Old 8th November 2013, 13:53
ikon246 ikon246 is offline
ikon246 is on a distinguished road
high looks good so far,what tyre size did you go for...........i will use 175x80x14
i hope theese will fit,i think maybe bcz the front baulhead is futher back there will only be the out riggers to get in theway?
good luck
clive
Old 8th November 2013, 16:31
rattler rattler is offline
hi ikon I used 175/70/14 they just miss the o/r 5mm one side 10mm the other side. I didn't want to cut the o/r or messabout with the s/rack or cut the arches .Ive got 40 mmat rear 60 mm at front I hope its ok .I asked what others have but no one came back. had agood day half the b/head in just got to polish the ali dave r
Old 13th November 2013, 17:31
ah 175 70 14.............what are they like in the arches? do they ook ok profile wise? they are cheaper aswell? ground clearance ok?
what make did you go for?
nice job by the way.
clive
Old 13th November 2013, 17:39
hi again? i see you have cut the rear outriggers off? do you think it will be ok? i want to cut them rather than have to repair the body?................what you recon then? clive
Old 13th November 2013, 20:02
hi ikon tyres cost 60 euros fitted with tubes/50 pounds ish/ per wheel will mesure tomorrow and get back to you.busy polishing the ali panels black hands but starting to look ok dave r
Old 13th November 2013, 20:15
thanks dave r
yes i have some new tubes new wheels cant decide on the tyre size?
i guess with the miglia theres not a problem with the baulhead? just the front out riggers,i was hopeing the wheels look ok in the arches and the ground clearance is ok
thanks clive
Old 14th November 2013, 18:21
hi ikon I think the tyers look ok ground clearance ok .ive got side exust so it mite be a bit tight on speed humps.got motor running today drove it up the lane sounds good. only prob it over heated so rad of clean fit new w/p and t/stat try again.dave r
Old 15th November 2013, 11:44
hi dave
all looking goodwould be nice to see what you have done with your exhauts?i to was thinking about it maybe removeing the sill on the body and make a nice sheils ect..........looks good ill keep on checking your threads.
clive ikon
Old 15th November 2013, 18:55
hi ikon engine running sweet as a nut jet washed the rad /cyl/head new w/pump now cool as a cucumber cut o/r as I will reg in france I just run the exust out side the body. flex pipe and cherry bomb under car 2 inchsteel pipe along the side sounds really good may change to 2inch polished ali if I can find someone to bend it .try and post pic at w/e dave r
Old 25th November 2013, 12:06
hi all just a few pic <a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0741_zps60939010.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0741_zps60939010.jpg" border="0" alt=" photo IMG_0741_zps60939010.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0739_zps16d64b09.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0739_zps16d64b09.jpg"
="0" alt=" photo IMG_0739_zps16d64b09.jpg"/></a>
Old 25th November 2013, 12:57
Viatron Viatron is offline
EDITED FOR YOu SO THE PICTURES APPEAR,
Old 25th November 2013, 13:04
Love turned Ali, good luck keeping it clean though :-)
Old 25th November 2013, 13:35
More pics, move further away... looks very interesting. I like the edging and copper pipe
Old 25th November 2013, 14:20
hi done something wrong should be more pics will try again don't need to clean ali 3 coats of lacuer its a pain to do but it looks nice dave r
Old 25th November 2013, 14:38
Looking like your having fun Dave. Great job mate.
Old 25th November 2013, 14:40
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0737_zps99e0cd4f.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0737_zps99e0cd4f.jpg" border="0" alt=" photo IMG_0737_zps99e0cd4f.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0736_zpsff52a1bf.jpg.html" target="_blank"><img src="http://i1363
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0734_zps00c1d8f6.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0734_zps00c1d8f6.jpg" border="0" alt=" photo IMG_0734_zps00c1d8f6.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0731_zps4c515d3b.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0731_zps4c515d3b.jpg" border="0" alt=" photo IMG_0731_zps4c515d3b.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0739_zps16d64b09.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0739_zps16d64b09.jpg" border="0" alt=" photo IMG_0739_zps16d64b09.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0727_zps42b8514f.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0727_zps42b8514f.jpg" border="0" alt=" photo IMG_0727_zps42b8514f.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0722_zpsd4b4513a.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0722_zpsd4b4513a.jpg" border="0" alt=" photo IMG_0722_zpsd4b4513a.jpg"/></a>
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_0721_zps0cc2d27d.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_0721_zps0cc2d27d.jpg" border="0" alt=" photo IMG_0721_zps0cc2d27d.jpg"/></a>
.photobucket.com/albums/r707/rattler33/IMG_0736_zpsff52a1bf.jpg"
border="0" alt=" photo IMG_0736_zpsff52a1bf.jpg"/></a>
Old 25th November 2013, 14:43
hicant get pics to upload may be v will do it ta dave r
Old 25th November 2013, 16:18
Dave - That is a very nice engine bay you have there.
Hopefully I can make a few more of your photos appear...
If you press the "Quote" button next to this post you will be able to see the difference in the photo link coding.
Old 25th November 2013, 16:19
<a href="http://s1363.photobucket.com/user/rattler33/media/IMG_6734_zps9b610d03.jpg.html" target="_blank"><img src="http://i1363.photobucket.com/albums/r707/rattler33/IMG_6734_zps9b610d03.jpg" border="0" alt=" photo IMG_6734_zps9b610d03.jpg"/></a>
Old 25th November 2013, 16:23
hi ive given up will wait for my daughter to do it dave r
