30th March 2015, 07:56
Thanks Chris , Geoff .
30th March 2015, 08:20
Try MWS in Slough (England!). They list this one for the Z3 1.9 but I don't know about a 2.8. The price for an e-type replica is £200 + VAT.
http://www.mws.co.uk/custom/FitmentG...ke=BM&CarYear=
Sadly, MWS reply is "Wheels at the size you request would have to be made as specials and the cost of these is very high"
Reason: additional information
30th March 2015, 10:42
Here you are Chris, I found these on ebay. http://www.ebay.co.uk/itm/1511385147...%3AMEBIDX%3AIT
They are also available from Alfaholics in the UK.
Problem is they are for a left hand drive car so the lock is on the passenger door for a UK car. Not sure if the buttons are interchangeable.
30th March 2015, 14:18
Door handles
For those interested in historical accuracy, I got this genuine 275GTB handle from "new old stock" via ebay, sadly, they only had one. Note the Ferrari had a separate key mounted on the driver's door only.
Bearing in mind the need to match the Z3 door mechanism, I found these "new old stock" (no more left)
31st March 2015, 07:07
My original choice of Classic Mini door handles has proved problematic when connecting the Mini lock/key mechanism to the Z3 door latch unit. Changing the linear movement of 15mm in the mini lock (at 45 degrees when mounted of the SWB door skin) to the 40mm vertical movement required at the Z3 internal latch using cantilevers working in a reversed ratio (small movement to large) has given an unreliable solution. So, a new solution has hopefully been found with these handles and there attached mechanisms:
http://www.ebay.co.uk/itm/4003682559...%3AMEBIDX%3AIT
They are readily available at reasonable cost, look period and that fact that they are Italian is a bonus!
I will update once I have test fitted one.
Any update on the Alfa door handle front? Have you managed to get them to work yet? Only I can source a pair locally and am champing at the bit to buy them...
4th April 2015, 10:52
What is needed from the bonnet of the z3 ...hinges and latches????
Is the inner bonnet frame needed ???
Come across a few front damaged cars at good prices that would be ideal for conversion.
4th April 2015, 19:45
I have only gotten as far as to mount one handle on temporary brackets to judge how things will work. Everything is backwards in relation to the location of the Z3 mechanism, meaning swapping handles from side to side and adding some fabricated levers to the Alfa workings to reverse their action and move the connecting rods above the Z3 gubbins:
I am almost certainly positive that they might work, maybe. Just hedging my bets there.
4th April 2015, 19:49
The double skinned GRP front section of the SWB kit comes fitted with captive bolts/nuts that require the standard Z3 bonnet hinges and latches to be retained, but the Z3 bonnet can be sold off if in good condition.
4th April 2015, 22:51
Thanks Chris
5th April 2015, 06:01
Sounds good to me. After all, a probable certainty of possible satisfactory operation is a solid gold guarantee in the specialist car world.
More importantly they look the part. If all else fails I'll just fit them for the style they'll impart and bung a wrought iron hasp and padlock on for access and security. After all, with no IVA to worry about I can pretty much do what I like!
(...and before I get any disgusted from Braintree posts about safety, I'm joking about the hasp).
Oh, and I also thought that if the mechanism won't play ball I could always go with solenoid locks/door release with a hidden mechanical override in case of battery flatness. Just a thought.
5th April 2015, 07:15
And what's wrong with a wrought iron hasp and padlock? Most Transits have them, especially white ones.
5th April 2015, 10:08
24th April 2015, 07:56
Door handle and door skin
Take a look at my thread on F275gtb/z3 for an alternative solution. The reverse curve at the top of the door made it impossible to lay the 275 panel on top so I have removed the door skin completely (apart from the area around the handle in order to locate the actuating mechanism).
5th May 2015, 15:57
Finalised side window frames will be show in the next few days. They are bolted to the Z3 doors and will include double channel rubber seals, Land Rover latches and toughened glass.[/QUOTE]
Hi Chris,Your frames look very good if you are thinking of making them in aluminium this might be useful.
https://www.youtube.com/watch?v=doVIQ4y29NE
5th May 2015, 16:23
https://www.youtube.com/watch?v=doVIQ4y29NE[/QUOTE]
Very interesting. Thank you.
7th May 2015, 22:10
I have been asked by several customers to compile a list of basic items required to build an SWB, The following are examples, there are limitations on the size of rear lights due to body recesses and we have set the kit up for Mini door handles, but all other items are down to personal choice:
7" Headlights with side lights + buckets
http://www.s-v-c.co.uk/product/7--he...bly-with-side/
Chrome headlight trims, MAKE SURE THEY ARE THE TAPERED TYPE
http://www.retroclassiccarparts.com/...for-triumph-tr
Rear lights
http://www.s-v-c.co.uk/product/l539-...--tail--pair-/
http://www.s-v-c.co.uk/product/l539-...icator--pair-/
Front indicators CLEAR LENSES WITH AMBER BULBS REQUIRED
http://www.s-v-c.co.uk/product/l594-...icator--pair-/
Side repeaters (front wing). Example for style, but your choice
http://www.ebay.co.uk/itm/CLASSIC-FI...item35da2f95bd
Fog light Example, your choice. REVERSING LIGHT TO MATCH? NOT REQUIRED FOR MOT
http://www.s-v-c.co.uk/product/1253-rear-fog-/
Reflectors. Example of period correct for SWB, but your choice
http://www.s-v-c.co.uk/product/lucas...ectors--pair-/
Washer jets
http://www.ebay.co.uk/itm/CLASSIC-MI...item418580ccc8
Numberplate lights x2
http://www.s-v-c.co.uk/product/550-t...lamp--frogeye/
NUMBERPLATES: UK STANDARD SIZE, OBLONG FRONT + SQUARER REAR
Mini boot handle
http://www.ebay.co.uk/itm/CLASSIC-MI...item1c4e51bded
Bonnet pins, Example
http://www.ebay.co.uk/itm/BONNET-PIN...item19eedbb0e8
15th May 2015, 20:00
15th May 2015, 20:04
Looking good Geoff.
I like the colour for some reason.
16th May 2015, 06:25
Great progress from yesterday afternoon, its a very well designed kit to even be hung together in such a short time.
The wheels look great, it will be nice to see the car side on once it makes it outside
I'm glad that Chris and Dan dress up to trim the excess fiberglass from the kit for the customer and get covered in dust,
16th May 2015, 17:38
Originally Posted by hurnleft
Looking good Geoff.
Evening Bob , thought you would , Geoff .
