Old 29th April 2019, 18:45
micky1mo's Avatar
micky1mo micky1mo is offline
This is the full mock-up of the front end.
Old 29th April 2019, 19:00
molleur molleur is offline
Nice, the spider web compliments the cow catcher nicely. Well done!
Old 2nd May 2019, 06:21
Mike - Nice to see this coming together & I like the front indicator mounts.
Old 5th May 2019, 18:04
micky1mo's Avatar
I spotted a classic wind screen on E-Bay that measured about right so I offered £45 and got it!!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=1042440513022
My thought were if it all goes wrong and doesn't fit I'll be able to use it on something else in the future.
The first thing I had to do was clean out all the old rubber seals.
Then lots of penetrating oil to free-up the top hinge and side adjusters.
Once these were working nice I made a simple supporting frame from 3 bits of 40 x 40 x 3 angle.
This frame is fixed to the original top hinge and side mounting brackets allowing it to swing away. This also allows the screen to be removed if needed. .
I had to trim a little steel from the top edge which helps to give it some shape.
Once I had lined the screen up on the truck it became evident some serious cutting was needed.
The top edge of the frame fits against the roof line and is held in place with the aid of some brackets.
The side rails rest on the lower dash cross member to which they are welded in place.
Then it was just a case of filling in the gaps around the ill-fitting wind screen.
Again a very satisfying job that gives the truck a period look .
I was quoted £80 to have a piece of glass cut to fit so alls fine and as a bonus this style of screen also eliminates the need for wipers but I'll fit a single one-arm unit as the holes are there for it.
The next dauting task it to try and fit opening door windows complet with glass, runners, winders, and finally door cards!! .
Old 5th May 2019, 21:41
Dpaz Dpaz is offline
Brilliant. For your door glasses, why not look at lifting glass with a leather strap as in old railway carriages? With a final hook to hold it fully closed.
Old 6th May 2019, 17:15
micky1mo's Avatar
I tried that on another truck and ended up using bungee cord to keep the windows closed and to stop them rattling so it's not for me !!
Old 6th May 2019, 19:26
Jerome Jerome is offline
Jerome is on a distinguished road
Don,t know which size but maybe;sliding windows from Citroen Hy.
You can still order new frames......
Old 7th May 2019, 07:49
micky1mo's Avatar
I might be a "woose" but, sliding window just an't cool.
I'v been sizing-up a pair of Land Rover Discovery rear windows. !!!.
Old 21st May 2019, 19:38
micky1mo's Avatar
Spent some time filling-in some of the gaps around the edges.
Rear edge.
Front edge.
Overall view.
Not sure how I'm going the sort out the door bottoms yet.
Old 21st May 2019, 19:46
Put a raiser on the sill.
Looking good!
Old 19th June 2019, 14:08
micky1mo's Avatar
Got a old mini heater fitted under the dash.
Also fitted an overdrive switch to the gear stick.
loving this build.
Old 23rd June 2019, 18:29
micky1mo's Avatar
I gone for the "steam punk" look with the dash board.
Because the clocks are so deep I had to remove the steering column to get the dash to fit in, I just hope I can reach and tighten the column clamps when I re-fit it .
Old 23rd June 2019, 20:38
Looks good love the heater (?) controls. Nitpicking I know but Surface mount 4" brass gauges would look interesting. Envious of your skill. Dave
Old 16th August 2019, 16:58
micky1mo's Avatar
As we are in the mood for painting we put a little on the pick-up.
Old 16th August 2019, 18:15
loving it!
Old 16th August 2019, 19:42
Also, I love it.
Old 20th October 2019, 15:34
micky1mo's Avatar
The rear tub has now been lined with T&G .
The T&G planks are pressure treated but I'm not sure weather to leave the wood as it is, stain it or varnish it.
I also freed off the clutch plate, freed off the front brakes and fitted new rear brakes.
Old 20th October 2019, 15:59
I'd coat them in epoxy or simply varnish them.
Looking really good! Well done.
Old 20th October 2019, 17:02
Jaguartvr's Avatar
Rustins plasticote after staining them. 2pack and as hard as nails, easy to put on as well. Satin or gloss finish.
Old 20th October 2019, 17:13
Never learned of that. Sounds good to me. Much easier than epoxy.
