. I think the main problem is the weight of the GRP. Has anyone fitted Carbon fibre wings?
4th October 2015, 15:50
I've been doing a bit of reading around propshaft vibrations and come to the conclusion that the M5X engine set up in the sportster really isn't going to help.
Take a look at this link
http://www.therangerstation.com/tech...onangles.shtml
There's a diagram about halfway down showing the correct way to install a propshaft in terms of angles between the gearbox and diff. The Sportster set up is the worst possible. The diff is true to the chassis but the engine/gearbox is at an angle meaning that at best you'll have and angle at one end but not at the other. In the worst case (which is what I think we have) there is an angle at both ends but most importantly they don't cancel each other out and the angles are different so by the time the rotation gets to the diff, it'll be accelerating and decelerating all over the place causing a massive vibration. This is just looking at the layout from above before you even take into account any difference in height or angle between the gearbox and diff.
I'm now determined to get the engine sitting straight even though we've been told before the car is designed this way. That's moved to the top of my winter projects list.
4th October 2015, 21:05
Hi Ian,
Great news and many congratulation in getting the car legal. Lets hope we get a few more good days before the weather starts to really go down hill.
I had a prop shaft made for mine and I put a new set of wheels on the car and the set up, with the engine and gear box at an angle must be much the same as yours. I've had no vibration problems at all (just bought up 11,000 miles this weekend) so I wouldn't focus too much on getting the engine straight. I think I would be inclined to focus on the wheels first and if you could change them all out, or at least fronts and then rears its probably the first port of call, at least to eliminate them if nothing else.
Nigel
4th October 2015, 18:22
That's an interesting link and worth following up BUT what do other Sportster owners think? Have they had similar issues? If not IMHO it has to be a simple fix unique to your car rather than an inherent design issue. I remember a tyre fitting chap, years ago, saying that wheel(s) out of balance always seemed to cause vibration at either 30mph or 50 mph, but no reason was forthcoming! Peter.
4th October 2015, 18:59
I have never had any vibration issues. My wheels were new and the propshaft was custom made (dave mac).
Bearing in mind that the propshaft rotates at 3x the wheel speed - I would have expected a highish frequency vibration if that was theculprit. (Perhaps it is - you dont mention details...)
Wheel vibration should be quite rcognisable - I guess most of us have had that at one time or another.
How good a fit was the propshaft? On my car (E30 based) I had to reem out the centre hole so it was a good fit over the gearbox spigot. The spigot is used for centralisation on the E30 box.
Cheers Robin
4th October 2015, 19:56
I wonder if putting the car up on four axle stands and then 'driving' the car with and without the rear wheels would shed any light on the cause. (but do make sure it cannot drop off the stands!!)
I'm guessing that if it is propshaft induced it will still vibrate without the rear wheels fitted.
I know I joked about flat spotting your tyres but maybe if the car has been sitting on the old tyres for a long time then maybe they have deformed?
My bet is on your old wheels or tyres...........
4th October 2015, 22:14
If you put it up on stands also put some wheels under it, they give a nice big surface area if theres an issue with the axle stands
5th October 2015, 18:20
Looks like bad news for the moment.
I've just run the car with the back end on stands and with the rear wheels on or off, you get the bad vibration at around 40mph.
I left it running on idle in 5th and from what I can see of the prop past the exhaust, it didn't look that smooth. Maybe some run out around the slip joint area.
the good news is that the drive shafts didn't visually seem to be vibrating so the problem must be between the engine and the diff. There's a little vibration when rev-ing the engine through 1000-2000rpm but nothing to get worried about. It certainly doesn't cause the issue when reving through the range in neutral which I guess rules the flywheel and clutch out too. So I guess it can only be the gearbox, prop or diff. The former will be easy to rule out if I disconnect the front end of the prop though I'm pretty sure I tried that when I first got the engine running but before installing the prop and I would remember a vibration like this. I don't remember any vibration from the diff on my drive home after buying the donor either.
Tomorrow I'll get it a bit higher in the air so I can look underneath properly, maybe drop the exhaust and try and film it at the resonant point to see what's going on. I'm hoping it is something silly (but not funny) like a bolt working loose though I can't quite see how that would have happened so soon.
If the prop does look dodgy I guess it's easy enough to send it off and get it looked at.
5th October 2015, 20:58
U/Js
Have you checked the alignment of the Universal joints in your prop shaft?
If they are not matched to the exact spline you will get vibration - particularly since the input/output flages are not in the same plane.
5th October 2015, 21:47
Hi Mike,
I've not checked the UJ alignment directly but I did look at some photos prior to fitting to see if this might be the issue. It certainly looks ok here
I think some filming running though the gears will help, hopefully I can get that done tomorrow evening. I think a check of all the bolts is also a logical next step.
8th October 2015, 08:52
Have you found the cause ?
8th October 2015, 09:14
Hi Mike,
.................... I think a check of all the bolts is also a logical next step.
Not just tight but are the bolts and nuts all identical? i.e. same length. Also as someone said earlier check that the flange inner shoulder and recess is a good snug fit and doing the centralising of the mating parts and not just relying on the bolt holes. Peter.
10th October 2015, 08:17
Looks like you are homing in on the problem. I'm not familiar with BMW parts but that location spigot step is much lower that I have seen on other cars. Worth putting a vernier across it and comparing with the mating recess? As there is so little to locate on it may not be very effective in centralising the flange. Peter.
10th October 2015, 09:44
Hi Pete,
It's exactly 2mm high but I've a drawing bailey-morris supplied for the same part way back when I was first getting quotes and that says 3mm max. You can see the diff input flange below. There is a very shallow recess to fit into and in this instance, I can see that I need to spend some time cleaning the surface up a bit too as there's a small amount of rust left in there. I really could do with getting the face of the diff flange machined too as you can see some corrosion top and bottom where it wasn't covered by the original BMW UJ.
10th October 2015, 10:47
Interesting. I wouldn't do any machining on the flange as you would have to reset all the diff preload as you would have to remove it to do the job. I would do some very thorough hand scraping to just remove all the rust scale and then a smear of waxoyl to inhibit further corrosion. If you have an old flat file and grind the teeth off and then put a slight radius on the end it will do a good job of the scraping.
Just a thought. Was your special flange fitted before the prop was balanced? It should have been. Did you remove the flange to enlarge the holes and if so did it go back on the yoke in exactly the same position or was it replaced 180 degrees from original? Peter.
