Old 7th February 2022, 19:55
JG's Avatar
JG JG is offline
JG has disabled reputation
Hi Peter
Are you copying and pasting the content from somewhere else or typing directly?
Is it cutting off on a certain character?
Cheers, John
Old 7th February 2022, 21:40
I've had the same problems too ! Simply cuts me off sometimes and can't edit or add anything.
Old 8th February 2022, 08:06
Originally Posted by JG View Post
Hi Peter
Cheers, John
I normally draft my updates in the comments sections of Flickr where I store my pictures. I then cut and paste into your site with some editing, etc. I've being doing it like this for years without a problem.
But your right about the pound symbol as that is exactly where it is truncating.
I will try again.....
thanks, Peter
Old 8th February 2022, 08:10
Default I'm back.........
(Ok, trying again without the pound sign)
Well after Christmas and the new year I took a short break from car building to carry out some important home improvements. Still got lots to do but my New Year resolution is to 'finish' my Sabre this year, so I better crack on ......
So, I was back in the garage this week tackling something I wasn't really happy with last year.....
Whilst browsing the internet over Christmas I came across these motorised door lock mechanisms. There are multiple sellers on ebay but this set cost me just 12.95GBpounds including postage which I thought was a bargain and worth a punt.
Remote door locks by Sabrebuilder, on Flickr
And for an additional 11.36GBpounds, I could add this remote control box and two rather nice control fobs. The box has a number of features including flashing the side indicators when you lock or unlock.
They have been sitting on the shelf for a while so it was time to try them out and see if they work.
They are pleasingly well made and came with clear wiring instructions and have a good strong action. They were easily fitted in the Sabre's door and work perfectly.
I now have the other door to do and to fit the interconnecting wiring. I also need to find suitable locations for the control boxes.
I've also tested my windscreen washers and wipers against the requirements in the IVA manual.
Bizarrely, you have to simulate the washer jets being blocked and check that the washer pump doesn't fail!
The wipers are required to have two speeds.
One has to be at least 45 cycles per minute. The second has to be between 10 and 55 cycles per minute and at least 15 cycles per minute different to the first.
Mine passed, phew!
So a good start to the year and next week I'll be fitting the locks to the second door....
....peter
Post posting note: well that worked fine, thanks John
Last edited by peterux; 8th February 2022 at 08:12.. Reason: Post posting note added
Currently Active Users Viewing This Thread: 2512 (0 members and 2512 guests)
