7th January 2006, 23:19
We got the brake pedal back from a friend who was able to bend it for us. Now the positioning is much better giving more room between the accelerator mand brakes (we've got big feet!):
15th January 2006, 16:41
Oil cooler fitment and revised radiator fitment:
23rd January 2006, 12:25
Order from Car Builder Solutions turned up today, placed on Friday afternoon! One heater and plume, a rivnut gun, universal band and a set of dash warning lights (I really didnt like the ones that came with the kit so I order these instead):
I've done a lot of work on the steering column bulk head mounting on sunday, it was nice and sunny so out the driveway! I've not put any pictures up yet.
12th February 2006, 16:09
19th February 2006, 15:03
Time for another version of the radiator bracket! Its now bolted along the sides with two strips of metal either side of the rad. Bolts need shortening to and a lick of paint to clean it up.
All the water pipes for the front of then engine are now cut to size and routed. Currently the bottom pipe is zip tied to the bottom of the radiator - I'd like to find a more elegant solution for this but it will do for the moment.
Oil pipe test fit, not sure yet how we're going to run these so these are just where they will fit at the moment. The oil cooler connectors we have are the straight type so are most suitable for running the pips this way. 180 degreee connector would work for going under and along. More research need on this one!
26th February 2006, 20:19
Today we installed the fuel level sender in the fuel tank - sounds easy but it took most of the day! Stage 1 was to figure out the numbering system as the chart that came with the sender only when down to 180mm deep tanks. The Marlin tank is 160mm. Luckily it was quite an easy one to figure out - 160mm depth, 67mm pivot, 63mm radius.
Next on the list was to make the hole that the send goes in. It was all going well until the dremel (110v 20 odd year old model) finally giving in and died leave the rest of the cut out and clean up to me done by hand. Still turned out quite nicely:
There was a lot of mess in the tank, but luckily one of the vacuum cleaner attachments fits in the hole!
This only leaves figuring out how to attach the fuel hose to the tank and mounting the filter/pump!
5th March 2006, 16:13
Busy weekend! We've installed the car builder solutions heater and put the oil cooler pipes in. The oil return pipe on the engine recieved a new spring, washer and o ring. The steering column is back out to clean up the bracket that holds it and adjust the bottom bracket.
2nd April 2006, 15:52
A quick trip to B&Q and one hardcore MAPP blow tourch later the two oil pipes are bent out of the way of the steering column with ease!
CBS Throttle cable through the bulk head. The thread on this had to be chopped back so the pedal could move all the way up. We've bolted on throttle cable at the other end - the cable is current 5m long which is a bit much! The throttle is still a bit stiff with the long cable - We're hoping that it will loose a bit once its shortend.
Parts from the donor heater system - The two pipes use opposite connector types therefore when connected we can use this as an inline electric controlled valve to regulate the amount of hot water that flows through the system from a control on the dash - much nicer than a manual valve hidden under the dash!
Following on from this thread: http://www.talkaudio.co.uk/vbb/showthread.php?t=151195
I'm looking for someone to build an exhaust for me:
Originally Posted by black-cat
Patrick, do you want something good or something loud, badly made and bad for the engine?
Do you need the manifold making too?
Something good and something that's less than 101db (1 meter from tip - SVA req.)
Yes need a manifold too.
EDIT: Budget wise I've got around £800 to play with - maybe a bit more if its something really good.
Looks wise I'd like pipes out the side of the engine bay - like this only evenly spaced:
Finishing with the pipe on the side - similar to this only with 6 pipes:
Originally Posted by kw_maher
didnt know you were building that. just looked through your site, and am impressed. nice read - well done
Thank you! I will be updating the site later today with new pics as I've been busy this weekend!
EDIT:
As far as manifold design goes for the M20 engine - this is supposed to be very good - not good for me as I dont want an underbody exhaust:
http://www.xsperformance.co.uk/e30zo...ages/btb23.JPG
Heater pipes added - CBS sent the wrong size pipes - too small, managed to get them on anyway but they kink on the bends so will have to replace them. Probably with two 90 degree silicon hoses.
Fuel pipe straps - Doh! hmm should really have thought of this before making a big hole in the tank - never mind just moved the straps over.
Fuel pump, filter and connection in place:
2nd April 2006, 15:53
2nd April 2006, 15:57
Decided to use the BMW header tank using Robin's car as a model!
AFM bracket part 1 - this fixing is not yet strong enough - the metal flexs too much to hold it safely. We'll need to add a more solid metal bracket up from the bottom. Other end of the bracket - holds the carbon airbox and the bottom of the header tank. The carbon airbox can be moved further forward by shortening the blue silicon hose making more room at the back for an intake pipe.
This bracket used to hold the diagnostic port in addition to the two sensor plugs - theres not much room here anymore so were going to move the diagnostic connector else where. The bracket has been cut and attached at a different angle to normal.
8th April 2006, 20:36
Spent all day in the garage but the only really constructive thing to come out of it was a mounting for the fuel pump:
9th April 2006, 09:47
Have you used "cotton reel" rubber mounts on fuel pump? It's just that the donor pump was mounted this way, so not sure if it's a must do.
Alfie
9th April 2006, 10:38
No but I've use rubber round the back and the whole pump is covered in spongy stuff the dampens the vibration. However something I will look into thanks
17th April 2006, 19:36
Misc items done such as finishing the steering column mount and putting the pedal box in for the last time (we hope!)
New tubes added
AFM Mount:
Also started wrapping the engine wiring loom ready to go back in the car.
23rd April 2006, 22:17
3rd May 2006, 17:04
11th May 2006, 21:15
Seat belts / harness' are here And an audi fuel filter - now I just need to find M14 unions!
14th May 2006, 17:08
We've decided to use the stock 4 stud alloys to start with, but with larger tyres that we've got from and E36. The alloys have seen better days after a good 15 years on the car! So today we've had the old rubber taken off the rim and started the refurb process. None of the pro restores I called would touch the plastics caps and most wanted £55 per wheel. So as these are only until we've worn through the tyres we decided to try the Halford wheel restoration kit. The results are pretty good consider its DIY - only finished one of the three so far, it take a long, long time with lots and lots of sanding to get anywhere!
Also a small job in the engine bay, mounting the coil and arranging the pipes. The Car Builder Solution pipe that I had custom made instead of the 3rd radiator cap is install with the pipe over to the header tank:
Click me
24th May 2006, 08:14
Sanding, sanding, sanding, sanding.... after find there is not enough paint in a halford repair kit to do a proper job it turns out you can't buy the paint seprately?!?! Ok plan B filler primer, sanding, primer, Honda Noble silver, lacquer! That should yield much better results than the paint in the kit. The stuff for filling the holes was good though.
Coil overs have arrived from Gaz - first test fit. Its tight and the chassis might need a bit of modification to get everything running nicely! Finish quality is excellent with ball joints at the top are welded into the E46 top mounts I sent to them.
Had a very good look around underneath with weight on the car. It really it down to 2mm clearance, especially on the left side. However when you bounce the suspension nothing rubs - I just wonder how much they will move around while under load. What we're probably going to do it pull the strut tower out a tiny bit and move the mounting hole at the top by a few mm to increase the clearances. Very happy with these, the spring seems a bit hard but we'll see once the car has its full weight in. The nice thing it replacing the spings is a very easy job - and not too expensive either!
