5th August 2018, 18:54
OBDII Bluetooth Scanner
I've just picked up one of these for £4.30 and downloaded the OBD Car Doctor app from elm327.com onto my Android phone.
The free app is fairly basic- rpm, coolant temperature and not much more. The full functions only become available when paying for the Pro version. (~£14)
Not sure how much info is available on the Z3 as its OBD is not fully compliant but I would expect to see trouble and servicing codes and be able to switch them off. There is also a data logger function.
Reason: pic added & basic info clarification
6th August 2018, 20:03
Originally Posted by IanA
I've just picked up one of these for £3.79 and downloaded the OBD Car Doctor app from elm327.com onto my Android phone.
And now I've upgraded to the Pro version. ( £13.49)
Interesting range of functions:
Road speed
RPM
Intake Air Temperature
Engine Coolant Temperature
Fuel consumption
Diagnostic Codes (library of 18193) (reset them with ignition on and engine off)
% Engine Load
Short Term Fuel Trim Banks 1 & 2
Long Term Fuel Trim Banks 1 & 2
Ignition Timing on #1 cylinder
Airflow Rate through MAF in g/second
Oxygen Sensor voltage and % Banks 1 & 2
Battery Voltage
but no ECU info (probably the Z3 non-compliant bit).
So basically- a whole load more things to worry about !!!
18th August 2018, 19:16
More pre-paint help please
More pre-paint help please:
1. How to remove Z3 door handles? I've got the clips off of the front pins but how to access the rear fastening?
2. How to remove the outer door top rubber trim? I'm guessing that loosening/removing the front window runner and quarterlight should provide access. I've found 2 bolts holding those.
18th August 2018, 21:31
Evening Ian there are 3 bolts holding the quarter light unit in place , one of them is under the door , Geoff .
18th August 2018, 22:48
Thanks for that, Geoff. I'm covering a Boston Green car with Ford Frozen White so trying to avoid any obvious lines showing on the outside.
19th August 2018, 16:04
No need to remove that clip- just slide an inside catch forwards and then back having replaced the trim- see here
This removes the door handle surround which is all that's required when painting. If you need to remove the handle and latch mechanism- removing the surround exposes the head of the front pin (clip comes off the back of that) and the rear is removed by rotating the bezel around the key cylinder. Then "just" unbolt the latch mechanism from the edge of the door. There's a YouTube video for that as well.
Reason: More info
19th August 2018, 18:40
2. How to remove the outer door top rubber trim? I'm guessing that loosening/removing the front window runner and quarter-light should provide access. I've found 2 bolts holding those.
Like most things- dead easy when you know how.
Remove the frangible clip at the rear of the door. That releases a triangular lump of rubber which is connected to the top trim. Ease it all upwards along the door and there's another triangular lump of rubber at the front which somehow grips the door. Ease that out and you're done.
It does make it a little easier if you have the inner door card off and loosen the top bolt holding the window runner/quarter-light but not essential when removing. Might be different when replacing with a new item but I find that Swarfega (NOT the one with plastic granules in it) works wonders, or Fairy Liquid.
Reason: Swarfega (NOT the one with plastic granules in it)
22nd September 2018, 08:19
Well- here we are- sanded down and ready for primer...
Work progressed quicker than expected- here it is with doors, bootlid and wheels back on- just need the bonnet to be painted and stripes applied...
22nd September 2018, 08:44
I saw this note and thought Ian was building a 2nd car........ It was only when I scrolled back a few pages I found a reference to getting the car sprayed. I'll keep taking the 'oldtimers' pills!
22nd September 2018, 08:56
Looking forward to seeing this
22nd September 2018, 09:15
If only- I would like a 250 convertible but space not available here.
This is the Z300S's 4th summer so I thought it was about time to get it painted. No further gel coat issues showed themselves in the hot sunlight/temperatures this year so I'm hopeful that the finish will endure. Two-pack paint has been used.
28th September 2018, 16:32
At last !!!
Fettled just enough to get it home...
Stripes to follow.
28th September 2018, 16:40
Liking it!
28th September 2018, 17:23
Very nice.
29th September 2018, 10:13
Looking so much better.
Chrome door handles, headlight covers and a grill, then you can it's finished.
29th September 2018, 10:19
Chrome door handles, headlight covers and a grill, then you can say it's finished.
Thanks Jag- also- just a small matter of the woodrim steering wheel, some cobra-style lowback seats (in the correct mid-brown colour), similar shade of alcantara wrap on the dashboard (door cards already done) and stainless wire wheels.
29th September 2018, 10:30
Earlier in your build thread, you mentioned "Polish wire wheel adaptors" but went with Orsen.
Any leads on some cheaper adaptors?
29th September 2018, 15:02
My friend Mork used to deal with Orsen on a weekly basis .....
29th September 2018, 15:17
Earlier in your build thread, you mentioned "Polish wire wheel adaptors" but went with Orsen...
Never found them so went to MWS for the adaptors and spinners. WCA used Orsen.
29th September 2018, 17:19
Am I right thinking Mindy was involved in that little manage et tois ?
