Old 25th March 2010, 12:39
limpabit's Avatar
limpabit limpabit is offline
Default Engine conversion - the first mapping session.
Hi everyone.
Had a dyno/mapping session yesterday. Not as much as I was hoping for due to some problems. Boost control issues so only running 17-18 psi.
Turbo was fine, just engine/boost control valve could get more boost (turbo peaked at 20PSI).
It made 296BHP at the crank with 260 lbft. With a bit more to come
when fixed.
Should be enough to be getting on with.
Old 25th March 2010, 17:04
alackofspeed's Avatar
Have you tried it on the road yet?
I think you're in for a shock, when you do!
As an aside, the K04 is usually mapped to boost to 1.5bar in the mid-range, and crica 1 bar at the top end, and that makes 270. If your turbo is still efficient at 1.5bar at the top end, you'll make 320 ish?
Old 25th March 2010, 21:11
limpabit's Avatar
Nope, not had it on the road yet as cv joint split. Fixed that tonight.
Should be fun at the airfield day Saturday. Where I can test me and the car.
Not looking forward to being shocked!
Here's the read out.
Old 27th March 2010, 22:52
Airfield day completed without incident?
